Bot can not connect
TheMorty
Hi, can you help me my bot can not connect to the server!
2020-04-15T20:04:00+02:00 closing channels
2020-04-15T20:03:59+02:00 Closed.
2020-04-15T20:03:59+02:00 TS>QMutex: destroying locked mutex
2020-04-15T20:03:59+02:00 TS>139984146143360:error:0E076071:configuration file routines:MODULE_RUN:unknown module name:conf_mod.c:222:module=ssl_conf
2020-04-15T20:03:59+02:00 TS>139984146143360:error:0E07506E:configuration file routines:MODULE_LOAD_DSO:error loading dso:conf_mod.c:285:module=ssl_conf, path=ssl_conf
2020-04-15T20:03:59+02:00 TS>139984146143360:error:25070067:DSO support routines:DSO_load:could not load the shared library:dso_lib.c:244:
2020-04-15T20:03:59+02:00 TS>139984146143360:error:25066067:DSO support routines:DLFCN_LOAD:could not load the shared library:dso_dlfcn.c:185:filename(libssl_conf.so): libssl_conf.so: cannot open shared object file: No such file or directory
2020-04-15T20:03:59+02:00 TS>Auto configuration failed
2020-04-15T20:03:59+02:00 TS>ALSA lib pcm.c:2565:(snd_pcm_open_noupdate) Unknown PCM default
2020-04-15T20:03:59+02:00 TS>ALSA lib conf.c:5047:(snd_config_expand) Evaluate error: No such file or directory
2020-04-15T20:03:59+02:00 TS>ALSA lib conf.c:4568:(_snd_config_evaluate) function snd_func_refer returned error: No such file or directory
2020-04-15T20:03:59+02:00 TS>ALSA lib confmisc.c:1246:(snd_func_refer) error evaluating name
2020-04-15T20:03:59+02:00 TS>ALSA lib conf.c:4568:(_snd_config_evaluate) function snd_func_concat returned error: No such file or directory
2020-04-15T20:03:59+02:00 TS>ALSA lib confmisc.c:392:(snd_func_concat) error evaluating strings
2020-04-15T20:03:59+02:00 TS>ALSA lib conf.c:4568:(_snd_config_evaluate) function snd_func_card_driver returned error: No such file or directory
2020-04-15T20:03:59+02:00 TS>ALSA lib confmisc.c:767:(parse_card) cannot find card '0'
2020-04-15T20:03:59+02:00 TSClient quit. LogLevel has been increased, please try to connect again to see more details.
2020-04-15T20:03:59+02:00 TS>libpng warning: iCCP: known incorrect sRGB profile
2020-04-15T20:03:59+02:00 TS>QXcbIntegration: Cannot create platform OpenGL context, neither GLX nor EGL are enabled
2020-04-15T20:03:59+02:00 TS>QCoreApplication::applicationDirPath: Please instantiate the QApplication object first
2020-04-15T20:03:58+02:00 TS |INFO | | |Statistics report: Not yet, next report on Sat May 9 19:48:53 2020
2020-04-15T20:03:58+02:00 TS |INFO |ClientUI | |Last update check was: Sat Jan 1 00:00:01 2022
2020-04-15T20:03:58+02:00 TS |INFO |Bookmarks | |Collecting autoconnect bookmarks
2020-04-15T20:03:58+02:00 TS |INFO |ClientUI |1 |Connect status: Disconnected
2020-04-15T20:03:58+02:00 TS |INFO |ClientUI |1 |Connect status: Connecting
2020-04-15T20:03:58+02:00 TS |ERROR |SoundBckndIntf| |/opt/SinusPort-8088/TeamSpeak3-Client-linux_amd64/soundbackends/libalsa_linux_amd64.so error: ALSA
2020-04-15T20:03:58+02:00 TS |ERROR |ALSA | |snd_pcm_open: No such file or directory -
2020-04-15T20:03:58+02:00 TS>AA ts3.alsa.dummy.capturedefault 5
2020-04-15T20:03:58+02:00 TS |INFO |CapSoundSet | |Found invalid capture device 'SinusBot', using default device 'ts3.alsa.dummy.capturedefault
2020-04-15T20:03:58+02:00 TS>AA ts3.alsa.dummy.playbackdefault 5
2020-04-15T20:03:58+02:00 TS |INFO |PlaySoundSet | |Found invalid playback device 'SinusBot', using default device 'ts3.alsa.dummy.playbackdefault
2020-04-15T20:03:58+02:00 TS |INFO |ClientUI |1 |Initiating connection: 178.238.235.148:25570
2020-04-15T20:03:58+02:00 TS |INFO |ClientUI |1 |Resolve successful: 178.238.235.148:25570
2020-04-15T20:03:58+02:00 TS |INFO |ClientUI |1 |Lookup finished: ip=178.238.235.148 port=25570 query=ts.citycraft.cz error=0
