Can someone help me with the above problem?
When advancing the song in the sinusbot panel, it most often does this from the above gif. Always skips one or more songs in playback. This only happens with complete playlist that was created by youtube link, the playlist with local songs or downloaded does not happen, they normally play the next song without skipping any.
SinusBot 0.13.37-9791176
Teamspeak 3.1.8 [Stable] em Linux
Youtube dl (March 26, 2018)
Config.ini
TS3Path = "/opt/bot4/teamspeak3-client/ts3client_linux_amd64"
DataDir = "/opt/bot4/data/"
ListenPort = 8090
LogFile = "/opt/bot4/logs.txt"
LicenseKey = "Xja+3msfoRhe0Zel9VyxLSRYmialR6KE7TyDrIwcxlE="
ChunkSize = 5242880
diagSinusbot.sh - Sinusbot diagnostic script
- Operating System: Debian GNU/Linux 8.10 (jessie)
- Kernel: Linux 3.16.0-5-amd64 x86_64
- Load Average: 0.80 3.08 2.59
- Uptime: 6 days, 13 hours, 59 minutes, 15 seconds
- OS APT Last Update: 01.04.2018 04:04:21 EDT -04:00:00
CPU(s): 1
Thread(s) per core: 1
Core(s) per socket: 1
Socket(s): 1
Model name: Intel Core Processor (Haswell, no TSX)
CPU MHz: 2394.472
Virtualization: VT-x
Hypervisor vendor: KVM
Virtualization type: full
- RAM: 842.57 MB/1.91 GB in use (42%)
- DISK: 2.73 GB/6.61 GB in use (41%)
+ libglib: 2.42.1-1+b1
- Status: running (PIDs: 12367 12364, User: bot4)
- Webinterface: port locally reachable (Port: 8090)
- Binary: /opt/bot4/sinusbot
- Binary Info: MD5 Hash: f42a573b7435a8ff04da446d5ccbe754, Perms: 755, User: bot4
- Version: 0.13.37-9791176
- TS3Path = /opt/bot4/teamspeak3-client/ts3client_linux_amd64 (Version 3.1.8)
- YoutubeDLPath = /usr/local/bin/youtube-dl (does exist, version: 2018.03.26.1)
- Installed scripts: advertising.js; alonemode.js; AutomaticServerGroupAssigner.js; bookmark.js; Changecodec.js; defaultChannel+.js; Digital_Clock.js; followme.js; jail.js; norecording.js; OKlib.js; Reconnect.js; rememberChannel.js; welcome.js; Youtube_Search.js
- Time (local): 01.04.2018 08:05:50 EDT -04:00:00
- Time (remote): 01.04.2018 08:05:50 EDT -04:00:00
- Timezone:
- TeamSpeak 3 Version: 3.1.8
- youtube-dl Version: 2018.03.26.1
- DiagScript Version: 0.7.0
