its actually getChannelGroup() instead of getChannelGroups()
which makes more sense, because you can only have one channel group at a time afaik.
Also it will not return an array (which is also wrong in the doc) but instead will return a single group object directly
#vote4docfix
PS: client.getURL() is also not documented at all in the docs, pls add. kthxbye
Seems like getChannelGroup() does work, but only partly.
It seems to cache data permanently, it keeps the old one even if I change my channel group, or if I switch channels, etc.
Is there a way to manually purge the cache?
Also another bug since I don't know if I should open another thread for this:
Using Client:getAudioChannel() sometimes causes a nullptr exception, while using Client:getChannels() and getting the first entry doesn't pose any issues.
