Solved After uploading the license, bot does not start
SirBusterWolf
Welcome to the problem.
I got licenses when I uploaded it to the bot is a bot that I didn't want to run.
After typing ystemctl the status of sinusbot. service I have it
Loaded: loaded (/lib/systemd/system/sinusbot.service; enabled)
Active: failed (Result: exit-code) since sob 2017-12-23 15:10:07 CET; 5s ago
Process: 7678 ExecStopPost=/bin/rm -f /tmp/.sinusbot.lock (code=exited, status=0/SUCCESS)
Process: 7672 ExecStart=/opt/sinusbot/sinusbot (code=exited, status=255)
Process: 7671 ExecStartPre=/bin/rm -f /tmp/.sinusbot.lock (code=exited, status=0/SUCCESS)
Main PID: 7672 (code=exited, status=255)
gru 23 15:10:07 vps3252 systemd[1]: Started Sinusbot, the Teamspeak 3 and Discord music bot..
gru 23 15:10:07 vps3252 sinusbot[7672]: ___ ___ _ _ _ _ ___ ___ ___ _____ BETA
gru 23 15:10:07 vps3252 sinusbot[7672]: / __|_ _| \| | | | / __| _ )/ _ \_ _|
gru 23 15:10:07 vps3252 sinusbot[7672]: \__ \| || .` | |_| \__ \ _ \ (_) || |
gru 23 15:10:07 vps3252 sinusbot[7672]: |___/___|_|\_|\___/|___/___/\___/ |_|
gru 23 15:10:07 vps3252 sinusbot[7672]: Version: 0.11.0-8e5f1a2
gru 23 15:10:07 vps3252 sinusbot[7672]: (C) 2013-2017 Michael Friese. All rights reserved.
gru 23 15:10:07 vps3252 sinusbot[7672]: 2017/12/23 15:10:07 X [MAIN] Starting up fake x-server...
gru 23 15:10:07 vps3252 systemd[1]: sinusbot.service: main process exited, code=exited, status=255/n/a
gru 23 15:10:07 vps3252 systemd[1]: Unit sinusbot.service entered failed state.
Elias
Wenn ich den MusikBot normal über das Script herunterladen läuft alles super. Dann packe ich aber die neue privat.dat in /opt/sinusbot und starte dann den Musikbot neu.
Danach startet er nicht mehr und es kommt der folgende Fehler: https://pastebin.com/i8XFW0bK
