Big problem `GLIBC_2.18'
Turkoy
Hello friends
My system;
Centos 7
kernel: 5.6.5-1.el7.elrepo.x86_64
I installed with automatic install script, I entered the panel, I made the settings. But why is the bot constantly giving the following error in error records?
2020-04-20T15:36:51+03:00 TSClient quit. LogLevel has been increased, please try to connect again to see more details.
2020-04-20T15:36:51+03:00 Closed.
2020-04-20T15:36:51+03:00 TS>/opt/sinusbot/teamspeak3-client/ts3client_linux_amd64: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /opt/sinusbot/teamspeak3-client/libc++abi.so.1)
Turkoy
Isn't that the solution? Changing the operating system is not an easy situation!
This is a system that works on other things! As a result, we can not use bots.
I guess there is no other way.
Running it in a docker container might work. But since you cannot really update you glibc without upgrading your OS, this might be your only shot.
