1.0.0-alpha.5-9767656 - crash
zmechu
Crashing when using scripts:
https://forum.sinusbot.com/resources/wheel-of-fortune.373/
https://forum.sinusbot.com/resources/sconomy-ng-simple-currency-system.367/
Last lines noticed at sinusbot application:
        :2197 +0x1
goroutine 13834 [IO wait, 2 minutes]:
(0x1f13388, 0x7fb42e6180e8, 0x1e13eee, 0x7, 0x889a1b, 0x5)
        :271 +0x13a
(0x7fb42e6180c0, 0x72, 0xb)
        :345 +0xc7
(0x7fb42e6180c0, 0x72, 0x26)
        :164 +0x59
(0xc420056928, 0x72, 0x28fc660, 0x28f6ad0)
        :75 +0x38
(0xc420056928, 0xc420508000, 0x4)
        :80 +0x34
(0xc4200568c0, 0xc420508000, 0x4, 0x10000, 0x0, 0x28fc660, 0x28f6ad0)
        :250 +0x1b7
(0xc42007cba8, 0xc420508000, 0x4, 0x10000, 0x0, 0x0, 0x0)
        :181 +0x70
(0xc42595ed80, 0xc420508000, 0x4, 0x10000, 0x5f, 0xc4250c7e60, 0x5f)
        :79 +0x7f
(0x28f8d20, 0xc42595ed80, 0xc420508000, 0x4, 0x10000, 0x4, 0x5f, 0x5f, 0xc4250c7e60)
        :307 +0xa9
(0x28f8d20, 0xc42595ed80, 0xc420508000, 0x4, 0x10000, 0x5f, 0x2, 0x0)
        :325 +0x58
(0xc420394580, 0xc42595ed80, 0xc425c74b50)
        :581 +0x11c
        :2197 +0x1
goroutine 13972 [select, 2 minutes]:
(0x1f133f8, 0x0, 0x1e13885, 0x6, 0x18, 0x2)
        :271 +0x13a
(0xc4256826f8, 0x0, 0x18)
        :423 +0x1364
(0xc4256826f8)
        :238 +0x1c
(0xc420261ec0, 0xc420394580, 0xc420261e80, 0xc425c83860)
        :2383 +0x32b
        :2197 +0x1
rax    0x0
rbx    0x21bd5d8
rcx    0xb40
rdx    0x0
rdi    0x7fb42c2dc520
rsi    0x7fb42c2dd750
rbp    0x7fb3f67fb120
rsp    0x7fb3f67fae18
r8     0x7fb42c2dd750
r9     0x7fb3f67fc700
r10    0x0
r11    0x0
r12    0x2259353
r13    0x0
r14    0x7fb3f67fb4a8
r15    0x7fb4240e7a10
rip    0x13280f9
rflags 0x10202
cs     0x33
fs     0x0
gs     0x0
Sinusbot diagnostic script:
 - Operating System: Debian GNU/Linux 9.5 (stretch)
 - Kernel: Linux 4.9.0-8-amd64 x86_64
 - Load Average: 0.25 0.17 0.17
 - Uptime: 28 days, 6 hours, 38 minutes, 57 seconds
 - OS Updates: 52 (updates available!)
 - OS APT Last Update: 02.12.2018 17:05:26 CET +01:00:00
    CPU(s):                2
    Thread(s) per core:    1
    Core(s) per socket:    1
    Socket(s):             2
    Model name:            Common KVM processor
    CPU MHz:               2199.998
    Hypervisor vendor:     KVM
    Virtualization type:   full
 - RAM: 948.23 MB/3.86 GB in use (23%)
 - DISK: 12.46 GB/49.18 GB in use (25%)
   + libglib: 2.50.3-2
 - Status: running (PIDs: 3844 3843, User: sinusbot)
 - Webinterface: port locally reachable (Port: 5003)
 - Binary: /home/sinus1_ALPHA/sinusbot
 - Binary Info: MD5 Hash: 6be140480cdf37bcb2f8a2e1f06a49f7, Perms: 755, User: sinusbot
 - Version: 1.0.0-alpha.5-9767656
   - Bot Plugin: 59d8f8244535ab73f5fcf321a5a404bf
   - TS3 Client: 59d8f8244535ab73f5fcf321a5a404bf
   - TS3Path = teamspeak/ts3client_linux_amd64 (Version 3.1.8)
   - YoutubeDLPath = /bin/youtube-dl (does exist, version: 2019.02.18)
 - Installed scripts: Bad_Nickname_Check.js; Jail.js; Lauftext__Ticker__APINewsticker_Support.js; Reconnect.js; Server_Join_Alert.js; advertising.js; alarm.js; alonemode.js; antiptoxy.js; bookmark.js; command.js; followme.js; messagetogroup.js; norecording.js; pm_to_all.js; rememberChannel.js; sconomy-ng-auc.js; sconomy-ng-wof.js; sconomy-ng.js; voicefaq.js; welcome.js; welcomettsmessage.js
 - Time (local): 23.02.2019 22:53:18 CET +01:00:00
 - Timezone: Europe/Warsaw
 - TeamSpeak 3 Version: 3.1.8
 - youtube-dl Version: 2019.02.18
 - DiagScript Version: 0.7.1
I would need the first lines after the crash and not the last ones to be able to debug it - but there's a known crashbug and I do hope it's the same as I'm currently investigating on that one ;)
Thanks for reporting though!
Though probably not directly related to the crash, I'd like to point out two things:
Admittedly updates can mess up things that were running smoothly, but it can be also the cause of new crashes. In your case, Sinusbot and yt-dl are most recent, your teamspeak client and some OS updates are outdated.
You should definitely get TS 3.2.3 in my opinion!
zmechu
Is there a way to get first lines of crash? Lines I've put here is only ones I see at "screen". There is no other debug in a log. How to get all crash lines?
