Bot Verbindet sich nicht
masel123
Hallo mein MusikBot/Sinusbot will sich einfach nicht verbinden :(
Betriebssystem
Debian 7 - 64 Bit (x86_64)
Config
LicenseKey = "6cIQdCbU2BPExm/qmQn5c0jRs/xnPOpABMBNofZcFXo="
  UserAgent = "SinusBot (0.9.12-58b509d)"
Instance-log
2016-05-15T18:25:06+02:00 Storing configuration.
2016-05-15T18:24:44+02:00 EOF
2016-05-15T18:24:44+02:00 TSClient quit.
2016-05-15T18:24:44+02:00 Starting instance ts3server://skymoon.eu?port=9987&nickname=TS3SB-Demobot&password=&cid=29&channelpassword=
2016-05-15T18:24:43+02:00 EOF
2016-05-15T18:24:43+02:00 TSClient quit.
2016-05-15T18:24:43+02:00 Starting instance ts3server://skymoon.eu?port=9987&nickname=TS3SB-Demobot&password=&cid=29&channelpassword=
2016-05-15T18:24:40+02:00 Loading script norecording
2016-05-15T18:24:28+02:00 BOT-CONFIG [admin] CHAN CHANPW ANNOUNCE DESCRIPTION ANNOUNCESTR DUCKING TTSURL CC OK
2016-05-15T18:24:16+02:00 BOT-CONFIG [admin] CHAN CHANPW ANNOUNCE DESCRIPTION ANNOUNCESTR TTSURL CC OK
2016-05-15T18:21:44+02:00 Storing configuration.
2016-05-15T18:21:29+02:00 TSClient quit.
2016-05-15T18:21:29+02:00 EOF
2016-05-15T18:21:29+02:00 TS>/opt/sinusbot/teamspeak3-client/ts3client_linux_amd64: /lib/x86_64-linux-gnu/libc.so.6: version `GLIBC_2.14' not found (required by /opt/sinusbot/teamspeak3-client/libc++abi.so.1)
2016-05-15T18:21:29+02:00 TS>/opt/sinusbot/teamspeak3-client/ts3client_linux_amd64: /lib/x86_64-linux-gnu/libc.so.6: version `GLIBC_2.14' not found (required by /opt/sinusbot/teamspeak3-client/libc++.so.1)
2016-05-15T18:21:29+02:00 TS>/opt/sinusbot/teamspeak3-client/ts3client_linux_amd64: /lib/x86_64-linux-gnu/libc.so.6: version `GLIBC_2.14' not found (required by /opt/sinusbot/teamspeak3-client/libQt5Sql.so.5)
2016-05-15T18:21:29+02:00 TS>/opt/sinusbot/teamspeak3-client/ts3client_linux_amd64: /lib/x86_64-linux-gnu/libc.so.6: version `GLIBC_2.14' not found (required by /opt/sinusbot/teamspeak3-client/libQt5Widgets.so.5)
2016-05-15T18:21:29+02:00 TS>/opt/sinusbot/teamspeak3-client/ts3client_linux_amd64: /lib/x86_64-linux-gnu/libc.so.6: version `GLIBC_2.14' not found (required by /opt/sinusbot/teamspeak3-client/libQt5Network.so.5)
2016-05-15T18:21:29+02:00 TS>/opt/sinusbot/teamspeak3-client/ts3client_linux_amd64: /lib/x86_64-linux-gnu/libc.so.6: version `GLIBC_2.14' not found (required by /opt/sinusbot/teamspeak3-client/libQt5Gui.so.5)
2016-05-15T18:21:29+02:00 TS>/opt/sinusbot/teamspeak3-client/ts3client_linux_amd64: /lib/x86_64-linux-gnu/libc.so.6: version `GLIBC_2.14' not found (required by /opt/sinusbot/teamspeak3-client/libQt5Core.so.5)
2016-05-15T18:21:29+02:00 TS>/opt/sinusbot/teamspeak3-client/ts3client_linux_amd64: /lib/x86_64-linux-gnu/libc.so.6: version `GLIBC_2.14' not found (required by /opt/sinusbot/teamspeak3-client/libquazip.so)
2016-05-15T18:21:29+02:00 TS>/opt/sinusbot/teamspeak3-client/ts3client_linux_amd64: /lib/x86_64-linux-gnu/libc.so.6: version `GLIBC_2.14' not found (required by /opt/sinusbot/teamspeak3-client/ts3client_linux_amd64)
2016-05-15T18:21:29+02:00 Starting instance ts3server://skymoon.eu?port=9987&nickname=TS3SB-Demobot&password=&channel=&channelpassword=
2016-05-15T18:20:18+02:00 Storing configuration.
2016-05-15T18:19:51+02:00 EOF
2016-05-15T18:19:51+02:00 TSClient quit.
2016-05-15T18:19:51+02:00 Starting instance ts3server://skymoon.eu?port=9987&nickname=TS3SB-Demobot&password=&channel=&channelpassword=
2016-05-15T18:19:49+02:00 Storing configuration.
2016-05-15T18:19:23+02:00 EOF
2016-05-15T18:19:23+02:00 TSClient quit.
2016-05-15T18:19:23+02:00 Starting instance ts3server://skymoon.eu?port=9987&nickname=TS3SB-Demobot&password=&channel=&channelpassword=
2016-05-15T18:19:20+02:00 Storing configuration.
2016-05-15T18:19:16+02:00 EOF
2016-05-15T18:19:16+02:00 TSClient quit.
2016-05-15T18:19:16+02:00 Starting instance ts3server://skymoon.eu?port=9987&nickname=TS3SB-Demobot&password=&channel=&channelpassword=
2016-05-15T18:19:12+02:00 EOF
2016-05-15T18:19:12+02:00 TSClient quit.
2016-05-15T18:19:12+02:00 Starting instance ts3server://skymoon.eu?port=9987&nickname=TS3SB-Demobot&password=&channel=&channelpassword=
2016-05-15T18:18:51+02:00 EOF
2016-05-15T18:18:51+02:00 TSClient quit.
2016-05-15T18:18:51+02:00 Starting instance ts3server://skymoon.eu?port=9987&nickname=TS3SB-Demobot&password=&channel=&channelpassword=
2016-05-15T18:18:51+02:00 Initialization complete
2016-05-15T18:18:51+02:00 Spawning instance shortly due to missing configuration file.
Qhiliqq
Licensed Partner
Da steht doch was du brauchst ;)
Mach mal apt-get install libglib2.0-0 libxcursor1
Danach Bot neustarten
masel123
PHP:
2016-05-15T20:13:58+02:00 Storing configuration.
2016-05-15T20:13:50+02:00 EOF
2016-05-15T20:13:50+02:00 TSClient quit.
2016-05-15T20:13:50+02:00 Starting instance ts3server://skymoon.eu?port=9987&nickname=TS3SB-Demobot&password=&channel=&channelpassword=
2016-05-15T20:13:29+02:00 EOF
2016-05-15T20:13:29+02:00 TSClient quit.
2016-05-15T20:13:29+02:00 Starting instance ts3server://skymoon.eu?port=9987&nickname=TS3SB-Demobot&password=&channel=&channelpassword=
2016-05-15T20:13:29+02:00 Initialization complete
2016-05-15T20:13:29+02:00 Spawning instance shortly due to missing configuration file.
