covatar upload problem
Crayne
Servus,
vServer, Ubuntu 14.04, ufw laeuft 8087/tcp ist offen
CoverArt, Covatar und Alone Mode sollen zusammen laufen - keine anderen Scripts aktiviert.
Problem : Avatare werden leider nicht im Client angezeigt - der data/cache ordner selbst ist voll von .png's
2015/10/22 14:32:26 [GENERAL/SCRIPTS] INFO Loading ScriptPlugin advertising.js
2015/10/22 14:32:26 [GENERAL/SCRIPTS] INFO Loading ScriptPlugin aloneMode.js
2015/10/22 14:32:26 [GENERAL/SCRIPTS] INFO Loading ScriptPlugin badchan.js
2015/10/22 14:32:26 [GENERAL/SCRIPTS] INFO Loading ScriptPlugin bookmark.js
2015/10/22 14:32:26 [GENERAL/SCRIPTS] INFO Loading ScriptPlugin covatar.js
2015/10/22 14:32:26 [GENERAL/SCRIPTS] INFO Loading ScriptPlugin dev.js
2015/10/22 14:32:26 [GENERAL/SCRIPTS] INFO Loading ScriptPlugin followme.js
2015/10/22 14:32:26 [GENERAL/SCRIPTS] INFO Loading ScriptPlugin idle.js
2015/10/22 14:32:26 [GENERAL/SCRIPTS] INFO Loading ScriptPlugin metadata.js
2015/10/22 14:32:26 [GENERAL/SCRIPTS] INFO Loading ScriptPlugin norecording.js
2015/10/22 14:32:26 [GENERAL/SCRIPTS] INFO Loading ScriptPlugin showcase.js
2015/10/22 14:32:26 [GENERAL/SCRIPTS] INFO Loading ScriptPlugin welcometext.js
2015/10/22 14:32:26 aeaceac3 INFO Initializing bot://aeaceac3-4220-48a1-91c6-21b6c8cab847
2015/10/22 14:32:26 X [MAIN] Starting up fake x-server...
2015/10/22 14:32:26 aeaceac3 INFO Loading instances
2015/10/22 14:32:26 aeaceac3 INFO Loading instance://affb4100-167f-49e7-9871-9e685f8d8120
2015/10/22 14:32:26 aeaceac3 affb4100 INFO Loading script covatar
2015/10/22 14:32:26 aeaceac3 affb4100 INFO Loading script aloneMode
2015/10/22 14:32:26 aeaceac3 affb4100 INFO Loading script metadata
2015/10/22 14:32:26 aeaceac3 affb4100 INFO Initialization complete
2015/10/22 14:32:26 aeaceac3 affb4100 INFO Auto-Starting aeaceac3-4220-48a1-91c6-21b6c8cab847/affb4100-167f-49e7-9871-9e685f8d8120 in 500 ms...
2015/10/22 14:32:26 aeaceac3 affb4100 INFO Last track was 5f4a2fcb-0504-44bd-ad05-2b60993ea4bc, will auto-play soon
2015/10/22 14:32:26 aeaceac3 INFO Loading instance://b05be666-26fe-4c47-9ecd-1a78e5127788
2015/10/22 14:32:26 aeaceac3 b05be666 INFO Initialization complete
2015/10/22 14:32:26 aeaceac3 b05be666 INFO Last track was 44955d5f-2d3b-4846-b45f-1abd4572bd63, will auto-play soon
2015/10/22 14:32:26 [GENERAL/FFMPEG ] INFO FFmpeg/avcodec v3675236; license: LGPL version 2.1 or later; 494 codecs
2015/10/22 14:32:26 [GENERAL/FFMPEG ] INFO FFmpeg/avformat v3674980; license: LGPL version 2.1 or later; 139 formats
2015/10/22 14:32:26 [GENERAL/YTDL ] INFO youtube-dl checking...
2015/10/22 14:32:27 aeaceac3 affb4100 INFO Auto-Playing last track
2015/10/22 14:32:27 aeaceac3 affb4100 DEBUG Could not delete from Notificationsno such table: Notifications
2015/10/22 14:32:27 aeaceac3 affb4100 DEBUG Could not insert into Notifications-Tableno such table: Notifications
2015/10/22 14:32:27 aeaceac3 affb4100 INFO Starting instance ts3server://<cut>
2015/10/22 14:32:27 X [MAIN] New connection
2015/10/22 14:32:27 aeaceac3 affb4100 WARN Could not upload avatar: Post http://127.0.0.1:8557/api/v1/avatar: dial tcp 127.0.0.1:8557: connection refused
2015/10/22 14:32:27 aeaceac3 affb4100 WARN Could not set description
2015/10/22 14:32:27 aeaceac3 affb4100 DEBUG New channel
2015/10/22 14:32:27 [GENERAL/YTDL ] INFO youtube-dl version compatible, support enabled
2015/10/22 14:32:27 [GENERAL/!!!!!!!] NOTICE You may now configure and launch the bots from the webinterface. http://0.0.0.0:8087
2015/10/22 14:32:27 [GENERAL/RADIO ] INFO RadioStation data loaded
2015/10/22 14:32:27 aeaceac3 b05be666 INFO Auto-Playing last track
2015/10/22 14:32:27 aeaceac3 b05be666 DEBUG New channel
2015/10/22 14:32:28 [GENERAL/RADIO ] INFO Imported radio stations
2015/10/22 14:32:55 aeaceac3 affb4100 DEBUG Storing configuration.