Edit:
got a little more data:
        :22 +0x4d
(0xc4203b5440, 0x0, 0x0, 0x0)
        :115 +0x2b
(0xc420380420, 0x0, 0x0)
        :435 +0x62
(0xc4203fa580, 0x0, 0x0)
        :2530 +0x228b
        :2197 +0x1
goroutine 215 [IO wait]:
(0x1f13388, 0x7f2659cd1aa8, 0x1e13eee, 0x7, 0x889a1b, 0x5)
        :271 +0x13a
(0x7f2659cd1a80, 0x72, 0xb)
        :345 +0xc7
(0x7f2659cd1a80, 0x72, 0x12)
        :164 +0x59
(0xc4201d5e28, 0x72, 0x28fc660, 0x28f6ad0)
        :75 +0x38
(0xc4201d5e28, 0xc4203ae188, 0x4)
        :80 +0x34
(0xc4201d5dc0, 0xc4203ae188, 0x4, 0x4, 0x0, 0x28fc660, 0x28f6ad0)
        :250 +0x1b7
(0xc42007d750, 0xc4203ae188, 0x4, 0x4, 0x0, 0x0, 0x0)
        :181 +0x70
(0x7f2659ce4b48, 0xc42007d750, 0xc4203ae188, 0x4, 0x4, 0x4, 0x1dedc20, 0x0, 0x7f2659ce4b48)
        :307 +0xa9
(0x7f2659ce4b48, 0xc42007d750, 0xc4203ae188, 0x4, 0x4, 0x0, 0x0, 0x5c0000)
        :325 +0x58
(0xc420610600, 0x0)
        :785 +0x36b7
        :2197 +0x1
goroutine 214 [syscall]:
(0x0, 0x11, 0xc4206160ce, 0xf32, 0x67, 0xf99, 0x0)
        :18 +0x5
(0x11, 0xc4206160ce, 0xf32, 0xf32, 0x67, 0x0, 0x0)
        :783 +0x55
        :162 +0x49
(0xc42007d720, 0xc4206160ce, 0xf32, 0xf32, 0x67, 0x0, 0x0)
        :165 +0x4f
(0xc42007d720, 0xc4206160ce, 0xf32, 0xf32, 0x973f7e, 0xc420616067, 0x100000000000067)
        :101 +0x76
(0xc4205ac520, 0xc4206160ce, 0xf32, 0xf32, 0x67, 0xc420616067, 0x66)
        :26 +0xcf
(0xc420375f28, 0x66)
        :207 +0x294
(0x28fe9a0, 0xc42007d720, 0x28fe9a0, 0xc42007d730, 0xc4203fa000)
        :2503 +0x171
        :2197 +0x1
goroutine 213 [select]:
        :271 +0x13a
(0xc4205f8ef8, 0x0, 0x18)
        :423 +0x1364
(0xc4205f8ef8)
        :238 +0x1c
(0xc420262740, 0xc4203fa000, 0xc420262700, 0xc420610540)
        :2383 +0x32b
        :2197 +0x1
goroutine 380 [chan receive]:
(0x1f133c0, 0xc420610ad8, 0x1e193d6, 0xc, 0x17, 0x3)
        :271 +0x13a
(0xc420610ad8, 0x1e193d6, 0xc, 0xc4205f8717, 0x3)
        :277 +0x5e
(0x1d08500, 0xc420610a80, 0xc4205f87c0, 0x1, 0x0)
        :513 +0x371
(0x1d08500, 0xc420610a80, 0xc4205f87c0, 0x839126)
        :400 +0x35
(0xc4200dbd60)
        :837 +0x4a
        :2197 +0x1
goroutine 379 [IO wait]:
(0x1f13388, 0x7f2659cd11a8, 0x1e13eee, 0x7, 0x889a1b, 0x5)
        :271 +0x13a
(0x7f2659cd1180, 0x72, 0xb)
        :345 +0xc7
(0x7f2659cd1180, 0x72, 0x25)
        :164 +0x59
(0xc4201d4768, 0x72, 0x28fc660, 0x28f6ad0)
        :75 +0x38
(0xc4201d4768, 0xc420216378, 0x4)
        :80 +0x34
(0xc4201d4700, 0xc420216378, 0x4, 0x4, 0x0, 0x28fc660, 0x28f6ad0)
        :250 +0x1b7
(0xc42000e020, 0xc420216378, 0x4, 0x4, 0x0, 0x0, 0x0)
        :181 +0x70
(0x7f2659ce4b48, 0xc42000e020, 0xc420216378, 0x4, 0x4, 0x4, 0x1dedc20, 0x0, 0x7f2659ce4b48)
        :307 +0xa9
(0x7f2659ce4b48, 0xc42000e020, 0xc420216378, 0x4, 0x4, 0x0, 0x0, 0x5c0000)
        :325 +0x58
(0xc4200870e0, 0x5)
        :785 +0x36b7
        :2197 +0x1
goroutine 378 [runnable]:
(0x1f13388, 0x7f2659cd1268, 0x1e13eee, 0x7, 0x889a1b, 0x5)
        :271 +0x13a
(0x7f2659cd1240, 0x72, 0xb)
        :345 +0xc7
(0x7f2659cd1240, 0x72, 0x24)
        :164 +0x59
(0xc4201d4538, 0x72, 0x28fc660, 0x28f6ad0)
        :75 +0x38
(0xc4201d4538, 0xc4200115f8, 0x4)
        :80 +0x34
(0xc4201d44d0, 0xc4200115f8, 0x4, 0x4, 0x0, 0x28fc660, 0x28f6ad0)
        :250 +0x1b7
(0xc42000e008, 0xc4200115f8, 0x4, 0x4, 0x0, 0x0, 0x0)
        :181 +0x70
(0x7f2659ce4b48, 0xc42000e008, 0xc4200115f8, 0x4, 0x4, 0x4, 0x1dedc20, 0x0, 0x7f2659ce4b48)
        :307 +0xa9
(0x7f2659ce4b48, 0xc42000e008, 0xc4200115f8, 0x4, 0x4, 0x0, 0x0, 0x5c0000)
        :325 +0x58
(0xc420087020, 0x4)
        :785 +0x36b7
        :2197 +0x1
goroutine 377 [select, locked to thread]:
        :271 +0x13a
(0xc4202bff50, 0x0, 0x18)
        :423 +0x1364
(0xc4202bff50)
        :238 +0x1c
        :434 +0x2dd
        :2197 +0x1
goroutine 376 [semacquire]:
(0x1f133c0, 0x29374a0, 0x1e17c3f, 0xa, 0xc4202bc719, 0x4)
        :271 +0x13a
(0x29374a0, 0x1e17c3f, 0xa, 0xc4202bc619, 0x4)
        :277 +0x5e
(0xc4202654fc, 0x1)
        :130 +0x251
(0xc4202654fc)
        :47 +0x34
(0xc4202654f0)
        :131 +0x7a
(0xc4202654f0, 0x1f12b70, 0xc42007c568)
        :18 +0x46
(0xc420086a80, 0xc420086ae0)
        :1164 +0xca
        :2197 +0x1
goroutine 375 [chan receive]:
(0x1f133c0, 0xc4200863b8, 0x1e193d6, 0xc, 0x17, 0x3)
        :271 +0x13a
(0xc4200863b8, 0x1e193d6, 0xc, 0x17, 0x3)
        :277 +0x5e
