Can't start a bot after restarting sinusbot.
Khailz
Version 0.9.9-35a06a3
OS: Linux 64 Bit
Hardware Specs:
Dual Intel Xeon X5650 24 Core
48 GB DDR3 ECC Memory
1 TB 7200 RPM Enterprise SATA Hard Drive
OS: Ubuntu 14.04 64 bit
_________________________________________________________________________________
I discovered that I cannot restart some instances of my bots after I have restarted sinusbot. I receive
KILL [admin] FAILED
After some messing around trying to get the instance to work it came online after a restart but then I couldn't start another instance. It seems to happen only to two of the instances that start at default, (maybe conflicting at start?) and alternate between broken and working.
Changed from root to non-root? Please make sure that the bot-user owns the data-directory and every file in there.
chown -R botuser:botgroup /opt/ts3bot/data
Khailz
The user owns everything in the directory all ready, it wasn't an issue before so I'm sure there is something going wrong. The proceeding errors I receive are the bot trying to start then seemingly just stops midway with not much information.
2015-08-14 11:16:19.623460|INFO    |ClientUI      |  1| Connect status: Establishing connection
2015-08-14 11:16:19.637032|INFO    |ClientUI      |  1| Connect status: Connection established
2015-08-14 11:16:19.637663|INFO    |PermManager   |   | Loading permissions from cache
2015-08-14 11:16:19.929525|INFO    |              |   | Failed to download remote image: Connection refused 1
This message occurs with only one instance randomly. it also happens when there are a lot of instances that start at startup.
Did you upgrade the plugin as well? You could also try to remove the guard library (from that new directory).
Khailz
This is what the instance stops at before starting another instance
2015/08/14 11:34:19 X [MAIN] New connection
2015-08-14 11:34:19.603891|INFO    |              |   | TeamSpeak 3 Client 3.0.16 (2014-08-04 13:42:43)
2015-08-14 11:34:19.604006|INFO    |              |   | SystemInformation: Linux 3.13.0-57-generic #95-Ubuntu SMP Fri Jun 19 09:28:15 UTC 2015 x86_64 B
inary: 64bit
2015-08-14 11:34:19.604095|INFO    |              |   | Using hardware aes
2015/08/14 11:34:19 X [MAIN] Disconnected:  1
2015/08/14 11:34:19 X [MAIN] Disconnected:  2
