prodigyguy
I have 4 instances running on port 9987, how can I connect one instance on port 9988 (same ip/vps), when I try to connect this says in instance log:
2018-07-08T18:02:08+02:00 Storing configuration.
2018-07-08T18:02:03+02:00 TSClient quit.
2018-07-08T18:02:03+02:00 Closed.
2018-07-08T18:02:03+02:00 TS>libpng warning: iCCP: known incorrect sRGB profile
2018-07-08T18:02:03+02:00 TS>QXcbIntegration: Cannot create platform OpenGL context, neither GLX nor EGL are enabled
2018-07-08T18:02:03+02:00 TS>Use QT_XKB_CONFIG_ROOT environmental variable to provide an additional search path, add ':' as separator to provide several search paths and/or make sure that XKB configuration data directory contains recent enough contents, to update please see http://cgit.freedesktop.org/xkeyboard-config/ .
2018-07-08T18:02:03+02:00 TS>Qt: Failed to create XKB context!
2018-07-08T18:02:03+02:00 TS>xkbcommon: ERROR: failed to add default include path /usr/share/X11/xkb
2018-07-08T18:02:03+02:00 TS>QCoreApplication::applicationDirPath: Please instantiate the QApplication object first
2018-07-08T18:02:02+02:00 TS |INFO | | |Statistics report: Not yet, next report on Thu Jul 12 14:15:30 2018
2018-07-08T18:02:02+02:00 TS |INFO |ClientUI | |Last update check was: Tue Jan 1 00:00:01 2019
2018-07-08T18:02:02+02:00 TS |INFO |Bookmarks | |Collecting autoconnect bookmarks
