Bug Can't connect trough the web interface
Vicreaft
So i used he script to install the bot (https://forum.sinusbot.com/resources/sinusbot-installer-script.58/), i can access to my website, but when i enter the login info, the blue bar at the top load.... and after, nothing.
  • used version: Latest
  • used operating system: Debian 8
  • hardware specs: VPS, 4G RAM
  • used browser: tried with a lot of browsers. I can connect with my cell phone (android, firefox), but can't with an emulator on my pc... weird.
  • your config.ini: Since the script made all, i don't know where is my config.ini :////
I have some error when i update trough the script, it seems that i can't install the package "fuse"..
Her is the ssh log:
Start installer now!
This could take a while. Please give it up to 10 minutes!
Setting up fuse (2.9.3-15+deb8u2) ...
Creating fuse device...
/run/udev or .udevdb or .udev presence implies active udev.  Aborting MAKEDEV invocation.
chmod: cannot access '/dev/fuse': No such file or directory
dpkg: error processing package fuse (--configure):
subprocess installed post-installation script returned error exit status 1
Errors were encountered while processing:
fuse
E: Sub-process /usr/bin/dpkg returned an error code (1)
Detected latest TS3-Client version as 3.0.19.1 with download URL http://dl.4players.de/ts/releases/3.0.19.1/TeamSpeak3-Client-linux_amd64-3.0.19.1.run
Installing necessary packages! Please wait...
fuse
Packages installed!
Please enter the name of the sinusbot user. Typically "sinusbot". If it does not exists, the installer will create it.
sinusbot
User "sinusbot" already exists.
Should we change the password of "sinusbot"?
1) Yes
2) No
#? 2
Doesn't change the password.
TS3 already installed!
Downloading latest Sinusbot.
Extracting Sinusbot files.
Sinusbot update done.
/etc/init.d/sinusbot already exists!
Sinusbot stopping now!
Stopping sinusbot...
sinusbot stopped successfully
No Sockets found in /var/run/screen/S-sinusbot.
Inject Cronjob for automatic Sinusbot update...
Inject Sinusbot update cronjob successful.
Starting the Sinusbot.
Using following data:
USER: sinusbot
DIR ROOT: /opt/sinusbot/
BOT RUN CMD: ./sinusbot
Starting sinusbot...
No directory, logging in with HOME=/
sinusbot started successfully
Please wait... This will take 15 seconds!
Update done!
Generated a README_installer.txt in /opt/sinusbot with all commands for the sinusbot...
All right. Everything is installed successfully. Sinusbot is UP on "my.ip:8087" | Username: "admin" | Password: "foobar" :)
Stop it with "/etc/init.d/sinusbot stop".
Also you can enter "/etc/init.d/sinusbot help" for help ;)
Don't forget to rate this script on: https://forum.sinusbot.com/resources/sinusbot-installer-script.58/
Thank you for using this script! :)
rm: cannot remove './sinusbot_installer.sh': No such file or directory
root@askaldya:/opt/ts3soundboard#
Looks like your system has been pretty messed up already before you tried installing the bot. You could run the diagnostic script to get more information.
As author of the install script, @Qhiliqq might want to take a look as well.
Qhiliqq
Licensed Partner
whats exactly your problem?
You can't login right?
If this problem appears delete the /data/ folder in /opt/sinusbot.
And if you read my ressource well, then you should have read this:
Installs everything in /opt/sinusbot!
Qhiliqq
Vicreaft
It is not that i can't login, but the web interface bug at the login wcreen for every browser exepct my android firefox. When i press the login button, a blue bar appears at the top and load, and after the load, nothing happens
Qhiliqq
Licensed Partner
Please send me a screenshot of this.
I never heard about this
Vicreaft
It can't be understandable with a screenshot. Check askaldya.tk:8087 user : ctlserv password :ctlserv
Qhiliqq
Licensed Partner
Send here a screenshot of my requirements to you.
I'll not help you with the bot in TS3 directly, only here.
Qhiliqq
Licensed Partner
I don't know what you mean, the login is normal, no "blue" things...
Raphraph
not working. I have this issue on multiple browsers and computers
I can connect, no matter which Browser I use (Chrome, Firefox, Android Chrome, Safari, Edge).
Try to remove your cookies, clear your cache, remove all saved data for this website.
Vicreaft
Just tried with a computer that i have not touched for years with Windows XP in it, don't work too. Also tried with cleaning caches, cookies, ALL but don't work too. Maybe something in network connection block it. But it is weird, with my phoneand my tablet and the wifi i'm also using with the computer, i can access ://
