Solved Bot möchte nicht connecten
  • Thread starter Deleted member 50138
  • Start date
D
Guest
Kann mir jemand helfen?
2018-04-21T20:43:07+02:00 TSClient quit.
2018-04-21T20:43:06+02:00 New connection status 0; Error 0
2018-04-21T20:43:06+02:00 The bot could not connect. This might have several reasons: the server doesn't exist at that address, the server password is wrong, the default channel doesn't exist, the bot has been banned, the server is an illegal installation or the password is wrong , the security level of your identity is too low or the server does not allow the version of the client you are using. See our Wiki / Forums for more help.
2018-04-21T20:43:06+02:00 TS |INFO |ClientUI |1 |Disconnected or forced to leave, want autoreconnect = 0
2018-04-21T20:43:06+02:00 TS |INFO |ClientUI |1 |Connect status: Disconnected
2018-04-21T20:43:06+02:00 TS |DEVELOP |PktHandler | |Puzzle solve time: 7
2018-04-21T20:43:06+02:00 New connection status 1; Error 0
2018-04-21T20:43:06+02:00 TS |INFO |ClientUI |1 |Connect status: Connecting
2018-04-21T20:43:05+02:00 TS |INFO |PreProSpeex |1 |Speex version: 1.2rc1
2018-04-21T20:43:05+02:00 TS |INFO |ClientUI |1 |Initiating connection: 178.198.12.225:9987
2018-04-21T20:43:05+02:00 TS |INFO |ClientUI |1 |Resolve successful: 178.198.12.225:9987
2018-04-21T20:43:05+02:00 TS |INFO |ClientUI |1 |Lookup finished: ip=178.198.12.225 port=9987 query=manicraft.de error=0
2018-04-21T20:43:05+02:00 TS |INFO |TSDNS | |No TSDNS found
2018-04-21T20:43:05+02:00 TS |INFO |TSDNS | |TSDNS queried unsuccessfully 178.198.12.225:41144
2018-04-21T20:43:03+02:00 TS |INFO | | |Statistics report: User has not yet confirmed participation
2018-04-21T20:43:03+02:00 TS |INFO |ClientUI | |Last update check was: Di. Jan. 1 00:00:01 2019
2018-04-21T20:43:03+02:00 TS |INFO |Bookmarks | |Collecting autoconnect bookmarks
2018-04-21T20:43:03+02:00 TS |INFO |TSDNS | |SRV DNS resolve unsuccessful, "_ts3._udp.manicraft.de" DNS server returned answer with no data
2018-04-21T20:43:03+02:00 TS |INFO |TSDNS | |SRV DNS resolve unsuccessful, "_tsdns._tcp.manicraft.de" DNS server returned answer with no data
2018-04-21T20:43:03+02:00 TS |INFO |TSDNS | |A/AAAA DNS resolve for possible TSDNS successful, "manicraft.de" =(h: 178.198.12.225 p:0)
2018-04-21T20:43:03+02:00 TS |INFO |TSDNS | |A/AAAA DNS resolve successful, "manicraft.de" =(h: 178.198.12.225 p:0)
2018-04-21T20:43:03+02:00 TS |INFO |ClientUI |1 |Trying to resolve manicraft.de
2018-04-21T20:43:03+02:00 TS |INFO |ClientUI |1 |Connect to server: manicraft.de
2018-04-21T20:43:03+02:00 TS |INFO |ClientUI | |ts3server: manicraft.de?port=9987&nickname=I%E2%99%A5RADIO%20-%20Live&password=&channel=&channelpassword=
2018-04-21T20:43:03+02:00 TS |INFO |ClientUI | |Using configuration location: /opt/sinusbot/data/ts3/d72115f5-7eea-4a47-99ef-5f9312604711/84de2419-5223-44b0-b5e7-12356c7e706a/settings.db
2018-04-21T20:43:03+02:00 TS |INFO |ClientUI | |Qt version: 5.6.1
2018-04-21T20:43:03+02:00 TS |INFO |ClientUI | |Failed to init text to speech engine
2018-04-21T20:43:03+02:00 TS |DEVELOP |ClientUI | |Notifications init: Soundpack path: /opt/sinusbot/teamspeak3-client/sound/nosounds
2018-04-21T20:43:03+02:00 TS |INFO | | |*** Time [INIT]: 243
2018-04-21T20:43:03+02:00 TS |INFO | | |*** Time [MAINWINDOW]: 242
2018-04-21T20:43:03+02:00 TS |INFO | | |successfully downloaded revocation list
2018-04-21T20:43:03+02:00 TS |INFO |Plugins | |Loading plugin: libsoundbot_plugin.so
2018-04-21T20:43:03+02:00 TS |INFO |Query | |listening on 127.0.0.1:25639
2018-04-21T20:43:03+02:00 TS |INFO |Plugins | |Loading plugin: libclientquery_plugin_linux_amd64.so
2018-04-21T20:43:03+02:00 TS |INFO |Addons | |Checking for addon updates...