2020-04-15T20:03:58+02:00 TS |INFO |TSDNS | |A/AAAA DNS resolve successful, "ts1.citycraft.cz" =(h: 178.238.235.148 p:0)
2020-04-15T20:03:58+02:00 TS |INFO |TSDNS | |SRV DNS resolve successful, "_ts3._udp.ts.citycraft.cz" =(h: ts1.citycraft.cz p:25570)
2020-04-15T20:03:58+02:00 TS |INFO |TSDNS | |SRV DNS resolve unsuccessful, "_tsdns._tcp.citycraft.cz" DNS server returned answer with no data
2020-04-15T20:03:58+02:00 TS |INFO |TSDNS | |A/AAAA DNS resolve for possible TSDNS successful, "citycraft.cz" =(h: 178.238.37.239 p:0)
2020-04-15T20:03:58+02:00 TS |INFO |TSDNS | |A/AAAA DNS resolve unsuccessful, "ts.citycraft.cz" DNS server returned answer with no data
2020-04-15T20:03:58+02:00 TS |INFO |ClientUI |1 |Trying to resolve ts.citycraft.cz
2020-04-15T20:03:58+02:00 TS |INFO |ClientUI |1 |Connect to server: ts.citycraft.cz
2020-04-15T20:03:58+02:00 TS |INFO |ClientUI | |ts3server: ts.citycraft.cz?port=9987&nickname=Martyho%20priv%C3%A1tn%C3%AD%20bot&password=&channel=&channelpassword=
2020-04-15T20:03:58+02:00 TS |INFO |ClientUI | |Using configuration location: /opt/SinusPort-8088/data/ts3/3c164aee-aa10-4a42-8882-cda0044ca862/b6f3fde3-ae54-409f-812e-4168546baff4/settings.db
2020-04-15T20:03:58+02:00 TS |INFO |ClientUI | |Qt version: 5.6.1
2020-04-15T20:03:58+02:00 TS |INFO |ClientUI | |Failed to init text to speech engine
2020-04-15T20:03:58+02:00 TS |DEVELOP |ClientUI | |Notifications init: Soundpack path: /opt/SinusPort-8088/TeamSpeak3-Client-linux_amd64/sound/nosounds
2020-04-15T20:03:58+02:00 TS |INFO | | |*** Time [INIT]: 172
2020-04-15T20:03:58+02:00 TS |INFO | | |*** Time [MAINWINDOW]: 171
2020-04-15T20:03:58+02:00 TS |INFO | | |failed to download revocation list - count: 1
2020-04-15T20:03:58+02:00 TS |INFO |Plugins | |Api version is not compatible for plugin: /opt/SinusPort-8088/TeamSpeak3-Client-linux_amd64/plugins/libsoundbot_plugin.so
2020-04-15T20:03:58+02:00 TS |INFO |Plugins | |Loading plugin: libsoundbot_plugin.so
2020-04-15T20:03:58+02:00 TS |INFO |Addons | |Checking for addon updates...
2020-04-15T20:03:58+02:00 TS |INFO |ClientUI | |Unable to create an Open GL context.
2020-04-15T20:03:58+02:00 TS |ERROR |SoundBckndIntf| |libpulse.so.0: cannot open shared object file: No such file or directory
2020-04-15T20:03:58+02:00 TS |INFO | | |Using hardware aes
2020-04-15T20:03:58+02:00 TS |INFO | | |SystemInformation: Linux 4.19.0-8-amd64 #1 SMP Debian 4.19.98-1 (2020-01-26) x86_64 Binary: 64bit
2020-04-15T20:03:58+02:00 TS |INFO | | |TeamSpeak 3 Client 3.1.8 (2018-01-22 09:50:07)
2020-04-15T20:03:58+02:00 TS>DUMP defined! Dumpdir is: /opt/SinusPort-8088/data/ts3/3c164aee-aa10-4a42-8882-cda0044ca862/b6f3fde3-ae54-409f-812e-4168546baff4/crashdumps
2020-04-15T20:03:58+02:00 TS>Crashdump ENABLED, directory is: /opt/SinusPort-8088/data/ts3/3c164aee-aa10-4a42-8882-cda0044ca862/b6f3fde3-ae54-409f-812e-4168546baff4/crashdumps
2020-04-15T20:03:58+02:00 Starting instance ts3server://ts.citycraft.cz?port=9987&nickname=Martyho%20priv%C3%A1tn%C3%AD%20bot&password=&channel=&channelpassword=
2020-04-15T20:03:58+02:00 Could not insert into News-Tableno such table: News
2020-04-15T20:03:58+02:00 Could not delete from Newsno such table: News
2020-04-15T20:03:58+02:00 Could not insert into FileTransfer-Tableno such table: FileTransfer
2020-04-15T20:03:58+02:00 Could not delete from FileTransferno such table: FileTransfer
2020-04-15T20:03:58+02:00 Could not create Notifications-Tabletable Notifications already exists
2020-04-15T20:03:58+02:00 Could not create WhisperReceive-Tabletable WhisperReceive already exists
2020-04-15T20:03:58+02:00 Could not create Chat-Tabletable Chat already exists
2020-04-15T20:03:58+02:00 About to run.
2020-04-15T20:03:58+02:00 Prespawn.
