about bot
Lala Sabathil
help meee
The normal way to get help in a forum:
The first thing to do is to see if you can fix the problem yourself, because you might have made a mistake.
If this is not the case, take a look at the FAQ of a forum (in our case it is here: https://forum.sinusbot.com/kb).
Then check if there are similar posts to your problem (see https://forum.sinusbot.com/search/).
If this is not the case, you will open a new post in which you stick to the guides for the post creation (in our case: https://forum.sinusbot.com/threads/read-me-before-you-post.342/).
Is there a sinusbot file for older version teamspeak servers?
No. There is no reason to have an old TeamSpeak Server except if you're doing illegal crap, either way: we don't support it.
Old versions are not supported, there is no reason to keep the teamspeak client to such an old version
By the way: every thread that you created has a unspecific/uninformative title and most of the questions that you ask are already explained in the FAQ/WIKI or in another thread.
If you continue making low quality/low effort posts like this it will have consequences.
