xxxjasonjxxx
Moin ich habe jetzt sehr viel probiert und etliche ,male neu installiert allerding bekomme ich den bot absolut nicht zum laufen kann vielleicht wer weiter helfen ?
[2020-01-18 08:42:40] [DEBUG] Done.
[/CODE]
config.ini data icudt62l.dat libavfilter.so.6 libavutil.so.55 libswresample.so.2 private.dat README.md sinusbot tts
config.ini.dist diagSinusbot.sh libavcodec.so.57 libavformat.so.57 libsbtts_rt.so plugin README_installer.txt scripts teamspeak3-client ttshlpr
root@h2856927:/opt/sinusbot# cd /opt/sinusbot
root@h2856927:/opt/sinusbot# ./diagSinusbot.sh
[2020-01-18 08:42:34] [WELCOME] ================================================
[2020-01-18 08:42:34] [WELCOME] = HELLO! Having an issue? I'm here to assist! =
[2020-01-18 08:42:34] [WELCOME] = =
[2020-01-18 08:42:34] [WELCOME] = Thanks for using this diagnostic script! =
[2020-01-18 08:42:34] [WELCOME] = The more information you provide, the =
[2020-01-18 08:42:34] [WELCOME] = better we can help to solve your problem. =
[2020-01-18 08:42:34] [WELCOME] = The execution may take some moments to =
[2020-01-18 08:42:34] [WELCOME] = collection the most important information =
[2020-01-18 08:42:34] [WELCOME] = of your system and your bot installation. =
[2020-01-18 08:42:34] [WELCOME] = After everything is done, you will get a =
[2020-01-18 08:42:34] [WELCOME] = summarized output ready to copy & paste it =
[2020-01-18 08:42:34] [WELCOME] = within a CODE-tag in the SinusBot forum. =
[2020-01-18 08:42:34] [WELCOME] = [Link: https://forum.sinusbot.com] =
[2020-01-18 08:42:34] [WELCOME] = This script uses DNS resolutions and HTTPS =
[2020-01-18 08:42:34] [WELCOME] = requests to Sinusbot-related domains to =
[2020-01-18 08:42:34] [WELCOME] = check if your network settings are valid. =
[2020-01-18 08:42:34] [WELCOME] = Please also report any feedback or issues =
[2020-01-18 08:42:34] [WELCOME] = related to the script in the official forum. =
[2020-01-18 08:42:34] [WELCOME] = Thank you and happy debugging! =
[2020-01-18 08:42:34] [WELCOME] = -- Patrik Kernstock aka. Patschi. =
[2020-01-18 08:42:34] [WAIT] Press [ENTER] to continue...
[2020-01-18 08:42:36] [INFO] Starting diagSinusbot v0.8.0 [2019-06-16 00:01 UTC]...
[2020-01-18 08:42:36] [INFO] Checking for new diagnostic script version...
[2020-01-18 08:42:36] [OKAY] You are using the latest version.
[2020-01-18 08:42:37] [INFO] Detected operating system: Ubuntu 16.04.6 LTS
[2020-01-18 08:42:37] [INFO] Searching bot binary...
[2020-01-18 08:42:37] [DEBUG] Searching in directory '/opt/sinusbot'...
[2020-01-18 08:42:37] [DEBUG] Binary 'sinusbot' found.
[2020-01-18 08:42:37] [INFO] Binary found.
[2020-01-18 08:42:37] [DEBUG] Collecting information...
[2020-01-18 08:42:37] [INFO] (Scan may take some moments...)
[2020-01-18 08:42:37] [INFO] Collecting system information...
[2020-01-18 08:42:37] [DEBUG] Getting operating system version...
[2020-01-18 08:42:37] [WARNING] It seems your machine is a OpenVZ container. OpenVZ is known for failing on some checks in this diagnostic scripts. These are known limitation s due to restrictions and the nature of the containering software.
[2020-01-18 08:42:37] [DEBUG] Checking DNS resolution...
[2020-01-18 08:42:37] [DEBUG] Checking web IPv4 access...
[2020-01-18 08:42:37] [DEBUG] Checking update server availability...
[2020-01-18 08:42:38] [DEBUG] Checking for locales...
[2020-01-18 08:42:38] [DEBUG] Getting processor information...
lscpu: failed to determine number of CPUs: /sys/devices/system/cpu/possible: No such file or directory
[2020-01-18 08:42:38] [DEBUG] Checking for available operating system updates...
[2020-01-18 08:42:39] [DEBUG] Getting RAM information...
