Bot stops to work after some hours
nicolatex
Hi, I have an issue with Sinusbot. It streams well any radio for some hours and after It stops to work magically.
After this stops, every time I must quit and restart the bot to fix it.
  • used version: 0.9.12.3-36fce3c
  • used operating system: Ubuntu Desktop 12.04
  • hardware specs: VPS, 1 CORE 2.30GHz, 1 GB RAM)
  • used browser: Chrome 53.0.2785.143m
  • my config.ini is in the attached files (Look also the log, please: There is music until 18:00. Music goes off between 18-19. I see the problem at 19. I quit: 2016/10/20 19:32:25 25d51478 5cb0e509 INFO KILL [ADMINandrix] OK)
Where is the problem? Can you help me, please?
  • log.txt
  • config-ini.txt
Floflobel
I had the same problem due to a plugin.
Backup all plugins and remove this.
Test again ..
Although I don't think the problem comes from there, according to the log
