Audio Problem
Fritte
Hey guys,
the sinusbot is allways muted, only if im logged in with rdp theres a audio.
Windows Server 2019 Standart Edition x64 Xeon with 64GB Ram.
I tryed installing an Virtual Audio Cable, that doesnt helped.
On my old 2016 Server it works great....
Any solutions?
Fritte
Okay, i found the problem ,but not the solution..
If i connect with rdp and disconnect after that, the bot will be muted...
Fritte
when exit RDP, stops sounds of the remote computer, its a known problem
Windows 10 Remote Desktop Session - Sound stops when disconnect
Solution:
Create a batch file, create an shortcut and run that
for /f "skip=1 tokens=3" %%s in ('query user %USERNAME%') do (
  %windir%\System32\tscon.exe %%s /dest:console
The sinusbot will keep playing the sound
if you want to kill one remote session of multiple one, you can use
%windir%\System32\tscon.exe RDP-Tcp#NNN /dest:console
to kill one
