* Rebuilt URL to: https://update01.sinusbot.com/
* Hostname was NOT found in DNS cache
* Trying 104.18.40.220...
* Connected to update01.sinusbot.com (104.18.40.220) port 443 (#0)
* successfully set certificate verify locations:
* CAfile: none
CApath: /etc/ssl/certs
* SSLv3, TLS handshake, Client hello (1):
* SSLv3, TLS handshake, Server hello (2):
* SSLv3, TLS handshake, CERT (11):
* SSLv3, TLS handshake, Server key exchange (12):
* SSLv3, TLS handshake, Server finished (14):
* SSLv3, TLS handshake, Client key exchange (16):
* SSLv3, TLS change cipher, Client hello (1):
* SSLv3, TLS handshake, Finished (20):
* SSL connection using TLSv1.2 / ECDHE-ECDSA-AES128-GCM-SHA256
* Server certificate:
* subject: OU=Domain Control Validated; OU=PositiveSSL Multi-Domain; CN=s ni104088.cloudflaressl.com
* start date: 2017-11-02 00:00:00 GMT
* expire date: 2018-05-11 23:59:59 GMT
* subjectAltName: update01.sinusbot.com matched
* issuer: C=GB; ST=Greater Manchester; L=Salford; O=COMODO CA Limited; CN =COMODO ECC Domain Validation Secure Server CA 2
* SSL certificate verify ok.
> GET / HTTP/1.1
> User-Agent: curl/7.38.0
> Host: update01.sinusbot.com
> Accept: */*
< HTTP/1.1 403 Forbidden
< Date: Thu, 09 Nov 2017 18:39:15 GMT
< Content-Type: text/html; charset=UTF-8
< Transfer-Encoding: chunked
< Connection: close
< Set-Cookie: __cfduid=d0be4f917f7a3a0ed37f62fbf6d3f83981510252755; expires=Fri, 09-Nov-18 18:39:15 GMT; path=/; domain=.sinusbot.com; HttpOnly
< CF-Chl-Bypass: 1
< Cache-Control: max-age=2
< Expires: Thu, 09 Nov 2017 18:39:17 GMT
< X-Frame-Options: SAMEORIGIN
* Server cloudflare-nginx is not blacklisted
< Server: cloudflare-nginx
< CF-RAY: 3bb2e4cbfef11ae1-DUS
<!DOCTYPE html>
<!--[if lt IE 7]> <html class="no-js ie6 oldie" lang="en-US"> <![endif]-->
<!--[if IE 7]> <html class="no-js ie7 oldie" lang="en-US"> <![endif]-->
<!--[if IE 8]> <html class="no-js ie8 oldie" lang="en-US"> <![endif]-->
<!--[if gt IE 8]><!--> <html class="no-js" lang="en-US"> <!--<![endif]-->
<head>
<title>Attention Required! | Cloudflare</title>
<meta name="captcha-bypass" id="captcha-bypass" />
<meta charset="UTF-8" />
<meta http-equiv="Content-Type" content="text/html; charset=UTF-8" />
<meta http-equiv="X-UA-Compatible" content="IE=Edge,chrome=1" />
<meta name="robots" content="noindex, nofollow" />
<meta name="viewport" content="width=device-width,initial-scale=1,maximum-scale= 1" />
<link rel="stylesheet" id="cf_styles-css" href="/cdn-cgi/styles/cf.errors.css" t ype="text/css" media="screen,projection" />
<!--[if lt IE 9]><link rel="stylesheet" id='cf_styles-ie-css' href="/cdn-cgi/sty les/cf.errors.ie.css" type="text/css" media="screen,projection" /><![endif]-->
<style type="text/css">body{margin:0;padding:0}</style>
<!--[if lte IE 9]><script type="text/javascript" src="/cdn-cgi/scripts/jquery.mi n.js"></script><![endif]-->
<!--[if gte IE 10]><!--><script type="text/javascript" src="/cdn-cgi/scripts/zep to.min.js"></script><!--<![endif]-->
<script type="text/javascript" src="/cdn-cgi/scripts/cf.common.js"></script>
</head>
<body>
<div id="cf-wrapper">
<div class="cf-alert cf-alert-error cf-cookie-error" id="cookie-alert" data- translate="enable_cookies">Please enable cookies.</div>
<div id="cf-error-details" class="cf-error-details-wrapper">
<div class="cf-wrapper cf-header cf-error-overview">