(0x1d07a40, 0xc420086360, 0xc42038f7a0, 0xc420086301, 0x206)
        :513 +0x371
(0x1d07a40, 0xc420086360, 0xc42038f7a0, 0x0)
        :400 +0x35
(0xc420074b40, 0x1f12b58, 0x0)
        :1082 +0x7b
        :2197 +0x1
goroutine 372 [IO wait]:
(0x1f13388, 0x7f2659cd1868, 0x1e13eee, 0x7, 0x889a1b, 0x5)
        :271 +0x13a
(0x7f2659cd1840, 0x72, 0xb)
        :345 +0xc7
(0x7f2659cd1840, 0x72, 0x20)
        :164 +0x59
(0xc420219178, 0x72, 0x28fc660, 0x28f6ad0)
        :75 +0x38
(0xc420219178, 0xc4202d4740, 0x4)
        :80 +0x34
(0xc420219110, 0xc4202d4740, 0x4, 0x4, 0x0, 0x28fc660, 0x28f6ad0)
        :250 +0x1b7
(0xc42007cdf8, 0xc4202d4740, 0x4, 0x4, 0x0, 0x0, 0x0)
        :181 +0x70
(0x7f2659ce4b48, 0xc42007cdf8, 0xc4202d4740, 0x4, 0x4, 0x4, 0x1dedc20, 0x0, 0x7f2659ce4b48)
        :307 +0xa9
(0x7f2659ce4b48, 0xc42007cdf8, 0xc4202d4740, 0x4, 0x4, 0x0, 0x0, 0x5c0000)
        :325 +0x58
(0xc42046c0c0, 0x3)
        :785 +0x36b7
        :2197 +0x1
goroutine 371 [syscall]:
(0x0, 0x1f, 0xc42061712b, 0xed5, 0x5d, 0xf32, 0x0)
        :18 +0x5
(0x1f, 0xc42061712b, 0xed5, 0xed5, 0x5d, 0x0, 0x0)
        :783 +0x55
        :162 +0x49
(0xc42007cdc8, 0xc42061712b, 0xed5, 0xed5, 0x5d, 0x0, 0x0)
        :165 +0x4f
(0xc42007cdc8, 0xc42061712b, 0xed5, 0xed5, 0x973f7e, 0xc4206170ce, 0x10000000000005d)
        :101 +0x76
(0xc42029e5c0, 0xc42061712b, 0xed5, 0xed5, 0x5d, 0xc4206170ce, 0x5c)
        :26 +0xcf
(0xc4204d0f28, 0x5c)
        :207 +0x294
(0x28fe9a0, 0xc42007cdc8, 0x28fe9a0, 0xc42007cdd8, 0xc4203fa580)
        :2503 +0x171
        :2197 +0x1
goroutine 370 [select]:
        :271 +0x13a
(0xc4206056f8, 0x0, 0x18)
        :423 +0x1364
(0xc4206056f8)
        :238 +0x1c
(0xc4202dd740, 0xc4203fa580, 0xc4202dd700, 0xc42039fec0)
        :2383 +0x32b
        :2197 +0x1
rax    0x0
rbx    0x21bd5d8
rcx    0xb40
rdx    0x0
rdi    0x7f2657994520
rsi    0x7f2657995750
rbp    0x7f262affc120
rsp    0x7f262affbe18
r8     0x7f2657995750
r9     0x7f262affd700
r10    0x0
r11    0x0
r12    0x2259353
r13    0x0
r14    0x7f262affc4a8
r15    0x7f26500f21e0
rip    0x13280f9
rflags 0x10202
cs     0x33
fs     0x0
gs     0x0
and kernel log:
kernel: [2518188.418307]  in ts_core_errors.qm[7fdc5471a000+6000] in ts_core_errors.qm[7f459e68a000+6000]<6>[2518713.854535] QXcbEventReader[20793]: segfault at 7f30557cde45 ip 00007f30557cde45 sp 00007f3054a91cf0 error 14 in LC_CTYPE[7f30558d8000+51000]
after update system and teamspeak client:
 - Operating System: Debian GNU/Linux 9.8 (stretch)
 - Load Average: 0.08 0.07 0.13
 - Uptime: 29 days, 3 hours, 45 minutes, 21 seconds
 - OS Updates: 4 (updates available!)
 - OS APT Last Update: 24.02.2019 19:31:05 CET +01:00:00
    CPU(s):                2
    Socket(s):             2
    CPU MHz:               2199.998
 - RAM: 761.82 MB/3.86 GB in use (19%)
 - DISK: 13.05 GB/49.18 GB in use (26%)
   + libglib: 2.50.3-2
 - Webinterface: port locally not reachable (Port: 5003)
   - TS3Path = teamspeak/ts3client_linux_amd64 (Version 3.2.3)
 - Time (local): 24.02.2019 19:59:42 CET +01:00:00
 - TeamSpeak 3 Version: 3.2.3
when starting with screen add the -L parameter this will log everything from the screen session into a file, alternatively you can use "CTRL + A" then "ESC" to detatch the cursor and be able to move up and down with the arrow keys
zmechu
Done, here is full crash log from "screen":
2019/02/24 20:04:23 5eba667e 106c621f INFO PRIVATE-CHAT [zmechu] kolo
# Fatal error in , line 0
# Failed to create ICU date format, are ICU data files missing?
#FailureMessage Object: 0x7fdac47f6e40
==== C stack trace ===============================
./sinusbot(v8::base::debug::StackTrace::StackTrace()+0x16) [0x1329d76]
./sinusbot() [0xf6fe67]
./sinusbot(V8_Fatal(char const, int, char const, ...)+0x14d) [0x132e9fd]
./sinusbot() [0x1595c45]
./sinusbot(v8::internal::Runtime_CreateDateTimeFormat(int, v8::internal::Object*, v8::internal::Isolate)+0x158) [0x14a53f8]
[0x380f7bcdc2d8]
SIGILL: illegal instruction
PC=0x13280f9 m=30 sigcode=2
signal arrived during cgo execution
goroutine 14606 [syscall, locked to thread]:
(0xe90b70, 0xc420545c70, 0x1e34407)
:131 +0xe2 fp=0xc420545c30 sp=0xc420545bf0
(0x7fdaf0095510, 0x7fdaf0095360, 0x0, 0x1, 0xc424f7f0f0, 0x7fdaf0005a80, 0x0, 0x0, 0x0, 0x0)
:603 +0x6f fp=0xc420545c70 sp=0xc420545c30
(0xc424f7f0f0, 0x2, 0x2, 0x7fdaf0095510, 0x7fdaf0095360, 0x0, 0x7fdb00000001, 0xc424f7f0f0, 0x7fdaf0005a80, 0x0, ...)
