JohnnyKing94
The bot user doesn't connect to my teamspeak 3 and i do not know why, probably it's cause by error lines in bold
Used Version: 0.9.8
OS: Ubuntu 12.04 LTS
Hardware: Dedicated Server | Intel(R) Core(TM) i5 CPU 750 @ 2.67GHz, 4 cores | 16GB RAM
Used Browser: Mozilla Firefox for Ubuntu 41.0.2
My Config.ini:
This is the message i get (look the bold lines)
Used Version: 0.9.8
My Config.ini:
TS3Path = "/home/desktop/Pubblici/Programmi/TeamSpeak3-Client-linux_amd64/ts3client_linux_amd64"
ListenHost = "91.121.133.17"
SecretKey = [193, 119, 232, 189, 207, 136, 169, 45, 28, 44, 86, 123, 219, 149, 93, 243, 66, 92, 161, 22, 164, 216, 233, 160, 247, 249, 50, 38, 123, 224, 114, 205]
EnableDebugConsole = true
MTU = 1500
SampleInterval = 100
2015/10/22 17:49:21 1f35d94c INFO Initializing bot://1f35d94c-1e59-46cf-a13c-aa6a7ac64113
2015/10/22 17:49:21 1f35d94c 31c6c6d1 INFO Loaded
2015/10/22 17:49:21 Auto-Starting 1f35d94c-1e59-46cf-a13c-aa6a7ac64113/31c6c6d1-7248-4552-af36-e7c97abb4c5c in 2500 ms...
2015/10/22 17:49:21 FFmpeg/avcodec v3675236; license: LGPL version 2.1 or later; 494 codecs
2015/10/22 17:49:21 FFmpeg/avformat v3674980; license: LGPL version 2.1 or later; 139 formats
2015/10/22 17:49:21 RadioStation data loaded
2015/10/22 17:49:22 Imported radio stations
2015/10/22 17:49:24 1f35d94c 31c6c6d1 DEBUG Could not delete from Notificationsno such table: Notifications
2015/10/22 17:49:24 1f35d94c 31c6c6d1 DEBUG Could not insert into Notifications-Tableno such table: Notifications
2015/10/22 17:49:24 1f35d94c 31c6c6d1 INFO Starting instance ts3server://91.121.133.17?port=9988&nickname=VAG%20%7C%20MusicBot&password=&cid=85&channelpassword=
Crashdump ENABLED, directory is: /home/desktop/Pubblici/Programmi/***/data/ts3/1f35d94c-1e59-46cf-a13c-aa6a7ac64113/31c6c6d1-7248-4552-af36-e7c97abb4c5c/crashdumps
DUMP defined! Dumpdir is: /home/desktop/Pubblici/Programmi/***/data/ts3/1f35d94c-1e59-46cf-a13c-aa6a7ac64113/31c6c6d1-7248-4552-af36-e7c97abb4c5c/crashdumps
2015-10-22 15:49:24.843806|INFO | | |TeamSpeak 3 Client 3.0.18.1 (2015-10-10 15:34:35)
2015-10-22 15:49:24.843903|INFO | | |SystemInformation: Linux 3.8.0-44-generic #66~precise1-Ubuntu SMP Tue Jul 15 04:01:04 UTC 2014 x86_64 Binary: 64bit
2015-10-22 15:49:25.489939|ERROR |SoundBckndIntf| |/home/desktop/Pubblici/Programmi/TeamSpeak3-Client-linux_amd64/soundbackends/libpulseaudio_linux_amd64.so error: NOT_CONNECTED
2015-10-22 15:49:25.995346|ERROR |SoundBckndIntf| |/home/desktop/Pubblici/Programmi/TeamSpeak3-Client-linux_amd64/soundbackends/libpulseaudio_linux_amd64.so error: NOT_CONNECTED
2015-10-22 15:49:26.005602|INFO | | |Loading plugin: libclientquery_plugin
2015-10-22 15:49:26.005666|INFO | | |Loading plugin: liblua_plugin
2015-10-22 15:49:26.005708|INFO | | |Loading plugin: libsoundbot_plugin
2015-10-22 15:49:26.005746|INFO | | |Loading plugin: libtest_plugin
2015-10-22 15:49:26.006727|INFO |Query | |listening on 127.0.0.1:25639
libpng warning: iCCP: known incorrect sRGB profile
2015-10-22 15:49:26.336262|INFO |ClientUI | |Failed to init text to speech engine
2015-10-22 15:49:26.336375|INFO |ClientUI | |Qt version: 5.5.0
2015-10-22 15:49:26.336429|INFO |ClientUI | |Using configuration location: /home/desktop/Pubblici/Programmi/***/data/ts3/1f35d94c-1e59-46cf-a13c-aa6a7ac64113/31c6c6d1-7248-4552-af36-e7c97abb4c5c/settings.db
2015-10-22 15:49:26.634657|INFO |ClientUI | |ts3server: 91.121.133.17?port=9988&nickname=VAG%20%7C%20MusicBot&password=&cid=85&channelpassword=
2015-10-22 15:49:26.635008|INFO |ClientUI |1 |Connect to server: 91.121.133.17
2015-10-22 15:49:26.635612|INFO |ClientUI |1 |Blacklist check ok
2015-10-22 15:49:26.635657|INFO |ClientUI |1 |Initiating connection: 91.121.133.17:9988 91.121.133.17
2015-10-22 15:49:27.013433|INFO |PreProSpeex |1 |Speex version: 1.2rc1
2015-10-22 15:49:27.149251|INFO |ClientUI | |Last update check was: dom gen 1 00:00:01 2017
2015-10-22 15:49:27.149405|INFO |ClientUI | |Checking for update
2015-10-22 15:49:27.373662|INFO |Update | |Checking for updates...
qt.network.ssl: QSslSocket: cannot resolve SSLv2_client_method
qt.network.ssl: QSslSocket: cannot resolve SSLv2_server_method
2015-10-22 15:49:27.516389|INFO |Newsticker | |Newsticker next check: gio ott 22 17:36:14 2015
2015-10-22 15:49:27.633624|INFO |Update | |Check license version: 1
2015-10-22 15:49:27.634548|INFO |LicenseViewer | |License language: en
2015-10-22 15:49:27.634681|INFO |LicenseViewer | |Found cached license for version 1 and language en
2015-10-22 15:49:28.241044|DEBUG |PulseAudio | |connected to pulse audio server
2015-10-22 15:49:28.313359|INFO |Newsticker | |Newsticker received for language en, expires on gio ott 22 18:19:27 2015, next check in 1800 seconds
2015/10/22 17:49:51 1f35d94c 31c6c6d1 DEBUG Storing configuration.