./diagSinusbot.sh: line 1330: 33554432 - : syntax error: operand expected (error token is "- ")
[2020-01-18 08:42:39] [DEBUG] Getting DISK information...
[2020-01-18 08:42:39] [DEBUG] Getting disk info by using command:
[2020-01-18 08:42:39] [DEBUG] $ df -Tl --total -t ext4 -t ext3 -t ext2 -t reiserfs -t jfs -t ntfs -t fat32 -t btrfs -t fuseblk -t simfs
[2020-01-18 08:42:39] [INFO] Collecting bot information...
[2020-01-18 08:42:39] [DEBUG] Trying to get SinusBot version using version parameter...
[2020-01-18 08:42:39] [DEBUG] Loading bot config file...
[2020-01-18 08:42:39] [DEBUG] Determining bot status...
[2020-01-18 08:42:39] [DEBUG] Getting LDD output from bot binary...
[2020-01-18 08:42:39] [DEBUG] Reading ListenPort from bot configuration...
[2020-01-18 08:42:39] [DEBUG] Getting installed bot scripts...
[2020-01-18 08:42:39] [DEBUG] Reading LogLevel from bot configuration...
[2020-01-18 08:42:39] [DEBUG] Reading TS3Path from bot configuration...
[2020-01-18 08:42:39] [DEBUG] Trying to get ts3client version...
[2020-01-18 08:42:39] [DEBUG] Checking installation of bot plugin in ts3client...
[2020-01-18 08:42:39] [DEBUG] Checking if libqxcb-glx-integration.so file exists...
[2020-01-18 08:42:39] [DEBUG] Checking for 'youtube-dl'...
./diagSinusbot.sh: line 730: nc: command not found
xxd: sorry cannot seek.
[2020-01-18 08:42:40] [ERROR] Failed trieving remote time from NTP server time.google.com! Is any firewall blocking the NTP request, or is the DNS resolution failing?
[2020-01-18 08:42:40] [DEBUG] Generating output...
(standard_in) 1: syntax error
./diagSinusbot.sh: line 323: [: -gt: unary operator expected
[CODE]
- Kernel: Linux 4.4.0-042stab141.3 x86_64
- Load Average: 0.17 0.29 0.25
- Uptime: 0 days, 10 hours, 48 minutes, 19 seconds
- OS APT Last Update: 18.01.2020 08:34:55 CET +01:00:00
- Shell Locale: de_DE.utf8
- RAM: B/32.00 GB in use (%)
- SWAP: B/ B in use (%)
- DISK: 9.52 GB/799.76 GB in use (1%)
- libglib: 2.48.2-0ubuntu4.4
- Status: running (PIDs: 9551 9549, User: sinusbot)
- YoutubeDLPath = /usr/local/bin/youtube-dl (does exist, version: 2020.01.15)
linux-vdso.so.1 => (0x00007ffc3ff43000)
libswresample.so.2 => /opt/sinusbot/libswresample.so.2 (0x00007f7a55d3b000)
libavfilter.so.6 => /opt/sinusbot/libavfilter.so.6 (0x00007f7a559e3000)
libavformat.so.57 => /opt/sinusbot/libavformat.so.57 (0x00007f7a555e2000)
libavcodec.so.57 => /opt/sinusbot/libavcodec.so.57 (0x00007f7a54c7c000)
libavutil.so.55 => /opt/sinusbot/libavutil.so.55 (0x00007f7a54a08000)
libdl.so.2 => /lib/x86_64-linux-gnu/libdl.so.2 (0x00007f7a547f4000)
libm.so.6 => /lib/x86_64-linux-gnu/libm.so.6 (0x00007f7a544ea000)
libpthread.so.0 => /lib/x86_64-linux-gnu/libpthread.so.0 (0x00007f7a542cd000)
libstdc++.so.6 => /usr/lib/x86_64-linux-gnu/libstdc++.so.6 (0x00007f7a53f4b000)
libgcc_s.so.1 => /lib/x86_64-linux-gnu/libgcc_s.so.1 (0x00007f7a53d34000)
libc.so.6 => /lib/x86_64-linux-gnu/libc.so.6 (0x00007f7a5396a000)
libz.so.1 => /lib/x86_64-linux-gnu/libz.so.1 (0x00007f7a53750000)
librt.so.1 => /lib/x86_64-linux-gnu/librt.so.1 (0x00007f7a53547000)
/lib64/ld-linux-x86-64.so.2 (0x000055b922e84000)
- Time (local): 18.01.2020 08:42:40 CET +01:00:00
- TeamSpeak3 Version: 3.3.2
- youtube-dl Version: 2020.01.15
[/CODE]