:763 +0x246 fp=0xc420545d10 sp=0xc420545c70
(0xc4203a4da0, 0x0, 0xc424f68320, 0x1, 0x1, 0x0, 0x0, 0xc420051858)
:763 +0x177 fp=0xc420545dd0 sp=0xc420545d10
(0xc424f7e980, 0x1, 0x1, 0x0)
:1524 +0x24e fp=0xc420545eb8 sp=0xc420545dd0
(0xc4203b0180, 0x1e10fc2, 0x4, 0xc424f7e980, 0x1, 0x1)
:740 +0x14f fp=0xc420545fb0 sp=0xc420545eb8
:2197 +0x1 fp=0xc420545fb8 sp=0xc420545fb0
created by
:743 +0x71
goroutine 1 [select (no cases)]:
(0x0, 0x0, 0x1e1e8c9, 0x11, 0xc420233310, 0x1)
:271 +0x13a
:224 +0x56
:1181 +0x253c
:185 +0x20a
:2197 +0x1
goroutine 17 [syscall, locked to thread]:
:2197 +0x1
goroutine 5 [syscall]:
(0x295ed20, 0xffffffffffffffff, 0x0)
:205 +0x42
(0x0)
:116 +0x104
:22 +0x22
:2197 +0x1
goroutine 375 [semacquire]:
(0x1f133c0, 0x29381e0, 0x1e17c3f, 0xa, 0xc420051919, 0x4)
:271 +0x13a
(0x29381e0, 0x1e17c3f, 0xa, 0xc420022619, 0x4)
:277 +0x5e
(0xc4203de67c, 0x1)
:130 +0x251
(0xc4203de67c)
:47 +0x34
(0xc4203de670)
:131 +0x7a
(0xc4203de670, 0x1f12b70, 0xc42000e088)
:18 +0x46
(0xc4203b06c0, 0xc4203b0720)
:1164 +0xca
:2197 +0x1
goroutine 18 [IO wait]:
(0x1f13388, 0x7fdb0b3bef98, 0x1e13eee, 0x7, 0xc420033d1b, 0x5)
:271 +0x13a
(0x7fdb0b3bef70, 0x72, 0x28fc660)
:345 +0xc7
:164 +0x59
(0xc4202112c8, 0x72, 0x28f6ad0, 0xc42020c5a0)
:75 +0x38
(0xc4202112c8, 0xffffffffffffffff, 0x0)
:80 +0x34
(0xc420211260, 0x0, 0x28fa8e0, 0xc42020c5a0)
:430 +0x1e5
(0xc4201ee9c0, 0xc420033e98, 0xced759, 0x8357a0)
:162 +0x32
(0xc4201ee9c0, 0x1f12460, 0xc420387140, 0x5, 0xc42040c1b0)
:237 +0x49
:1420 +0x102
:2197 +0x1
goroutine 19 [chan receive]:
(0x1f133c0, 0xc420237138, 0x1e193d6, 0xc, 0x17, 0x3)
:271 +0x13a
(0xc420237138, 0x1e193d6, 0xc, 0x17, 0x3)
:277 +0x5e
(0x1d08500, 0xc4202370e0, 0xc42001cfc0, 0x1, 0x0)
:513 +0x371
(0x1d08500, 0xc4202370e0, 0xc42001cfc0, 0x0)
:400 +0x35
(0xc42027f220)
:837 +0x4a
:2197 +0x1
(0x0, 0x1f, 0xc4204ee5b3, 0xa4d, 0x5d, 0xaaa, 0x0)
:18 +0x5
(0x1f, 0xc4204ee5b3, 0xa4d, 0xa4d, 0x5d, 0x0, 0x0)
:783 +0x55
:162 +0x49
(0xc42022adb0, 0xc4204ee5b3, 0xa4d, 0xa4d, 0x5d, 0x0, 0x0)
:165 +0x4f
(0xc42022adb0, 0xc4204ee5b3, 0xa4d, 0xa4d, 0x973f7e, 0xc4204ee556, 0x10000000000005d)
:101 +0x76
(0xc42020d4a0, 0xc4204ee5b3, 0xa4d, 0xa4d, 0x5d, 0xc4204ee556, 0x5c)
:26 +0xcf
(0xc420384f28, 0x5c)
:207 +0x294
(0x28fe9a0, 0xc42022adb0, 0x28fe9a0, 0xc42022adc0, 0xc42026d8c0)
:2503 +0x171
:2197 +0x1
goroutine 386 [runnable]:
(0x0, 0x23, 0xc42455e000, 0x4, 0x4, 0x4, 0x0)
:18 +0x5
(0x23, 0xc42455e000, 0x4, 0x5c0000, 0x72, 0x0, 0x0)
:783 +0x55
(0x23, 0xc42455e000, 0x4, 0x5c0000, 0x8124ee, 0xc420255040, 0x200000003)
:162 +0x49
(0xc4202003f0, 0xc42455e000, 0x4, 0x5c0000, 0x0, 0x0, 0x0)
:246 +0x13b
(0xc42022a020, 0xc42455e000, 0x4, 0x5c0000, 0x0, 0x0, 0x0)
:181 +0x70
(0x7fdb0b38b9a8, 0xc42022a020, 0xc42455e000, 0x4, 0x5c0000, 0x4, 0x1dedc20, 0xc420224700, 0x7fdb0b38b9a8)
:307 +0xa9
(0x7fdb0b38b9a8, 0xc42022a020, 0xc42455e000, 0x4, 0x5c0000, 0x0, 0x20, 0xc4203c8ee0)
:325 +0x58
(0xc420387140, 0x4, 0xc42455e000, 0x5c0000, 0x5c0000, 0x4, 0x0, 0x0)
:476 +0xf2
(0xc420387140, 0x5)
:812 +0x37c7
:2197 +0x1
goroutine 7 [chan receive]:
(0x1f133c0, 0xc4203865f8, 0x1e193d6, 0xc, 0xc4202ecb17, 0x3)
:271 +0x13a
(0xc4203865f8, 0x1e193d6, 0xc, 0x17, 0x3)
:277 +0x5e
(0x1d07a40, 0xc4203865a0, 0x0, 0xc420386501, 0x0)
:513 +0x371
(0x1d07a40, 0xc4203865a0, 0x0)
:395 +0x35
(0xc4202b2260, 0x20, 0x20, 0xc4202b2240, 0x20, 0x20)
:931 +0x70
:2197 +0x1
goroutine 8 [chan receive]:
(0x1f133c0, 0xc42005b0d8, 0x1e193d6, 0xc, 0xc4202ecb17, 0x3)
:271 +0x13a
(0xc42005b0d8, 0x1e193d6, 0xc, 0x17, 0x3)
:277 +0x5e
(0x1d08500, 0xc42005b080, 0xc42001efc0, 0x1, 0x0)
:513 +0x371
(0x1d08500, 0xc42005b080, 0xc42001efc0, 0xc420010260)
:400 +0x35
(0xc4202143c0)
:837 +0x4a
:2197 +0x1
goroutine 28 [IO wait]:
(0x1f13388, 0x7fdb0b3bee18, 0x1e13eee, 0x7, 0x889a1b, 0x5)
:271 +0x13a
(0x7fdb0b3bedf0, 0x72, 0xb)
:345 +0xc7
