BOT NOT Start - panic: runtime error: invalid memory address or nil pointer dereference
bykaan
I can not start. What should I do ?
Version: 0.9.16-10f0fad
2017/01/11 17:57:13 [GENERAL/SCRIPTS] INFO   Loading ScriptPlugin Digital Clock.js
2017/01/11 17:57:13 [GENERAL/SCRIPTS] INFO   Loading ScriptPlugin advertising.js
2017/01/11 17:57:13 [GENERAL/SCRIPTS] INFO   Loading ScriptPlugin aloneMode.js
2017/01/11 17:57:13 [GENERAL/SCRIPTS] INFO   Loading ScriptPlugin badchan.js
[signal 0xb code=0x1 addr=0x0 pc=0x83a79f]
goroutine 8 [running]:
main.func·163()
▒▒▒z▒▒▒ ▒
▒@▒▒Ę▒OlH▒%▒
p▒:249 +0x3f▒g
created by main.LoadScriptPlugins
▒▒▒z▒▒▒ ▒
▒@▒▒Ę▒OlH▒%▒
p▒:273 +0x21dg
goroutine 1 [runnable]:
        ִdQ▒8
▒▒▒Ov▒W%▒?▒▒▒▒▒▒B▒▒kO
▒▒t▒}iI▒E▒ؑ@▒▒▒▒K▒k▒^%▒*▒▒b,▒rd▒(0x0, 0x0)
        4z▒▒▒+▒y▒▒▒3B▒?1▒M▒*[email protected]▒▒.▒▒i_H▒▒▒▒!4▒Q▒▒\▒&Si▒k▒▒:815 +0x39
|▒▒     U▒▒o)▒~&|ɴ#X▒▒▒▒▒q
▒.-d
▒_1▒d~▒{^▒▒"▒▒(0xc208092370, 0x0, 0x0)
        4z▒▒▒+▒y▒▒▒3B▒?1▒M▒*[email protected]▒▒.▒▒i_H▒▒▒▒!4▒Q▒▒\▒&Si▒k▒▒:816 +0x8a
nF▒t▒▒▒▒(▒▒▒*▒m>!▒ʟ▒`▒▒wc▒▒2h1Ss.▒O▒蠽▒=▒▒▒▒끳_%x▒L▒g▒▒"▒mu="▒r▒▒S6▒▒U▒}▒b▒Ap2_v|6ƈ▒!N▒̣(0x0, 0x0)
        4z▒▒▒+▒y▒▒▒3B▒?1▒M▒*[email protected]▒▒.▒▒i_H▒▒▒▒!4▒Q▒▒\▒&Si▒k▒▒:836 +0x39
▒h▒s▒▒▒z▒▒▒^▒MC▒c1MVV▒=2▒▒▒▒▒#yz▒)Z.▒▒'6=r[w▒▒▒▒▒▒J8z▒▒)▒\▒g▒,(0xc208092370, 0x0, 0x0)
        4z▒▒▒+▒y▒▒▒3B▒?1▒M▒*[email protected]▒▒.▒▒i_H▒▒▒▒!4▒Q▒▒\▒&Si▒k▒▒:837 +0x8a
ձ▒▒▒▒[▒▒/'.D]▒▒e▒T      &▒▒(ڀ▒EI▒▒6▒ ▒6▒▒▒R▒V▒b▒@▒▒▒=̀j▒▒M▒▒▒(0xc208092370, 0x0, 0x0)
        ▒▒▒'đ▒:J▒ta▒7▒͌&DSj▒oj▒Շ<▒▒
jZ▒▒Urc▒wV▒▒7▒▒q▒▒:751 +0x167
#▒f▒▒▒B▒$º▒▒▒▒▒▒+v.▒▒▒IN\▒|▒֏▒▒@▒4
2#▒Tg3▒▒▒(0xc208092370, 0x7f97f7fed5d8, 0xc208197dc0, 0x1)
jZ▒▒Urc▒wV▒▒7▒▒q▒▒:553 +0xf8
▒▒m▒9'sw.▒0Ca#▒▒▒D4v>4▒
                       ▒u▒▒s▒▒▒MSJ▒▒@▒▒▒H/2>▒▒'▒▒▒▒▒yb~d▒y7▒(0xc208092370, 0x0, 0x0)
jZ▒▒Urc▒wV▒▒7▒▒q▒▒:639 +0x9e1        ▒▒?▒▒▒#▒▒
▒▒N<▒▒E▒mq
▒`VE▒▒▒iƍӺ▒Z j▒Ʒ▒[email protected](0xc208092370, 0xc208100500, 0xd)
jZ▒▒Urc▒wV▒▒7▒▒q▒▒:296 +0x318
▒▒h▒)▒jR▒▒GԒ▒
D▒c+}v▒R▒▒▒B▒}▒▒m<.▒▒-s]▒/TN▒▒▒▒D▒▒g▒▒▒X$▒
▒Q▒$▒▒]▒▒(0xc208092370, 0x0, 0x0)
        4z▒▒▒+▒y▒▒▒3B▒?1▒M▒*[email protected]▒▒.▒▒i_H▒▒▒▒!4▒Q▒▒\▒&Si▒k▒▒:542 +0x403
▒▒▒▒l}2/▒▒+▒▒X▒;▒`#ri▒▒▒T▒▒1▒▒.n▒U▒VaP▒g4▒Gho▒▒▒▒▒t▒S▒(0xc208092370, 0x0, 0x0)
        4z▒▒▒+▒y▒▒▒3B▒?1▒M▒*[email protected]▒▒.▒▒i_H▒▒▒▒!4▒Q▒▒\▒&Si▒k▒▒:670 +0x8a
        ִdQ▒8
▒.-d
▒^`f▒0▒▒|▒Dif▒▒▒▒x▒▒▒12<▒^▒▒.▒%a%▒▒,3▒͆▒▒VZ▒▒▒J▒(▒"▒▒Ij▒k(0xc208092370, 0xc20814b0a0, 0x1, 0x1, 0x1d7, 0xc208197cc0)
        4z▒▒▒+▒y▒▒▒3B▒?1▒M▒*[email protected]▒▒.▒▒i_H▒▒▒▒!4▒Q▒▒\▒&Si▒k▒▒:395 +0xa1
▒▒h▒)▒jR▒▒GԒ▒
        4z▒▒▒+▒y▒▒▒3B▒?1▒M▒*[email protected]▒▒.▒▒i_H▒▒▒▒!4▒Q▒▒\▒&Si▒k▒▒:555 +0x361
        ִdQ▒8
▒.-d
        4z▒▒▒+▒y▒▒▒3B▒?1▒M▒*[email protected]▒▒.▒▒i_H▒▒▒▒!4▒Q▒▒\▒&Si▒k▒▒:837 +0x8a        ▒▒?▒▒▒#▒▒