2018-04-21T20:43:03+02:00 TS |INFO |ClientUI | |Unable to create an Open GL context.
2018-04-21T20:43:03+02:00 TS |ERROR |SoundBckndIntf| |libpulse.so.0: Kann die Shared-Object-Datei nicht öffnen: Datei oder Verzeichnis nicht gefunden
2018-04-21T20:43:03+02:00 TS |INFO | | |SystemInformation: Linux 4.4.0-119-generic #143-Ubuntu SMP Mon Apr 2 16:08:24 UTC 2018 x86_64 Binary: 64bit
2018-04-21T20:43:03+02:00 TS |INFO | | |TeamSpeak 3 Client 3.1.8 (2018-01-22 09:50:07)
2018-04-21T20:43:02+02:00 Starting instance ts3server://manicraft.de?port=9987&nickname=I%E2%99%A5RADIO%20-%20Live&password=&channel=&channelpassword=
2018-04-21T20:43:02+02:00 Could not create Notifications-Tabletable Notifications already exists
2018-04-21T20:43:02+02:00 Could not create WhisperReceive-Tabletable WhisperReceive already exists
2018-04-21T20:43:02+02:00 Could not create Chat-Tabletable Chat already exists
2018-04-21T20:43:00+02:00 BOT-CONFIG [admin] CHAN CHANPW ANNOUNCE DESCRIPTION ANNOUNCESTR TTSURL CC OK
2018-04-21T20:43:00+02:00 Invalid identity, ignoring (V).
2018-04-21T20:42:53+02:00 Error in script (event: setInterval callback): TypeError: Cannot access member 'length' of undefined at Random_GIFs.js:184:43
2018-04-21T20:42:38+02:00 TSClient quit.
2018-04-21T20:42:37+02:00 New connection status 0; Error 0
2018-04-21T20:42:37+02:00 The bot could not connect. This might have several reasons: the server doesn't exist at that address, the server password is wrong, the default channel doesn't exist, the bot has been banned, the server is an illegal installation or the password is wrong , the security level of your identity is too low or the server does not allow the version of the client you are using. See our Wiki / Forums for more help.
2018-04-21T20:42:37+02:00 TS |INFO |ClientUI |1 |Disconnected or forced to leave, want autoreconnect = 0
2018-04-21T20:42:37+02:00 TS |INFO |ClientUI |1 |Connect status: Disconnected
2018-04-21T20:42:37+02:00 TS |DEVELOP |PktHandler | |Puzzle solve time: 6
2018-04-21T20:42:37+02:00 New connection status 1; Error 0
2018-04-21T20:42:37+02:00 TS |INFO |ClientUI |1 |Connect status: Connecting
2018-04-21T20:42:37+02:00 TS |INFO |PreProSpeex |1 |Speex version: 1.2rc1
2018-04-21T20:42:36+02:00 TS |INFO |ClientUI |1 |Initiating connection: 178.198.12.225:9987
2018-04-21T20:42:36+02:00 TS |INFO |ClientUI |1 |Resolve successful: 178.198.12.225:9987
2018-04-21T20:42:36+02:00 TS |INFO |ClientUI |1 |Lookup finished: ip=178.198.12.225 port=9987 query=manicraft.de error=0
2018-04-21T20:42:36+02:00 TS |INFO |TSDNS | |No TSDNS found
2018-04-21T20:42:36+02:00 TS |INFO |TSDNS | |TSDNS queried unsuccessfully 178.198.12.225:41144
2018-04-21T20:42:35+02:00 TS |INFO | | |Statistics report: User has not yet confirmed participation
2018-04-21T20:42:35+02:00 TS |INFO |ClientUI | |Last update check was: Di. Jan. 1 00:00:01 2019
2018-04-21T20:42:35+02:00 TS |INFO |Bookmarks | |Collecting autoconnect bookmarks
2018-04-21T20:42:35+02:00 TS |INFO |TSDNS | |SRV DNS resolve unsuccessful, "_ts3._udp.manicraft.de" DNS server returned answer with no data
2018-04-21T20:42:34+02:00 TS |INFO |TSDNS | |SRV DNS resolve unsuccessful, "_tsdns._tcp.manicraft.de" DNS server returned answer with no data
2018-04-21T20:42:34+02:00 TS |INFO |TSDNS | |A/AAAA DNS resolve for possible TSDNS successful, "manicraft.de" =(h: 178.198.12.225 p:0)
2018-04-21T20:42:34+02:00 TS |INFO |TSDNS | |A/AAAA DNS resolve successful, "manicraft.de" =(h: 178.198.12.225 p:0)
2018-04-21T20:42:34+02:00 TS |INFO |ClientUI |1 |Trying to resolve manicraft.de
2018-04-21T20:42:34+02:00 TS |INFO |ClientUI |1 |Connect to server: manicraft.de
