Solved A couple of questions
Mr_MazAXaka
1 I received a license and added it to my server and it happens that 1 of the added bots sometimes stops being on the server (I have an auto-restart on them every hour) and then it never connects to the server (although in the control panel it shows on the server "green button")
My server characteristics:
CPU: INTEL XEON-E 2288G 3.7GHz - 1 NUCLEUS RAM: SAMSUNG DDR4 2.6GHz - 2Gb DATA STORE: NVMe SSD SAMSUNG PM983 - 20Gb PORT: 1000 Mbit
2 After auto-restart on every Saturday, bots do not want to connect to my server themselves, come open the control panel and turn on each of them. How can I fix it?
Lala Sabathil
Maybe the RAM is too low for the TS3Client.
Gut you use the diagSinusbot Script and post the output please?
Why you do an autostart every Saturday?
Mr_MazAXaka
It?
 - Operating System: Debian GNU/Linux 9.11 (stretch)
 - Kernel: Linux 4.9.0-11-amd64 x86_64
 - Load Average: 0.00 0.05 0.05
 - Uptime: 1 days, 14 hours, 41 minutes, 13 seconds
 - OS Updates: 104 (updates available!)
 - OS APT Last Update: 05.08.2020 04:23:02 MSK +03:00:00
 - Shell Locale: en_US.UTF-8
    CPU(s):                1
    Thread(s) per core:    1
    Core(s) per socket:    1
    Socket(s):             1
    Model name:            Intel(R) Xeon(R) E-2288G CPU @ 3.70GHz
    CPU MHz:               3696.000
    Hypervisor vendor:     KVM
    Virtualization type:   full
 - RAM: 532.51 MB/1.95 GB in use (26%)
 - DISK: 4.84 GB/19.55 GB in use (24%)
   - libglib: 2.50.3-2+deb9u1
 - Status: running (PIDs: 9918 9916, User: sinusbot)
   - YoutubeDLPath = /usr/local/bin/youtube-dl (does exist, version: 2019.11.28)
 - Installed scripts: advertising.js; AFK_Mover_(AwayMuteDeafIdle).js; alonemode.js; AutomaticChannelGroupAssigner.js; Bad_Nickname_Check.js; bookmark.js; command.js; CountOnlineUsers.js; followme.js; Game_Server_Query.js; gta_samp.js; LastFM_Scrobbling.js; Montys_Auto_Support_Ping.js; MusicSoundText_Message_On_Join.js; norecording.js; OKlib.js; Online_Users_Record.js; Plopos_Permission_Mover.js; radioOnLeave.js; rememberChannel.js; RLNT MUOJ v1.0.0.js; RSS_Feed.js; Server_Join_Alert.js; Server_Rules.js; simple_channel_notifications.js; SteamLevelQuery.js; SteamUserQuery.js; Uptimerobot_-_Server_StatusUptime_Monitoring.js; welcome.js; WelcomeMessage.js; WelcomeSound.js
    linux-vdso.so.1 (0x00007fffcb4b8000)
    libswresample.so.2 => /opt/sinusbot/libswresample.so.2 (0x00007fd0ecbdf000)
    libavfilter.so.6 => /opt/sinusbot/libavfilter.so.6 (0x00007fd0ec887000)
    libavformat.so.57 => /opt/sinusbot/libavformat.so.57 (0x00007fd0ec486000)
    libavcodec.so.57 => /opt/sinusbot/libavcodec.so.57 (0x00007fd0ebb21000)
    libavutil.so.55 => /opt/sinusbot/libavutil.so.55 (0x00007fd0eb8ad000)
    libdl.so.2 => /lib/x86_64-linux-gnu/libdl.so.2 (0x00007fd0eb6a9000)
    libm.so.6 => /lib/x86_64-linux-gnu/libm.so.6 (0x00007fd0eb3a5000)
    libpthread.so.0 => /lib/x86_64-linux-gnu/libpthread.so.0 (0x00007fd0eb188000)
    libstdc++.so.6 => /usr/lib/x86_64-linux-gnu/libstdc++.so.6 (0x00007fd0eae06000)
    libgcc_s.so.1 => /lib/x86_64-linux-gnu/libgcc_s.so.1 (0x00007fd0eabef000)
    libc.so.6 => /lib/x86_64-linux-gnu/libc.so.6 (0x00007fd0ea850000)
    libz.so.1 => /lib/x86_64-linux-gnu/libz.so.1 (0x00007fd0ea636000)
    librt.so.1 => /lib/x86_64-linux-gnu/librt.so.1 (0x00007fd0ea42e000)
    /lib64/ld-linux-x86-64.so.2 (0x00007fd0ecdf9000)
 - HTTPS check with IPv4 mode: SUCCESS [Connection established to http://www.sinusbot.com, CODE #200]
 - DNS resolution check: SUCCESS [http://www.sinusbot.com resolved to 104.28.15.74]
 - Time (local): 06.08.2020 00:44:45 MSK +03:00:00
 - Time (remote): 06.08.2020 00:44:45 MSK +03:00:00
 - Timezone: Europe/Moscow
 - TeamSpeak3 Version: 3.3.2
 - youtube-dl Version: 2019.11.28
[2020-08-06 00:44:47] [DEBUG] Done.
Mr_MazAXaka
And I don’t know about auto-restarting 5 years ago I did it and got used to it, but before the bots themselves connected to the server over the past year and a half, now they don’t want to enter the server themselves ..
Lala Sabathil
First, can you update your packages
Second, can you upgrade to buster?
Third, Youtubedl seems old
Fourth, maybe use the startup script? For restart?
I would like to ask if you want to try to install it via Debian package?
Mr_MazAXaka
So well, I updated the server OS.
I will turn on the bots and check whether one of the bots will be dumped again or not.
Or did you mean something else?
Lala Sabathil
Nice. Please check it.
Are you now on buster?
The last one was more a question if you would test another way of installing sinusbot.
Mr_MazAXaka
I think to check the current option for the blade of one of the bots.
If it appears again, I want to try your option.
Mr_MazAXaka
I found the solution "Reconnect", the script included and after restarting the machine, the bots themselves enter the server)
Thank you very much for your help, if one of the bots falls off again within a week, I will ask you about another method)
Mr_MazAXaka
Overall test results:
1 week were online as expected
then one of the main bots disconnected and never returned ... (returned when I rebooted the machine)
How do I make a different installation?
Mr_MazAXaka
Why not? it just doesn't work out that one of the bots can constantly disconnect and not return in the end ...
And so it can help
