Changing security level
comüuterkiller
Hey , my bot wont start because the security level is too low , but I cant change it . Its everytime level 8.
How can I change it ?
you have to create a new Identity in your Local Client or configure your TS3 - Server to Security Level to 8 (Default).
How you can create a Identity can you found here: http://www.dark-alchemy.com/wiki/index.php/Teamspeak_3:_Create_your_Identity
If you have created the identity after the guidance increase the security level to your server.
Next, you export this identity how to do that you'll find at the end of the linked website.
Now you open the exported .ini file and search for identity = "" now copy the string between "" to your Web Interface (Configuration> Instance Settings> Identity) and Save it.
Start your instance again and you're done :)