2015/10/22 14:32:55 aeaceac3 b05be666 DEBUG Storing configuration.
2015/10/22 14:32:57 aeaceac3 affb4100 INFO New connection status 1; Error 0
2015/10/22 14:32:57 aeaceac3 affb4100 INFO New connection status 2; Error 0
2015/10/22 14:32:57 aeaceac3 affb4100 INFO New connection status 3; Error 0
2015/10/22 14:32:57 aeaceac3 affb4100 INFO Nasenbaer joined the channel
2015/10/22 14:32:57 aeaceac3 affb4100 INFO Ruebezahl joined the channel
2015/10/22 14:32:57 aeaceac3 affb4100 INFO New connection status 4; Error 0
2015/10/22 14:32:57 aeaceac3 affb4100 DEBUG TS/ERR 2564 e'access to default group is forbidden' x'' r'PR:{a9058037-b163-4135-904d-fdf860f920b6}:15/GCLL'
2015/10/22 14:32:57 aeaceac3 affb4100 DEBUG 2568/insufficient client permissions/b_client_use_channel_commander
EDIT sagt :
Config vergessen ^^
TS3Path = "/home/musicbot/TeamSpeak3-Client-linux_amd64/ts3client_linux_amd64"
MTU = 1500
LogFile = "/home/musicbot/ts3soundboard/sinusbot.log"
LicenseKey = "<zip>"
DisableLocalXServer = false
DebugLocalXServer = false
_______
Jemand einen Tipp für mich ?
Sieht nach einem allgemeinen Problem aus. Ton an sich läuft? Kannst du ggf. mal die Firewall auf dem Loopback-Interface (lo) ausschalten? Das dürfte die Sicherheit nicht gefährden.
Crayne
Bot rennt soweit hervorragend .. bin nur noch am Feintunen ...
folgende Befehle eingehämmert :
ufw allow from 127.0.0.0/8
ufw allow in on lo0
ufw allow out on lo0
so sieht der ufw status jetzt aus :
Status: active
To Action From
22 ALLOW Anywhere
22/tcp ALLOW Anywhere
8087/tcp ALLOW Anywhere
Anywhere on lo0 ALLOW Anywhere
22 (v6) ALLOW Anywhere (v6)
22/tcp (v6) ALLOW Anywhere (v6)
8087/tcp (v6) ALLOW Anywhere (v6)
Anywhere (v6) on lo0 ALLOW Anywhere (v6)
Anywhere ALLOW OUT Anywhere on lo0
Anywhere (v6) ALLOW OUT Anywhere (v6) on lo0
___
log nach Restart :
2015-10-22T15:38:52+02:00 Could not upload avatar: Post http://127.0.0.1:8557/api/v1/avatar: dial tcp 127.0.0.1:8557: connection refused
2015-10-22T15:38:52+02:00 Could not set description
Hmm, kannst du den Bot mal beenden und gucken, ob noch alte Client-Prozesse laufen und die ggf. manuell killen, bevor du den Bot neu startest?
Crayne
nach einem kompletten reboot, selbe Fehlermeldung.
2015/10/22 15:53:30 aeaceac3 affb4100 INFO Auto-Playing last track
2015/10/22 15:53:30 aeaceac3 affb4100 DEBUG Could not delete from Notificationsno such table: Notifications
2015/10/22 15:53:30 aeaceac3 affb4100 DEBUG Could not insert into Notifications-Tableno such table: Notifications
2015/10/22 15:53:30 aeaceac3 affb4100 WARN Could not set description
2015/10/22 15:53:30 aeaceac3 affb4100 WARN Could not upload avatar: Post http://127.0.0.1:8557/api/v1/avatar: dial tcp 127.0.0.1:8557: connection refused
2015/10/22 15:53:30 aeaceac3 affb4100 DEBUG New channel
2015/10/22 15:53:30 aeaceac3 affb4100 INFO Starting instance ts3server:/
... warum wird denn erst der Avatar geladen dann die Instanz gestartet ?
Ich vermute dabei handelt es sich einfach um eine verzögerung wie die Logroutine die Daten schmeisst ;)
Ach moment - funktioniert es denn dann beim zweiten Track, wenn der Bot schon ein paar Minuten online war?
Crayne
Nein... hatte ich schon geschaut - funktioniert ebenfalls nicht ..
aber ich schau grade mal wie gross die max Avatargroesse ist in der Usergroup ...
wobei dann aber ein "connection refused" nicht passen würde...
Phew ;) Ich muss da wohl mal mehr Checks einbauen...