2018-04-21T20:42:34+02:00 TS |INFO |ClientUI | |ts3server: manicraft.de?port=9987&nickname=I%E2%99%A5RADIO%20-%20Live&password=&channel=&channelpassword=
2018-04-21T20:42:34+02:00 TS |INFO |ClientUI | |Using configuration location: /opt/sinusbot/data/ts3/d72115f5-7eea-4a47-99ef-5f9312604711/84de2419-5223-44b0-b5e7-12356c7e706a/settings.db
2018-04-21T20:42:34+02:00 TS |INFO |ClientUI | |Qt version: 5.6.1
2018-04-21T20:42:34+02:00 TS |INFO |ClientUI | |Failed to init text to speech engine
2018-04-21T20:42:34+02:00 TS |DEVELOP |ClientUI | |Notifications init: Soundpack path: /opt/sinusbot/teamspeak3-client/sound/nosounds
2018-04-21T20:42:34+02:00 TS |INFO | | |*** Time [INIT]: 256
2018-04-21T20:42:34+02:00 TS |INFO | | |*** Time [MAINWINDOW]: 255
2018-04-21T20:42:34+02:00 TS |INFO | | |successfully downloaded revocation list
2018-04-21T20:42:34+02:00 TS |INFO |Query | |listening on 127.0.0.1:25639
2018-04-21T20:42:34+02:00 TS |INFO |Plugins | |Loading plugin: libclientquery_plugin_linux_amd64.so
2018-04-21T20:42:34+02:00 TS |INFO |Plugins | |Loading plugin: libsoundbot_plugin.so
2018-04-21T20:42:34+02:00 TS |INFO |Addons | |Checking for addon updates...
2018-04-21T20:42:34+02:00 TS |INFO |ClientUI | |Unable to create an Open GL context.
2018-04-21T20:42:34+02:00 TS |ERROR |SoundBckndIntf| |libpulse.so.0: Kann die Shared-Object-Datei nicht öffnen: Datei oder Verzeichnis nicht gefunden
2018-04-21T20:42:34+02:00 TS |INFO | | |SystemInformation: Linux 4.4.0-119-generic #143-Ubuntu SMP Mon Apr 2 16:08:24 UTC 2018 x86_64 Binary: 64bit
2018-04-21T20:42:34+02:00 TS |INFO | | |TeamSpeak 3 Client 3.1.8 (2018-01-22 09:50:07)
2018-04-21T20:42:34+02:00 Starting instance ts3server://manicraft.de?port=9987&nickname=I%E2%99%A5RADIO%20-%20Live&password=&channel=&channelpassword=
2018-04-21T20:42:33+02:00 Could not create Notifications-Tabletable Notifications already exists
2018-04-21T20:42:33+02:00 Could not create WhisperReceive-Tabletable WhisperReceive already exists
2018-04-21T20:42:33+02:00 Could not create Chat-Tabletable Chat already exists
2018-04-21T20:42:23+02:00 Error in script (event: setInterval callback): TypeError: Cannot access member 'length' of undefined at Random_GIFs.js:184:43
2018-04-21T20:41:53+02:00 Error in script (event: setInterval callback): TypeError: Cannot access member 'length' of undefined at Random_GIFs.js:184:43
2018-04-21T20:41:43+02:00 TSClient quit.
2018-04-21T20:41:42+02:00 New connection status 0; Error 0
2018-04-21T20:41:42+02:00 The bot could not connect. This might have several reasons: the server doesn't exist at that address, the server password is wrong, the default channel doesn't exist, the bot has been banned, the server is an illegal installation or the password is wrong , the security level of your identity is too low or the server does not allow the version of the client you are using. See our Wiki / Forums for more help.
2018-04-21T20:41:42+02:00 TS |INFO |ClientUI |1 |Disconnected or forced to leave, want autoreconnect = 0
2018-04-21T20:41:42+02:00 TS |INFO |ClientUI |1 |Connect status: Disconnected
2018-04-21T20:41:42+02:00 TS |DEVELOP |PktHandler | |Puzzle solve time: 7
2018-04-21T20:41:42+02:00 New connection status 1; Error 0
2018-04-21T20:41:42+02:00 TS |INFO |ClientUI |1 |Connect status: Connecting
2018-04-21T20:41:42+02:00 TS |INFO |PreProSpeex |1 |Speex version: 1.2rc1
LG
Alles ausgeschlossen?
D
Guest
Die Adresse ist korrekt, ein Passwort gibt es nicht, die Channel Eingabe ist leer, der bot ist nicht gebannt, der bot wurde auch korrekt installiert und hat vorher schon mal funktioniert, server funktioniert, passwort gibt es keines, level ist korrekt, und der server lässt die version zu
D
Guest
Ich habe anschliessend die Sicherheitshöhe nach oben gestellt. Jetzt funtioniert es, danke
