Connect problem 3.0.18.2
seniorbaniak
Linux
TS3 Version: 3.0.18.2
problem in code , sinus bot dont connect on my server
2017-11-19T01:17:44+01:00 TSClient quit.
2017-11-19T01:17:43+01:00 New connection status 0; Error 1797
2017-11-19T01:17:43+01:00 The bot could not connect. This might have several reasons: the server doesn't exist at that address, the server password is wrong, the default channel doesn't exist, the bot has been banned, the server is an illegal installation or the password is wrong , the security level of your identity is too low or the server does not allow the version of the client you are using. See our Wiki / Forums for more help.
2017-11-19T01:17:43+01:00 TS |INFO |ClientUI |1 |Failed to connect to server, want autoreconnect = 0
2017-11-19T01:17:43+01:00 TS |INFO |ClientUI |1 |Connect status: Disconnected
2017-11-19T01:17:43+01:00 TS |INFO |ClientUI | |Blacklist check timeout
2017-11-19T01:17:38+01:00 TS |INFO | | |Statistics report: Not yet, next report on Fri Nov 24 01:13:33 2017
2017-11-19T01:17:38+01:00 TS |INFO |ClientUI | |Last update check was: Tue Jan 1 00:00:01 2019
2017-11-19T01:17:38+01:00 New connection status 1; Error 0
2017-11-19T01:17:38+01:00 TS |INFO |ClientUI |1 |Connect status: Connecting
2017-11-19T01:17:38+01:00 TS |INFO |PreProSpeex |1 |Speex version: 1.2rc1
2017-11-19T01:17:38+01:00 TS |INFO |ClientUI |1 |Initiating connection: 31.133.6.21:9987 31.133.6.21
2017-11-19T01:17:38+01:00 TS |INFO |ClientUI |1 |Blacklist check ok
2017-11-19T01:17:38+01:00 TS |INFO |ClientUI |1 |Connect to server: 31.133.6.21
2017-11-19T01:17:38+01:00 TS |INFO |ClientUI | |ts3server: 31.133.6.21?port=9987&nickname=SinusBot&password=&channel=&channelpassword=
2017-11-19T01:17:38+01:00 TS |INFO |ClientUI | |Using configuration location: /opt/sinusbot/data/ts3/bd798523-0ff4-4ae4-95d6-cf1cbf8ce395/1e35a75d-1c83-4f67-864d-99db81c6ca03/settings.db
2017-11-19T01:17:38+01:00 TS |INFO |ClientUI | |Qt version: 5.5.0
2017-11-19T01:17:38+01:00 TS |INFO |ClientUI | |Failed to init text to speech engine
2017-11-19T01:17:38+01:00 TS |INFO |Query | |listening on 127.0.0.1:25639
2017-11-19T01:17:38+01:00 TS |INFO | | |Loading plugin: libtest_plugin
2017-11-19T01:17:38+01:00 TS |INFO | | |Loading plugin: libsoundbot_plugin
2017-11-19T01:17:38+01:00 TS |INFO | | |Loading plugin: liblua_plugin
2017-11-19T01:17:38+01:00 TS |INFO | | |Loading plugin: libclientquery_plugin
2017-11-19T01:17:38+01:00 TS |WARNING |SoundDevManager| |Did not load any sound backends. No (usable) dynamic libraries found.
2017-11-19T01:17:38+01:00 TS |ERROR |SoundBckndIntf| |libpulse.so.0: cannot open shared object file: No such file or directory
2017-11-19T01:17:38+01:00 TS |ERROR |SoundBckndIntf| |libasound.so.2: cannot open shared object file: No such file or directory
2017-11-19T01:17:38+01:00 TS |INFO | | |SystemInformation: Linux 4.9.0-3-amd64 #1 SMP Debian 4.9.30-2+deb9u3 (2017-08-06) x86_64 Binary: 64bit
2017-11-19T01:17:38+01:00 TS |INFO | | |TeamSpeak 3 Client 3.0.18.2 (2015-10-22 11:14:48)
2017-11-19T01:17:38+01:00 Starting instance ts3server://31.133.6.21?port=9987&nickname=SinusBot&password=&channel=&channelpassword=
2017-11-19T01:17:38+01:00 Could not create Notifications-Tabletable Notifications already exists
2017-11-19T01:17:38+01:00 Could not create WhisperReceive-Tabletable WhisperReceive already exists
2017-11-19T01:17:38+01:00 Could not create Chat-Tabletable Chat already exists
PLZ HELP ME
D4rkD0me
The Bot cannot connect to your TeamSpeak:
"The bot could not connect. This might have several reasons: the server doesn't exist at that address, the server password is wrong, the default channel doesn't exist, the bot has been banned, the server is an illegal installation or the password is wrong , the security level of your identity is too low or the server does not allow the version of the client you are using."
Check your TeamSpeak Adress, Password of the TeamSpeak, the default Channel where the Bot connect to or your Bot has been banned.
Also check if the bot can connect to a other Server.
