Deprecated : Use of "parent" in callables is deprecated in
/var/www/html/forum/src/vendor/league/flysystem-eventable-filesystem/src/EventableFilesystem.php on line
431
If you need help or want to discuss things, you now can also join us on our
Discord Server!
A first preview of the unlimited version of SinusBot can be found in the
Upcoming Changes thread. A version for Windows will follow, but we don't have a release date, yet.
JavaScript is disabled. For a better experience, please enable JavaScript in your browser before proceeding.
You are using an out of date browser. It may not display this or other websites correctly.
You should upgrade or use an
alternative browser .
used version latest from auto install version of linux
used operating system is Centos
hardware specs VPS
used browser (and maybe plugins)
your config.ini
The problem is that sends these errors in the Instance log
2016-06-29T22:39:46+02:00 TSClient quit.
2016-06-29T22:39:46+02:00 Starting instance ts3server://164.132.193.75?port=9987&nickname=MusicBot1&password=&channel=&channelpassword=
2016-06-29T22:31:29+02:00 TSClient quit.
2016-06-29T22:31:29+02:00 Starting instance ts3server://164.132.193.75?port=9987&nickname=MusicBot1&password=&channel=&channelpassword=
2016-06-29T22:31:01+02:00 TSClient quit.
2016-06-29T22:31:01+02:00 Starting instance ts3server://164.132.193.75?port=9987&nickname=MusicBot1&password=&channel=&channelpassword=
2016-06-29T21:54:06+02:00 TSClient quit.
2016-06-29T21:54:06+02:00 Starting instance ts3server://164.132.193.75?port=9987&nickname=MusicBot1&password=&channel=&channelpassword=
2016-06-29T21:51:52+02:00 TSClient quit.
2016-06-29T21:51:52+02:00 Starting instance ts3server://164.132.193.75?port=9987&nickname=MusicBot1&password=&channel=&channelpassword=
2016-06-29T21:36:30+02:00 TSClient quit.
2016-06-29T21:36:30+02:00 Starting instance ts3server://164.132.193.75?port=9987&nickname=MusicBot1&password=&channel=&channelpassword=
2016-06-29T21:36:15+02:00 TSClient quit.
2016-06-29T21:36:15+02:00 Starting instance ts3server://164.132.193.75?port=9987&nickname=MusicBot1&password=&channel=&channelpassword=
2016-06-29T21:35:56+02:00 TSClient quit.
2016-06-29T21:35:56+02:00 Starting instance ts3server://164.132.193.75?port=9987&nickname=MusicBot1&password=&channel=&channelpassword=
2016-06-29T21:32:49+02:00 TSClient quit.
2016-06-29T21:32:49+02:00 Starting instance ts3server://164.132.193.75?port=9987&nickname=MusicBot1&password=&channel=&channelpassword=
2016-06-29T21:32:35+02:00 TSClient quit.
2016-06-29T21:32:35+02:00 Starting instance ts3server://164.132.193.75?port=9987&nickname=MusicBot1&password=&channel=&channelpassword=
2016-06-29T21:31:52+02:00 TSClient quit.
2016-06-29T21:31:52+02:00 Starting instance ts3server://164.132.193.75?port=9987&nickname=MusicBot1&password=&channel=&channelpassword=
2016-06-29T21:31:43+02:00 TSClient quit.
2016-06-29T21:31:43+02:00 Starting instance ts3server://164.132.193.75?port=9987&nickname=MusicBot1&password=&channel=&channelpassword=
2016-06-29T21:31:29+02:00 BOT-CONFIG [admin] CHAN CHANPW ANNOUNCE DESCRIPTION ANNOUNCESTR TTSURL CC OK
2016-06-29T21:31:26+02:00 BOT-CONFIG [admin] NICK NAME HOST CHAN CHANPW ANNOUNCE DESCRIPTION ANNOUNCESTR TTSURL CHATIGNSRV CHATIGNPRIV CC OK
2016-06-29T21:29:35+02:00 TSClient quit.
2016-06-29T21:29:35+02:00 Starting instance ts3server://127.0.0.1?port=9987&nickname=TS3SB-Demobot&password=&channel=&channelpassword=
2016-06-29T21:29:30+02:00 TSClient quit.
2016-06-29T21:29:30+02:00 Starting instance ts3server://127.0.0.1?port=9987&nickname=TS3SB-Demobot&password=&channel=&channelpassword=
2016-06-29T21:28:41+02:00 TSClient quit.
2016-06-29T21:28:41+02:00 Starting instance ts3server://127.0.0.1?port=9987&nickname=TS3SB-Demobot&password=&channel=&channelpassword=
2016-06-29T21:27:56+02:00 PLAYURL [admin] http://streaming207.radionomy.com:80/180 OK
2016-06-29T21:27:56+02:00 PLAYURL [admin] http://streaming208.radionomy.com:80/180 OK
2016-06-29T21:27:54+02:00 PLAYURL [admin] http://streaming208.radionomy.com:80/180 OK
2016-06-29T21:24:15+02:00 TSClient quit.
2016-06-29T21:24:15+02:00 Starting instance ts3server://127.0.0.1?port=9987&nickname=TS3SB-Demobot&password=&channel=&channelpassword=
Any help please?
