Connection problem
Stadny
Hello, so I'm getting this problem, which is not allowing me to join my bot to TS3 server. This is what it says:
TS>/opt/sinusbot/teamspeak3-client/ts3client_linux_amd64: error while loading shared libraries: libXss.so.1: cannot open shared object file: No such file or directory
Can someone help me what to do ? Thanks in advance.
diagSinusBot log:
- Operating System: Debian GNU/Linux 9.9 (stretch)
- Kernel: Linux 4.9.0-8-amd64 x86_64
- Load Average: 0.29 0.24 0.15
- Uptime: 3 days, 17 hours, 56 minutes, 18 seconds
- OS APT Last Update: 01.08.2019 11:56:48 CEST +02:00:00
- Shell Locale: en_US.UTF-8
CPU(s): 4
Thread(s) per core: 1
Core(s) per socket: 4
Socket(s): 1
Model name: Intel(R) Xeon(R) CPU E5-2630 v4 @ 2.20GHz
CPU MHz: 2199.998
Hypervisor vendor: KVM
Virtualization type: full
- RAM: 531.33 MB/7.80 GB in use (6%)
- DISK: 11.87 GB/195.84 GB in use (6%)
- libglib: 2.50.3-2
- Status: running (PIDs: 2712 2710, User: sinusbot)
- YoutubeDLPath = /usr/local/bin/youtube-dl (does exist, version: 2019.07.30)
linux-vdso.so.1 (0x00007ffd793fb000)
libswresample.so.2 => /opt/sinusbot/libswresample.so.2 (0x00007f97425d9000)
libavfilter.so.6 => /opt/sinusbot/libavfilter.so.6 (0x00007f9742281000)
libavformat.so.57 => /opt/sinusbot/libavformat.so.57 (0x00007f9741e80000)
libavcodec.so.57 => /opt/sinusbot/libavcodec.so.57 (0x00007f974151b000)
libavutil.so.55 => /opt/sinusbot/libavutil.so.55 (0x00007f97412a7000)
libdl.so.2 => /lib/x86_64-linux-gnu/libdl.so.2 (0x00007f97410a3000)
libm.so.6 => /lib/x86_64-linux-gnu/libm.so.6 (0x00007f9740d9f000)
libpthread.so.0 => /lib/x86_64-linux-gnu/libpthread.so.0 (0x00007f9740b82000)
libstdc++.so.6 => /usr/lib/x86_64-linux-gnu/libstdc++.so.6 (0x00007f9740800000)
libgcc_s.so.1 => /lib/x86_64-linux-gnu/libgcc_s.so.1 (0x00007f97405e9000)
libc.so.6 => /lib/x86_64-linux-gnu/libc.so.6 (0x00007f974024a000)
libz.so.1 => /lib/x86_64-linux-gnu/libz.so.1 (0x00007f9740030000)
librt.so.1 => /lib/x86_64-linux-gnu/librt.so.1 (0x00007f973fe28000)
/lib64/ld-linux-x86-64.so.2 (0x00007f97427f3000)
- Time (local): 01.08.2019 12:30:39 CEST +02:00:00
- TeamSpeak3 Version: 3.3.0
- youtube-dl Version: 2019.07.30
