1. The bot currently doesn't work with version 3.1 of the TS client. Please downgrade to an older version. Read this for more information on how to downgrade.
Solved Can't use STREAM
Discussion in 'Bugs & Feature Requests' started by dziudziu, Oct 10, 2017.
  1. dziudziu
    dziudziu Member
    Operating System: Linux
    SinusBot Version: 0.10.7-a91e4b6
    TS3 Version: 3.0.19.4
    Can't USE STREAM
    Example: !stream http://stream.open.fm/2
    This stream is ok :) You can check.
    I have permission :>
    2017-10-10T18:45:21+02:00 Cannot playback URL of type text/plain; charset=utf-8
    2017-10-10T18:45:21+02:00 Server seems broken or unreachable. Maybe ICY? Trying GET
    2017-10-10T18:45:20+02:00 Cannot playback URL of type text/plain; charset=utf-8
    2017-10-10T18:45:20+02:00 Server seems broken or unreachable. Maybe ICY? Trying GET
    2017-10-10T18:45:19+02:00 Server seems broken or unreachable. Maybe ICY? Trying GET
    2017-10-10T18:45:19+02:00 Cannot playback URL of type text/plain; charset=utf-8
    2017-10-10T18:45:18+02:00 Cannot playback URL of type text/plain; charset=utf-8
    2017-10-10T18:45:18+02:00 Server seems broken or unreachable. Maybe ICY? Trying GET
    2017-10-10T18:45:17+02:00 Cannot playback URL of type text/plain; charset=utf-8
    2017-10-10T18:45:17+02:00 Server seems broken or unreachable. Maybe ICY? Trying GET
    2017-10-10T18:45:16+02:00 Cannot playback URL of type text/plain; charset=utf-8
    2017-10-10T18:45:16+02:00 Server seems broken or unreachable. Maybe ICY? Trying GET
    2017-10-10T18:45:15+02:00 Server seems broken or unreachable. Maybe ICY? Trying GET
    2017-10-10T18:45:15+02:00 Cannot playback URL of type text/plain; charset=utf-8
    2017-10-10T18:45:14+02:00 Cannot playback URL of type text/plain; charset=utf-8
    2017-10-10T18:45:14+02:00 Server seems broken or unreachable. Maybe ICY? Trying GET
    2017-10-10T18:45:13+02:00 Cannot playback URL of type text/plain; charset=utf-8
    2017-10-10T18:45:13+02:00 Server seems broken or unreachable. Maybe ICY? Trying GET
    2017-10-10T18:45:12+02:00 Cannot playback URL of type text/plain; charset=utf-8
    2017-10-10T18:45:12+02:00 Server seems broken or unreachable. Maybe ICY? Trying GET
    After update I have this :)
    On 2 VPS update look like good and stream is ok.
    !yt it works perfectly.
    My config:
    LicenseKey = "3rng24sJoWXklOeJX9wwk2dc2ASSvthP/IUdhcWTy2s="
      UserAgent = "SinusBot (0.10.7-a91e4b6)"
  2. Tuetchen
    Tuetchen Donor is awesome! Insider
    Hm the stream is working fine for my bots...
  3. Lightning
    Lightning Member
    Maybe the radio station has blocked your serverip because (as you can see) the error message says that it cannot reach the station.
    For me "!stream http://stream.open.fm/2" works fine.
    I use a LXC container with Debian 9 64bit (Kernel -> Linux CT100 4.10.17-3-pve #1 SMP PVE 4.10.17-23 (Tue, 19 Sep 2017 09:43:50 +0200) x86_64 GNU/Linux) (Just for you as info, if you may want to change the system, so you can test if its an OS issue)
  4. dziudziu
    dziudziu Member
    I cant use all links for !stream
    My stream is broken after update *,*
  5. dziudziu
    dziudziu Member
    If I ping from my vps domain stream.open.fm I have reply :)
  6. dziudziu
    dziudziu Member
    Ok please close. This time is ok :D I don't know how... maybe hosting :>
Share This Page
