Bots will not connect
vEGA
Problem:
Sinusbot was running fine for a year now. After updating today TS server, Sinusbot and TS client, bots will not connect to the server anymore.
System:
Debian 9 64 bit
Sinusbot 1.0.0-beta.3-735814e
Teamspeak client 3.3.0
Teamspeak server 3.8.0
Log:
Jul 31 12:44:18 deb9 sinusbot[6557]: 2019/07/31 12:44:18 ec9ecc67 499c76f9 DEBUG Prespawn.
Jul 31 12:44:18 deb9 sinusbot[6557]: 2019/07/31 12:44:18 ec9ecc67 499c76f9 DEBUG About to run.
Jul 31 12:44:18 deb9 sinusbot[6557]: 2019/07/31 12:44:18 ec9ecc67 499c76f9 WARN Could not create Chat-Tabletable Chat already exists
Jul 31 12:44:18 deb9 sinusbot[6557]: 2019/07/31 12:44:18 ec9ecc67 499c76f9 WARN Could not create WhisperReceive-Tabletable WhisperReceive already exists
Jul 31 12:44:18 deb9 sinusbot[6557]: 2019/07/31 12:44:18 ec9ecc67 499c76f9 WARN Could not create Notifications-Tabletable Notifications already exists
Jul 31 12:44:18 deb9 sinusbot[6557]: 2019/07/31 12:44:18 ec9ecc67 499c76f9 DEBUG Could not delete from FileTransferno such table: FileTransfer
Jul 31 12:44:18 deb9 sinusbot[6557]: 2019/07/31 12:44:18 ec9ecc67 499c76f9 DEBUG Could not insert into FileTransfer-Tableno such table: FileTransfer
Jul 31 12:44:18 deb9 sinusbot[6557]: 2019/07/31 12:44:18 ec9ecc67 499c76f9 INFO Starting instance ts3server://ip-adress.com?port=9987&nickname=Willkommensj%C3%BCnger&password=&cid=1&channelpassword=
Jul 31 12:44:18 deb9 sinusbot[6557]: 2019/07/31 12:44:18 ec9ecc67 499c76f9 DEBUG TS>QCoreApplication::applicationDirPath: Please instantiate the QApplication object first
Jul 31 12:44:18 deb9 sinusbot[6557]: 2019/07/31 12:44:18 ec9ecc67 499c76f9 DEBUG TS>qt.qpa.plugin: Could not load the Qt platform plugin "xcb" in "" even though it was found.
Jul 31 12:44:18 deb9 sinusbot[6557]: 2019/07/31 12:44:18 ec9ecc67 499c76f9 DEBUG TS>This application failed to start because no Qt platform plugin could be initialized. Reinstalling the application may fix
Jul 31 12:44:18 deb9 sinusbot[6557]: 2019/07/31 12:44:18 ec9ecc67 499c76f9 DEBUG TS>Available platform plugins are: xcb.
Jul 31 12:44:18 deb9 sinusbot[6557]: 2019/07/31 12:44:18 ec9ecc67 499c76f9 DEBUG Closed.
Jul 31 12:44:18 deb9 sinusbot[6557]: 2019/07/31 12:44:18 ec9ecc67 499c76f9 INFO TSClient quit. LogLevel has been increased, please try to connect again to see more details.
sinusbot.current.tar.bz2
That's not a version number!
Either you go "Settings -> Info -> About" in your website-backend or you post the output of the Diag-Script.
Since you're using TeamSpeak 3.3.0, be sure you are using 1.0.0beta3 or greater.
vEGA
Sorry, I thought current file of today means newest version.
Installed the needed dependencies for TS 3.3.0?
apt install libpci3 libxslt1.1 libxkbcommon0