(0x7fdb0b3bedf0, 0x72, 0x7)
:164 +0x59
(0xc420211488, 0x72, 0x28fc660, 0x28f6ad0)
:75 +0x38
(0xc420211488, 0xc4202d6000, 0x2000)
:80 +0x34
(0xc420211420, 0xc4202d6000, 0x2000, 0x2000, 0x0, 0x28fc660, 0x28f6ad0)
:250 +0x1b7
(0xc42022a210, 0xc4202d6000, 0x2000, 0x2000, 0x0, 0x0, 0x0)
:181 +0x70
(0xc4202c6420, 0x7fdb0b376380, 0xc42022a210, 0x5, 0xc42022a210, 0xc420045870)
:488 +0x98
(0xc4202d4000, 0x1f13517, 0xc4202d4120, 0x835040)
:590 +0xc4
(0xc4202d4000, 0xc4202c9000, 0x1000, 0x1000, 0x0, 0x0, 0x0)
:1134 +0x11d
(0xc420259680, 0xc4202c9000, 0x1000, 0x1000, 0x5, 0x833140, 0xc42005af00)
:1316 +0x14b
(0xc420386420)
:97 +0x117
(0xc420386420, 0x1, 0xc420045be5, 0x1, 0x0, 0xc420386480, 0x0)
:129 +0x67
(0xc420259680)
:1474 +0x196
:2197 +0x1
goroutine 29 [select]:
:271 +0x13a
(0xc42002ff48, 0x0, 0x18)
:423 +0x1364
(0xc42002ff48)
:238 +0x1c
(0xc420259680)
:1704 +0x43a
:2197 +0x1
goroutine 376 [select, locked to thread]:
:271 +0x13a
(0xc4205b8f50, 0x0, 0x18)
:423 +0x1364
(0xc4205b8f50)
:238 +0x1c
:434 +0x2dd
:2197 +0x1
:271 +0x13a
(0xc420022ef8, 0x0, 0x18)
:423 +0x1364
(0xc420022ef8)
:238 +0x1c
(0xc420015380, 0xc42026d8c0, 0xc420015300, 0xc4205acf60)
:2383 +0x32b
:2197 +0x1
goroutine 378 [chan receive]:
(0x1f133c0, 0xc4203b0778, 0x1e193d6, 0xc, 0xc420051a17, 0x3)
:271 +0x13a
(0xc4203b0778, 0x1e193d6, 0xc, 0x17, 0x3)
:277 +0x5e
(0x1d07d80, 0xc4203b0720, 0x0, 0x10001, 0xc4203de690)
:513 +0x371
(0x1d07d80, 0xc4203b0720, 0x0)
:395 +0x35
(0xc42000e088, 0xc4203b06c0, 0xc4203b0720)
:1161 +0x17d
:2197 +0x1
goroutine 379 [chan receive]:
(0x1f133c0, 0xc420607618, 0x1e193d6, 0xc, 0xc42576f017, 0x3)
:271 +0x13a
(0xc420607618, 0x1e193d6, 0xc, 0xc420023f17, 0x3)
:277 +0x5e
(0x1d08500, 0xc4206075c0, 0xc420023fc0, 0x1, 0x0)
:513 +0x371
(0x1d08500, 0xc4206075c0, 0xc420023fc0, 0x839126)
:400 +0x35
(0xc4200cbd60)
:837 +0x4a
:2197 +0x1
goroutine 377 [chan receive]:
(0x1f133c0, 0xc4203b0718, 0x1e193d6, 0xc, 0x17, 0x3)
:271 +0x13a
(0xc4203b0718, 0x1e193d6, 0xc, 0x17, 0x3)
:277 +0x5e
(0x1d084c0, 0xc4203b06c0, 0xc42038af70, 0x1, 0x1)
:513 +0x371
(0x1d084c0, 0xc4203b06c0, 0xc42038af70, 0xc4203878c0)
:400 +0x35
:1172 +0x68
:2197 +0x1
(0x1f13388, 0x7fdb0b3be2d8, 0x1e13eee, 0x7, 0xc4205cf21b, 0x5)
:271 +0x13a
(0x7fdb0b3be2b0, 0x72, 0x28fc660)
:345 +0xc7
:164 +0x59
(0xc4202113a8, 0x72, 0x28f6ad0, 0xc4250e5e60)
:75 +0x38
(0xc4202113a8, 0xffffffffffffffff, 0x0)
:80 +0x34
(0xc420211340, 0x0, 0x28fa8e0, 0xc4250e5e60)
:430 +0x1e5
(0xc42022a488, 0xc4205cf3b8, 0x7e0abb, 0xc4205cf3b8)
:136 +0x2e
(0xc42022a488, 0xffffffffffffffff, 0xc4250dac01, 0x7ef428)
:215 +0x49
(0xc42022a488, 0x8357a0, 0xc4205cf450, 0xc4205cf458, 0xc4205cf448)
:713 +0x2f
(0xc42022a490, 0x1f12d88, 0xc425f18aa0, 0x29019e0, 0xc42060b350)
:104 +0x4d
(0xc42044b810, 0x29006a0, 0xc42022a490, 0x0, 0x0)
:2643 +0x228
(0xc4206051e0, 0xc42044b810, 0xc42029be70, 0xc)
:646 +0x402
(0xc4206051e0, 0xc42029be70, 0xc, 0x1e10238, 0x1)
:587 +0x53
:880 +0x5f35
:2197 +0x1
goroutine 61 [select]:
:271 +0x13a
(0xc4205bdf38, 0x0, 0x18)
:423 +0x1364
(0xc4205bdf38)
:238 +0x1c
(0xc420200d20, 0xc4200c7080, 0xc4205ac600)
:488 +0x1bf
:2197 +0x1
goroutine 60 [syscall]:
(0xf7, 0x1, 0x5602, 0xc42022e6f8, 0x1000004, 0x0, 0x0, 0x0, 0x60, 0xc4206140c0)
:44 +0x5
(0xc42060b380, 0xc4206140c0, 0x4, 0x3)
:28 +0xa5
(0xc42060b380, 0xc420016068, 0xc420016000, 0xc42060b260)
:22 +0x4d
(0xc42060b380, 0x0, 0x0, 0x0)
:115 +0x2b
(0xc4202742c0, 0x0, 0x0)
:435 +0x62
(0xc4200c7080, 0x0, 0x0)
:2530 +0x228b
:2197 +0x1
goroutine 62 [IO wait]:
(0x1f13388, 0x7fdb0b3bec98, 0x1e13eee, 0x7, 0x889a1b, 0x5)
:271 +0x13a
(0x7fdb0b3bec70, 0x72, 0xb)
:345 +0xc7
(0x7fdb0b3bec70, 0x72, 0xf)
:164 +0x59
(0xc420200ca8, 0x72, 0x28fc660, 0x28f6ad0)
:75 +0x38
(0xc420200ca8, 0xc4205be000, 0x4)
:80 +0x34
(0xc420200c40, 0xc4205be000, 0x4, 0x10000, 0x0, 0x28fc660, 0x28f6ad0)
:250 +0x1b7
(0xc42000e100, 0xc4205be000, 0x4, 0x10000, 0x0, 0x0, 0x0)