▒▒N<▒▒E▒mq
▒`VE▒▒▒iƍӺ▒Z j▒Ʒ▒[email protected](0xc208092370, 0x7f97f7fed000, 0xc20813ea80)
▒▒h▒)▒jR▒▒GԒ▒
goroutine 7 [chan receive]:
database/sql.(*DB).connectionOpener(0xc20805dc20)
        /usr/local/go/src/database/sql/sql.go:589 +0x4c
created by database/sql.Open
        /usr/local/go/src/database/sql/sql.go:452 +0x31c
goroutine 6 [syscall]:
os/signal.loop()
        /usr/local/go/src/os/signal/signal_unix.go:21 +0x1f
created by os/signal.init·1
        /usr/local/go/src/os/signal/signal_unix.go:27 +0x35
goroutine 17 [syscall, locked to thread]:
▒▒▒▒$▒▒<▒M▒▒▒6()
        /usr/local/go/src/runtime/asm_amd64.s:2232 +0x1
Morpheus
OS: Win 10 x64 Pro
CPU: intel Core i7 930 2.8 GHz
8GB
Version: 0.13.37-f37f203
2018/05/18 17:18:30 [GENERAL/SCRIPTS] INFO Loading ScriptPlugin advertising.js
2018/05/18 17:18:30 [GENERAL/SCRIPTS] INFO Loading ScriptPlugin alonemode.js
2018/05/18 17:18:30 [GENERAL/SCRIPTS] INFO Loading ScriptPlugin bookmark.js
2018/05/18 17:18:30 [GENERAL/SCRIPTS] INFO Loading ScriptPlugin followme.js
2018/05/18 17:18:30 [GENERAL/SCRIPTS] INFO Loading ScriptPlugin norecording.js
2018/05/18 17:18:30 [GENERAL/SCRIPTS] INFO Loading ScriptPlugin rememberChannel.js
2018/05/18 17:18:30 [GENERAL/SCRIPTS] INFO Loading ScriptPlugin welcome.js
2018/05/18 17:18:33 ee142b8f INFO Loading instances
2018/05/18 17:18:33 ee142b8f INFO Loading instance://58f6e2e1-a8ef-41c5-bee3-a03f3500a12d
2018/05/18 17:18:33 ee142b8f 58f6e2e1 INFO Initialization complete
2018/05/18 17:18:33 ee142b8f 58f6e2e1 INFO Auto-Starting ee142b8f-b3a5-4bac-9932-8a16c1578f0b/58f6e2e1-a8ef-41c5-bee3-a03f3500a12d in 500 ms...
2018/05/18 17:18:33 [GENERAL/FFMPEG ] INFO FFmpeg/avcodec v3747941; license: LGPL version 3 or later; 572 codecs
2018/05/18 17:18:33 [GENERAL/FFMPEG ] INFO FFmpeg/avformat v3746148; license: LGPL version 3 or later; 146 formats
2018/05/18 17:18:33 [GENERAL/!!!!!!!] NOTICE You may now configure and launch the bots from the webinterface. http://0.0.0.0:8087
2018/05/18 17:18:33 [GENERAL/RADIO ] INFO Could not find RadioStation-Data (or outdated), updating...
[signal 0xc0000005 code=0x0 addr=0x18 pc=0x9a28bd]
goroutine 79 [running]:
(0xc5c220, 0x13678f0)
:531 +0x1dd
:63 +0x65
:161 +0x8b
(0x0, 0xe34390, 0xc0425d2000)
:195 +0x2d
(0xc042538840, 0xc0425388a0)
:1142 +0xc2
:2197 +0x1
[signal 0xc0000005 code=0x0 addr=0x10 pc=0x9a2232]
goroutine 82 [running]:
:531 +0x1dd
:63 +0x65
:161 +0x8b
(0x0, 0x1350e95, 0x0, 0x140a2e70c8a1bf4e)
:116 +0x82
(0x0, 0x0, 0x0, 0xd33ca1, 0x8, 0x9c8cc8fce8b9fe68, 0xccae2052d4c276cd)
:42 +0x65
(0xc0425d2000, 0xc042538840, 0xc0425388a0)
:1094 +0x71
:2197 +0x1
