Danker Pepers
When I press the start button on the bot, it turns green, but it just turns orange after a few seconds. When I look at the instance log, it says: "TSClient quit." right after starting it.
- Operating System: Ubuntu 16.04 LTS
- Kernel: Linux 4.4.0-24-generic x86_64
- Load Average: 0.50 0.31 0.15
- Uptime: 1 days, 5 hours, 15 minutes, 48 seconds
- OS Updates: 14 (updates available!)
- OS APT Last Update: 29.06.2016 01:43:33 CDT -05:00:00
CPU(s): 3
Thread(s) per core: 1
Core(s) per socket: 3
Socket(s): 1
Model name: Intel(R) Xeon(R) CPU E5-2697 v3 @ 2.60GHz
CPU MHz: 2600.050
Hypervisor vendor: Xen
Virtualization type: full
- RAM: 1.68 GB/2.93 GB in use (57%)
- DISK: 25.38 GB/254.85 GB in use (9%)
> libglib: 2.48.1-1~ubuntu16.04.1
- Binary: /opt/ts3soundboard/ts3bot (Hash: 3b2c7f99a3b0a358e7d328079c4fa8b8)
- Version:
- YoutubeDLPath = /usr/local/bin/youtube-dl (does exist, version: 2016.06.26)
- Report date: 29.06.2016 11:49:00 CDT -05:00:00 (timezone: America/New_York)
- youtube-dl Version: 2016.06.26
- DiagScript version: 0.4.5