:181 +0x70
(0xc4205ac660, 0xc4205be000, 0x4, 0x10000, 0xc420014080, 0x7fdb0b4164b0, 0x0)
:79 +0x7f
(0x28f8d20, 0xc4205ac660, 0xc4205be000, 0x4, 0x10000, 0x4, 0xc4203aaec8, 0xc4203aaec0, 0xc420014080)
:307 +0xa9
(0x28f8d20, 0xc4205ac660, 0xc4205be000, 0x4, 0x10000, 0x10000, 0xc4203aafb0, 0xc15f40)
:325 +0x58
(0xc4200c7080, 0xc4205ac660)
:514 +0xf1
:2197 +0x1
goroutine 63 [IO wait]:
(0x1f13388, 0x7fdb0b3beed8, 0x1e13eee, 0x7, 0x889a1b, 0x5)
:271 +0x13a
(0x7fdb0b3beeb0, 0x72, 0xb)
:345 +0xc7
:164 +0x59
(0xc420200bc8, 0x72, 0x28fc660, 0x28f6ad0)
:75 +0x38
(0xc420200bc8, 0xc4205d6000, 0x4)
:80 +0x34
(0xc420200b60, 0xc4205d6000, 0x4, 0x10000, 0x0, 0x28fc660, 0x28f6ad0)
:250 +0x1b7
(0xc42000e0e0, 0xc4205d6000, 0x4, 0x10000, 0x0, 0x0, 0x0)
:181 +0x70
(0xc4205ac600, 0xc4205d6000, 0x4, 0x10000, 0x4ca, 0xc426a8aa00, 0x4ca)
:79 +0x7f
(0x28f8d20, 0xc4205ac600, 0xc4205d6000, 0x4, 0x10000, 0x4, 0x4ca, 0x4ca, 0xc426a8aa00)
:307 +0xa9
(0x28f8d20, 0xc4205ac600, 0xc4205d6000, 0x4, 0x10000, 0x4ca, 0x0, 0x0)
:325 +0x58
(0xc4200c7080, 0xc4205ac600, 0xc420224aa0)
:581 +0x11c
:2197 +0x1
goroutine 76 [IO wait]:
(0x1f13388, 0x7fdb0b3beb18, 0x1e13eee, 0x7, 0x889a1b, 0x5)
:271 +0x13a
(0x7fdb0b3beaf0, 0x72, 0xb)
:345 +0xc7
(0x7fdb0b3beaf0, 0x72, 0x12)
:164 +0x59
(0xc42004f178, 0x72, 0x28fc660, 0x28f6ad0)
:75 +0x38
(0xc42004f178, 0xc420010368, 0x4)
:80 +0x34
(0xc42004f110, 0xc420010368, 0x4, 0x4, 0x0, 0x28fc660, 0x28f6ad0)
:250 +0x1b7
(0xc42022ac60, 0xc420010368, 0x4, 0x4, 0x0, 0x0, 0x0)
:181 +0x70
(0x7fdb0b38b9a8, 0xc42022ac60, 0xc420010368, 0x4, 0x4, 0x4, 0x1dedc20, 0x0, 0x7fdb0b38b9a8)
:307 +0xa9
(0x7fdb0b38b9a8, 0xc42022ac60, 0xc420010368, 0x4, 0x4, 0x0, 0x0, 0x5c0000)
:325 +0x58
(0xc4204f09c0, 0x0)
:785 +0x36b7
:2197 +0x1
goroutine 66 [select]:
:271 +0x13a
(0xc420035e60, 0x0, 0x18)
:423 +0x1364
(0xc420035e60)
:238 +0x1c
(0xc4203d8500, 0xc420286090, 0xc420256000, 0xc4203de0d0, 0xc4203de0bc, 0xc4203de0f0, 0xc4203de0d8, 0xc4203de0b8, 0xc4203de0f8, 0xc4202860c0, ...)
:263 +0x2bf7
:2197 +0x1
goroutine 77 [IO wait]:
(0x1f13388, 0x7fdb0b3bea58, 0x1e13eee, 0x7, 0x889a1b, 0x5)
:271 +0x13a
(0x7fdb0b3bea30, 0x72, 0xb)
:345 +0xc7
(0x7fdb0b3bea30, 0x72, 0x14)
:164 +0x59
(0xc42004e458, 0x72, 0x28fc660, 0x28f6ad0)
:75 +0x38
(0xc42004e458, 0xc420010588, 0x4)
:80 +0x34
(0xc42004e3f0, 0xc420010588, 0x4, 0x4, 0x0, 0x28fc660, 0x28f6ad0)
:250 +0x1b7
(0xc42000e008, 0xc420010588, 0x4, 0x4, 0x0, 0x0, 0x0)
:181 +0x70
(0x7fdb0b38b9a8, 0xc42000e008, 0xc420010588, 0x4, 0x4, 0x4, 0x1dedc20, 0x0, 0x7fdb0b38b9a8)
:307 +0xa9
(0x7fdb0b38b9a8, 0xc42000e008, 0xc420010588, 0x4, 0x4, 0x0, 0x0, 0x5c0000)
:325 +0x58
(0xc420256180, 0x1)
:785 +0x36b7
:2197 +0x1
goroutine 31 [select]:
:271 +0x13a
(0xc420031e60, 0x0, 0x18)
:423 +0x1364
(0xc420031e60)
:238 +0x1c
(0xc4203d8000, 0xc4202c7650, 0xc420386600, 0xc4202e9950, 0xc4202e994c, 0xc4202e9960, 0xc4202e9958, 0xc4202e9948, 0xc4202e9968, 0xc4202c7680, ...)
:263 +0x2bf7
:2197 +0x1
goroutine 30 [chan receive]:
(0x1f133c0, 0xc420386658, 0x1e193d6, 0xc, 0xc420018017, 0x3)
:271 +0x13a
(0xc420386658, 0x1e193d6, 0xc, 0x17, 0x3)
:277 +0x5e
(0x1d07fc0, 0xc420386600, 0xc4203a67b0, 0xc4203d8001, 0xc4203d8030)
:513 +0x371
(0x1d07fc0, 0xc420386600, 0xc4203a67b0, 0xc420071301)
:400 +0x35
(0xc420386600, 0xc4203d8000)
:147 +0x5a
:2197 +0x1
goroutine 51 [select]:
:271 +0x13a
(0xc420030ee0, 0x0, 0x18)
:423 +0x1364
(0xc420030ee0)
:238 +0x1c
(0xc4203bd860)
:183 +0xd8c
:2197 +0x1
goroutine 54 [select]:
:271 +0x13a
(0xc420385f30, 0x0, 0x18)
:423 +0x1364
(0xc420385f30)
:238 +0x1c
(0xc4202ad980, 0xc4202ecf00, 0xc4203b1260, 0xc4202372c0)
:588 +0x200
:2197 +0x1
goroutine 55 [select]:
:271 +0x13a
(0xc42002ef30, 0x0, 0x18)
:423 +0x1364
(0xc42002ef30)
:238 +0x1c
(0xc4202adb00, 0xc4202ed310, 0xc4203b1260, 0xc420237bc0)
:588 +0x200
:2197 +0x1
goroutine 33 [chan receive]:
