Solved Bot is creating channels in a weird order
Montiary
hey i am writing a script to automate channel creation.
my script is working but the bot starts creates the channel from bootem.
normaly it should look like this
channel1
channel2
channel3
my but do
channel3
channel2
channel1
and i dont understand why.
here is the channel creation part:
JavaScript:
                var create = backend.createChannel({
                    parent: "0",
                    position: ChannelPosition,
                    permanent: true,
                    codec: parseInt(ChannelCodec),
                    codecQuality: parseInt(parseInt(ChannelQuality)),
                    maxClients: parseInt(ChannelMaxClients),
                    description: ChannelDescription
i also tried ChannelPosition+1 but it doesnt work
Montiary
try to set position, this should set in which order a channel gets created otherwise i suppose it just creates it at the top most channel
https://sinusbot.github.io/scripting-docs/#channelparams
i already set the position "position: ChannelPosition,"
but with this the bot create the channel in top of the other channel and with "position: ChannelPosition+1"
the bot create the channel under the next channel and that is wrong