<h1 data-translate="challenge_headline">One more step</h1>
<h2 class="cf-subheadline"><span data-translate="complete_sec_check">Ple ase complete the security check to access</span> update01.sinusbot.com</h2>
</div><!-- /.header -->
<div class="cf-section cf-highlight cf-captcha-container">
<div class="cf-wrapper">
<div class="cf-columns two">
<div class="cf-column">
<div class="cf-highlight-inverse cf-form-stacked">
<form class="challenge-form" id="challenge-form" action="/cdn-cg i/l/chk_captcha" method="get">
<script type="text/javascript" src="/cdn-cgi/scripts/cf.challenge.js" data-typ e="normal" data-ray="3bb2e4cbfef11ae1" async data-sitekey="6LfBixYUAAAAABhdHynF UIMA_sa4s-XsJvnjtgB0"></script>
<div class="g-recaptcha"></div>
<noscript id="cf-captcha-bookmark" class="cf-captcha-info">
<div><div style="width: 302px">
<div>
<iframe src="https://www.google.com/recaptcha/api/fallback?k=6LfBixYUAAA AABhdHynFUIMA_sa4s-XsJvnjtgB0" frameborder="0" scrolling="no" style="width: 302p x; height:422px; border-style: none;"></iframe>
</div>
<div style="width: 300px; border-style: none; bottom: 12px; left: 25px; ma rgin: 0px; padding: 0px; right: 25px; background: #f9f9f9; border: 1px solid #c1 c1c1; border-radius: 3px;">
<textarea id="g-recaptcha-response" name="g-recaptcha-response" class="g -recaptcha-response" style="width: 250px; height: 40px; border: 1px solid #c1c1c 1; margin: 10px 25px; padding: 0px; resize: none;"></textarea>
<input type="submit" value="Submit"></input>
</div>
</div></div>
</noscript>
</form>
</div>
</div>
<div class="cf-screenshot-container">
<span class="cf-no-screenshot"></span>
</div>
</div>
</div><!-- /.columns -->
</div>
</div><!-- /.captcha-container -->
<div class="cf-section cf-wrapper">
<h2 data-translate="why_captcha_headline">Why do I have to complete a CAPTCHA?</h2>
<p data-translate="why_captcha_detail">Completing the CAPTCHA proves you are a human and gives you temporary access to the web property.</p>
</div>
<h2 data-translate="resolve_captcha_headline">What can I do to preve nt this in the future?</h2>
<p data-translate="resolve_captcha_antivirus">If you are on a person al connection, like at home, you can run an anti-virus scan on your device to ma ke sure it is not infected with malware.</p>
<p data-translate="resolve_captcha_network">If you are at an office or shared network, you can ask the network administrator to run a scan across th e network looking for misconfigured or infected devices.</p>
</div>
</div>
</div><!-- /.section -->
<div class="cf-error-footer cf-wrapper">
<p>
<span class="cf-footer-item">Cloudflare Ray ID: <strong>3bb2e4cbfef11ae1</st rong></span>
<span class="cf-footer-separator">•</span>
<span class="cf-footer-item"><span data-translate="your_ip">Your IP</span>: 80.211.250.104</span>
<span class="cf-footer-item"><span data-translate="performance_security_by"> Performance & security by</span> <a data-orig-proto="https" data-orig-ref="w ww.cloudflare.com/5xx-error-landing?utm_source=error_footer" id="brand_link" tar get="_blank">Cloudflare</a></span>
</p>
</div><!-- /.error-footer -->
</div><!-- /#cf-error-details -->
</div><!-- /#cf-wrapper -->
<script type="text/javascript">
window._cf_translation = {};
</script>
</body>
</html>
* Closing connection 0
* SSLv3, TLS alert, Client hello (1):
root@MZKPTEAM:~# curl -v https://update01.sinusbot.com
