Marcinek1465
TS3 version 3.1.8
Hi! I have problem with SinusBot.
I installed this with Installer Script and Manually but still not working. When i try to start the bot (by ./sinusbot) i got message: A manual update is required
Previously i used this on Debian, and all works good, but in one time my bot has Connection Lost from TS3 server and i got message "A manual update is required".
I think my time is set good (i know this from Sinusbot Diagnostics)
Please help me and sorry for my bad english.
Config.ini:
Diagnostics log:
Config.ini:
LogLevel = 3
ChunkSize = 5242880
UpdateInterval = 0[
Diagnostics log:
- Operating System: Ubuntu 16.04.4 LTS
- Kernel: Linux 4.4.0-116-generic x86_64
- Load Average: 0.08 0.09 0.07
- Uptime: 0 days, 0 hours, 7 minutes, 31 seconds
- OS APT Last Update: 08.03.2018 03:37:47 CET +01:00:00
- HTTPS check with IPv4 mode: FAILED [Failed establishing connection to www.sinusbot.com, CODE #403]
CPU(s): 2
Thread(s) per core: 1
Core(s) per socket: 1
Socket(s): 2
Model name: Common KVM processor
CPU MHz: 2599.998
Hypervisor vendor: KVM
Virtualization type: full
- RAM: 316.42 MB/3.85 GB in use (8%)
- DISK: 2.03 GB/46.35 GB in use (4%)
+ libglib: 2.48.2-0ubuntu1
- Binary Info: MD5 Hash: f42a573b7435a8ff04da446d5ccbe754, Perms: 755, User: sinusbot
- Version: 0.13.37-9791176
- TS3Path = /opt/sinusbot/TeamSpeak3-Client-linux_amd64/ts3client_linux_amd64 (Version 3.1.8)
- YoutubeDLPath = not set (does exist anyway, version: 2018.03.03)
- Time (local): 08.03.2018 04:44:16 CET +01:00:00
- Time (remote): 08.03.2018 04:44:16 CET +01:00:00
- Timezone: Europe/Warsaw
- TeamSpeak 3 Version: 3.1.8
- youtube-dl Version: 2018.03.03
- DiagScript Version: 0.7.0