(0x1f133c0, 0xc420256058, 0x1e193d6, 0xc, 0xc420051117, 0x3)
:271 +0x13a
(0xc420256058, 0x1e193d6, 0xc, 0xc420239317, 0x3)
:277 +0x5e
(0x1d07fc0, 0xc420256000, 0xc42038f7b0, 0x1, 0x0)
:513 +0x371
(0x1d07fc0, 0xc420256000, 0xc42038f7b0, 0xc420239380)
:400 +0x35
(0xc420256000, 0xc4203d8500)
:147 +0x5a
:2197 +0x1
goroutine 57 [select]:
:271 +0x13a
(0xc420034ee0, 0x0, 0x18)
:423 +0x1364
(0xc420034ee0)
:238 +0x1c
(0xc420220c30)
:183 +0xd8c
:2197 +0x1
goroutine 67 [select]:
:271 +0x13a
(0xc420390730, 0x0, 0x18)
:423 +0x1364
(0xc420390730)
:238 +0x1c
(0xc4202add40, 0xc420051720, 0xc4203b0180, 0xc420257e00)
:588 +0x200
:2197 +0x1
goroutine 218 [syscall]:
(0x0, 0x11, 0xc4204ef0ce, 0xf32, 0x67, 0xf99, 0x0)
:18 +0x5
(0x11, 0xc4204ef0ce, 0xf32, 0xf32, 0x67, 0x0, 0x0)
:783 +0x55
:162 +0x49
(0xc42000eb28, 0xc4204ef0ce, 0xf32, 0xf32, 0x67, 0x0, 0x0)
:165 +0x4f
(0xc42000eb28, 0xc4204ef0ce, 0xf32, 0xf32, 0x973f7e, 0xc4204ef067, 0x100000000000067)
:101 +0x76
(0xc4205a7c20, 0xc4204ef0ce, 0xf32, 0xf32, 0x67, 0xc4204ef067, 0x66)
:26 +0xcf
(0xc42037ef28, 0x66)
:207 +0x294
(0x28fe9a0, 0xc42000eb28, 0x28fe9a0, 0xc42000eb38, 0xc4200c7080)
:2503 +0x171
:2197 +0x1
goroutine 217 [select]:
:271 +0x13a
(0xc4205f76f8, 0x0, 0x18)
:423 +0x1364
(0xc4205f76f8)
:238 +0x1c
(0xc420226a00, 0xc4200c7080, 0xc4202269c0, 0xc420614060)
:2383 +0x32b
:2197 +0x1
goroutine 78 [IO wait]:
(0x1f13388, 0x7fdb0b3be998, 0x1e13eee, 0x7, 0x889a1b, 0x5)
:271 +0x13a
(0x7fdb0b3be970, 0x72, 0xb)
:345 +0xc7
(0x7fdb0b3be970, 0x72, 0x15)
:164 +0x59
(0xc42004e848, 0x72, 0x28fc660, 0x28f6ad0)
:75 +0x38
(0xc42004e848, 0xc420224420, 0x4)
:80 +0x34
(0xc42004e7e0, 0xc420224420, 0x4, 0x4, 0x0, 0x28fc660, 0x28f6ad0)
:250 +0x1b7
(0xc42000e028, 0xc420224420, 0x4, 0x4, 0x0, 0x0, 0x0)
:181 +0x70
(0x7fdb0b38b9a8, 0xc42000e028, 0xc420224420, 0x4, 0x4, 0x4, 0x1dedc20, 0x0, 0x7fdb0b38b9a8)
:307 +0xa9
(0x7fdb0b38b9a8, 0xc42000e028, 0xc420224420, 0x4, 0x4, 0x0, 0x0, 0x5c0000)
:325 +0x58
(0xc420256240, 0x2)
:785 +0x36b7
:2197 +0x1
goroutine 80 [syscall]:
(0xf7, 0x1, 0x561d, 0xc4203646f8, 0x1000004, 0x0, 0x0, 0x0, 0x60, 0xc4205ad080)
:44 +0x5
(0xc4203a0d80, 0xc4205ad080, 0x4, 0x3)
:28 +0xa5
(0xc4203a0d80, 0xc420017368, 0xc420017300, 0xc4203a0c60)
:22 +0x4d
(0xc4203a0d80, 0x0, 0x0, 0x0)
:115 +0x2b
(0xc420274840, 0x0, 0x0)
:435 +0x62
(0xc42026d8c0, 0x0, 0x0)
:2530 +0x228b
:2197 +0x1
goroutine 374 [chan receive]:
(0x1f133c0, 0xc4203b06b8, 0x1e193d6, 0xc, 0xc420014317, 0x3)
:271 +0x13a
(0xc4203b06b8, 0x1e193d6, 0xc, 0x17, 0x3)
:277 +0x5e
(0x1d07a40, 0xc4203b0660, 0xc4205e97a0, 0xc4203b0601, 0x206)
:513 +0x371
(0x1d07a40, 0xc4203b0660, 0xc4205e97a0, 0x0)
:400 +0x35
(0xc4202ad100, 0x1f12b58, 0x0)
:1082 +0x7b
:2197 +0x1
goroutine 230 [select]:
:271 +0x13a
(0xc4205f3f38, 0x0, 0x18)
:423 +0x1364
(0xc4205f3f38)
:238 +0x1c
(0xc420200fc0, 0xc42026d8c0, 0xc42005b1a0)
:488 +0x1bf
:2197 +0x1
goroutine 231 [IO wait]:
(0x1f13388, 0x7fdb0b3be698, 0x1e13eee, 0x7, 0x889a1b, 0x5)
:271 +0x13a
(0x7fdb0b3be670, 0x72, 0xb)
:345 +0xc7
(0x7fdb0b3be670, 0x72, 0x1d)
:164 +0x59
(0xc420200ed8, 0x72, 0x28fc660, 0x28f6ad0)
:75 +0x38
(0xc420200ed8, 0xc42051a000, 0x4)
:80 +0x34
(0xc420200e70, 0xc42051a000, 0x4, 0x10000, 0x0, 0x28fc660, 0x28f6ad0)
:250 +0x1b7
(0xc42022a080, 0xc42051a000, 0x4, 0x10000, 0x0, 0x0, 0x0)
:181 +0x70
(0xc42005b2c0, 0xc42051a000, 0x4, 0x10000, 0xc4202ad240, 0x7fdb0b416000, 0x0)
:79 +0x7f
(0x28f8d20, 0xc42005b2c0, 0xc42051a000, 0x4, 0x10000, 0x4, 0xc4205f46c8, 0xc4205f46c0, 0xc4202ad240)
:307 +0xa9
(0x28f8d20, 0xc42005b2c0, 0xc42051a000, 0x4, 0x10000, 0x10000, 0x18, 0xc4205f47b0)
:325 +0x58
(0xc42026d8c0, 0xc42005b2c0)
:514 +0xf1
:2197 +0x1
goroutine 232 [IO wait]:
(0x1f13388, 0x7fdb0b3be818, 0x1e13eee, 0x7, 0x889a1b, 0x5)
:271 +0x13a
(0x7fdb0b3be7f0, 0x72, 0xb)
:345 +0xc7
(0x7fdb0b3be7f0, 0x72, 0x19)
:164 +0x59
(0xc420200a78, 0x72, 0x28fc660, 0x28f6ad0)