* CAfile: none
* subject: OU=Domain Control Validated; OU=PositiveSSL Multi-Domain; CN=sni104088.cloudflaressl.com
* issuer: C=GB; ST=Greater Manchester; L=Salford; O=COMODO CA Limited; CN=COMODO ECC Domain Validation Secure Server CA 2
> GET / HTTP/1.1
> Accept: */*
< Date: Thu, 09 Nov 2017 18:39:25 GMT
< Connection: close
< Set-Cookie: __cfduid=dee547c9da53bd99e5923eccfd045ebe61510252765; expires=Fri, 09-Nov-18 18:39:25 GMT; path=/; domain=.sinusbot.com; HttpOnly
< CF-Chl-Bypass: 1
< Expires: Thu, 09 Nov 2017 18:39:27 GMT
< CF-RAY: 3bb2e509ada41a8d-DUS
<!DOCTYPE html>
<head>
<meta name="viewport" content="width=device-width,initial-scale=1,maximum-scale=1" />
<link rel="stylesheet" id="cf_styles-css" href="/cdn-cgi/styles/cf.errors.css" type="text/css" media="screen,projection" />
<!--[if lt IE 9]><link rel="stylesheet" id='cf_styles-ie-css' href="/cdn-cgi/styles/cf.errors.ie.css" type="text/css" media="screen,projection" /><![endif]-->
<!--[if lte IE 9]><script type="text/javascript" src="/cdn-cgi/scripts/jquery.min.js"></script><![endif]-->
<!--[if gte IE 10]><!--><script type="text/javascript" src="/cdn-cgi/scripts/zepto.min.js"></script><!--<![endif]-->
</head>
<body>
<div class="cf-alert cf-alert-error cf-cookie-error" id="cookie-alert" data-translate="enable_cookies">Please enable cookies.</div>
<h2 class="cf-subheadline"><span data-translate="complete_sec_check">Please complete the security check to access</span> update01.sinusbot.com</h2>
<form class="challenge-form" id="challenge-form" action="/cdn-cgi/l/chk_captcha" method="get">
<script type="text/javascript" src="/cdn-cgi/scripts/cf.challenge.js" data-type="normal" data-ray="3bb2e509ada41a8d" async data-sitekey="6LfBixYUAAAAABhdHynFUIMA_sa4s-XsJvnjtgB0"></script>
<div>
<iframe src="https://www.google.com/recaptcha/api/fallback?k=6LfBixYUAAAAABhdHynFUIMA_sa4s-XsJvnjtgB0" frameborder="0" scrolling="no" style="width: 302px; height:422px; border-style: none;"></iframe>
</div>
<div style="width: 300px; border-style: none; bottom: 12px; left: 25px; margin: 0px; padding: 0px; right: 25px; background: #f9f9f9; border: 1px solid #c1c1c1; border-radius: 3px;">
<textarea id="g-recaptcha-response" name="g-recaptcha-response" class="g-recaptcha-response" style="width: 250px; height: 40px; border: 1px solid #c1c1c1; margin: 10px 25px; padding: 0px; resize: none;"></textarea>
</div>
</div></div>
</noscript>
</form>
</div>
</div>
</div>
</div>
</div>
</div>
<h2 data-translate="resolve_captcha_headline">What can I do to prevent this in the future?</h2>
<p data-translate="resolve_captcha_antivirus">If you are on a personal connection, like at home, you can run an anti-virus scan on your device to make sure it is not infected with malware.</p>
<p data-translate="resolve_captcha_network">If you are at an office or shared network, you can ask the network administrator to run a scan across the network looking for misconfigured or infected devices.</p>
</div>
</div>
<p>
<span class="cf-footer-item">Cloudflare Ray ID: <strong>3bb2e509ada41a8d</strong></span>
<span class="cf-footer-item"><span data-translate="performance_security_by">Performance & security by</span> <a data-orig-proto="https" data-orig-ref="www.cloudflare.com/5xx-error-landing?utm_source=error_footer" id="brand_link" target="_blank">Cloudflare</a></span>
</p>
</script>
</body>
</html>