:75 +0x38
(0xc420200a78, 0xc420566000, 0x4)
:80 +0x34
(0xc420200a10, 0xc420566000, 0x4, 0x10000, 0x0, 0x28fc660, 0x28f6ad0)
:250 +0x1b7
(0xc42022a060, 0xc420566000, 0x4, 0x10000, 0x0, 0x0, 0x0)
:181 +0x70
(0xc42005b1a0, 0xc420566000, 0x4, 0x10000, 0x28e, 0xc425333600, 0x28e)
:79 +0x7f
(0x28f8d20, 0xc42005b1a0, 0xc420566000, 0x4, 0x10000, 0x4, 0x28e, 0x28e, 0xc425333600)
:307 +0xa9
(0x28f8d20, 0xc42005b1a0, 0xc420566000, 0x4, 0x10000, 0x28e, 0x0, 0x0)
:325 +0x58
(0xc42026d8c0, 0xc42005b1a0, 0xc420011fe0)
:581 +0x11c
:2197 +0x1
goroutine 224 [IO wait]:
(0x1f13388, 0x7fdb0b3be8d8, 0x1e13eee, 0x7, 0x889a1b, 0x5)
:271 +0x13a
(0x7fdb0b3be8b0, 0x72, 0xb)
:345 +0xc7
(0x7fdb0b3be8b0, 0x72, 0x20)
:164 +0x59
(0xc42004f258, 0x72, 0x28fc660, 0x28f6ad0)
:75 +0x38
(0xc42004f258, 0xc420225ee0, 0x4)
:80 +0x34
(0xc42004f1f0, 0xc420225ee0, 0x4, 0x4, 0x0, 0x28fc660, 0x28f6ad0)
:250 +0x1b7
(0xc42000e110, 0xc420225ee0, 0x4, 0x4, 0x0, 0x0, 0x0)
:181 +0x70
(0x7fdb0b38b9a8, 0xc42000e110, 0xc420225ee0, 0x4, 0x4, 0x4, 0x1dedc20, 0x0, 0x7fdb0b38b9a8)
:307 +0xa9
(0x7fdb0b38b9a8, 0xc42000e110, 0xc420225ee0, 0x4, 0x4, 0x0, 0x0, 0x5c0000)
:325 +0x58
(0xc420256ae0, 0x3)
:785 +0x36b7
:2197 +0x1
goroutine 225 [IO wait]:
(0x1f13388, 0x7fdb0b3be458, 0x1e13eee, 0x7, 0x889a1b, 0x5)
:271 +0x13a
(0x7fdb0b3be430, 0x72, 0xb)
:345 +0xc7
(0x7fdb0b3be430, 0x72, 0x22)
:164 +0x59
(0xc42004f4f8, 0x72, 0x28fc660, 0x28f6ad0)
:75 +0x38
(0xc42004f4f8, 0xc420224298, 0x4)
:80 +0x34
(0xc42004f490, 0xc420224298, 0x4, 0x4, 0x0, 0x28fc660, 0x28f6ad0)
:250 +0x1b7
(0xc42000e118, 0xc420224298, 0x4, 0x4, 0x0, 0x0, 0x0)
:181 +0x70
(0x7fdb0b38b9a8, 0xc42000e118, 0xc420224298, 0x4, 0x4, 0x4, 0x1dedc20, 0x0, 0x7fdb0b38b9a8)
:307 +0xa9
(0x7fdb0b38b9a8, 0xc42000e118, 0xc420224298, 0x4, 0x4, 0x0, 0x0, 0x5c0000)
:325 +0x58
(0xc420256b40, 0x4)
:785 +0x36b7
:2197 +0x1
goroutine 387 [IO wait]:
(0x1f13388, 0x7fdb0b3be218, 0x1e13eee, 0x7, 0xc420381b1b, 0x5)
:271 +0x13a
(0x7fdb0b3be1f0, 0x72, 0x28fc660)
:345 +0xc7
:164 +0x59
(0xc420211958, 0x72, 0x28f6ad0, 0xc4202ea060)
:75 +0x38
(0xc420211958, 0xffffffffffffffff, 0x0)
:80 +0x34
(0xc4202118f0, 0x0, 0x28fa8e0, 0xc4202ea060)
:430 +0x1e5
(0xc42022a4c8, 0xc42060b9e0, 0x1d3bf40, 0x28dfdf0)
:136 +0x2e
(0xc42022a4c8, 0xc42060b9b0, 0x1d3bf40, 0x28dfdf0, 0x1d9cf60)
:228 +0x49
(0xc42044b970, 0x2900be0, 0xc42022a4c8, 0x0, 0x0)
:2643 +0x228
(0xc420605520, 0xc42044b970, 0x1e11dde, 0x5)
:646 +0x402
(0xc420605520, 0x0, 0x0, 0xb, 0x2900be0)
:587 +0x53
(0xc42020d000)
:861 +0x3f3
:2197 +0x1
goroutine 388 [IO wait]:
(0x1f13388, 0x7fdb0b3be158, 0x1e13eee, 0x7, 0x889a1b, 0x5)
:271 +0x13a
(0x7fdb0b3be130, 0x72, 0xb)
:345 +0xc7
(0x7fdb0b3be130, 0x72, 0x26)
:164 +0x59
(0xc420223798, 0x72, 0x28fc660, 0x28f6ad0)
:75 +0x38
(0xc420223798, 0xc420613000, 0x1000)
:80 +0x34
(0xc420223730, 0xc420613000, 0x1000, 0x1000, 0x0, 0x28fc660, 0x28f6ad0)
:250 +0x1b7
(0xc42022a4e0, 0xc420613000, 0x1000, 0x1000, 0x0, 0x0, 0x0)
:181 +0x70
(0xc425774140, 0xc420613000, 0x1000, 0x1000, 0x0, 0x2, 0x0)
:754 +0x140
(0xc4205adc80)
:97 +0x117
(0xc4205adc80, 0xa, 0x2, 0x0, 0x9727a7, 0xc4259840ac, 0x28f6250)
:338 +0xbb
(0xc4205adc80, 0xc425334700, 0x100, 0xf8, 0x1df7ae0, 0xc42022a4e0, 0x83fdd2)
:367 +0x37
(0xc4250e6120, 0xc4203c7ac8, 0xc4203c7ac8, 0x7ef428, 0x100, 0x1df7ae0)
:55 +0x5f
(0xc4250e6120, 0xc425334700, 0x72, 0x8000000000000000, 0x0)
:36 +0x2f
(0xc4205adc80, 0x0, 0xc425334700, 0x0, 0x0)
:918 +0xa5
(0xc420246f00, 0x2901920, 0xc425774100, 0x0, 0x0, 0x0)
:934 +0x213
(0xc420246f00, 0x2901920, 0xc425774100)
:1763 +0x49a
:2197 +0x1
rax 0x0
rbx 0x21bd5d8
rcx 0xb40
rdx 0x0
rdi 0x7fdb09039520
rsi 0x7fdb0903a750
rbp 0x7fdac47f7120
rsp 0x7fdac47f6e18
r8 0x7fdb0903a750
r9 0x7fdac47f8700
r10 0x0
r11 0x0
r12 0x2259353
r13 0x0
r14 0x7fdac47f74a8
r15 0x7fdaf0032bc0
rip 0x13280f9
rflags 0x10202
cs 0x33
fs 0x0
gs 0x0
