Kaczuc
Hello, I have a bot problem which is time to turn off the screen nwm why this is happening
Version
Sinusbot version: 0.13.37-9791176
TS Client: 3.1.8
Server version: 3.0.13.8 (19.07.2017 10:26:51) on
Operating system: Debian 8, 64bit
CPU VPS: Intel(R) Xeon(R) CPU E5-2680 0 @ 2.70GHz
MEMORY VPS: 3GB
Used browser: Google Chrome
plugin: none
Config.ini:
Last logs before switching off:
Version
TS Client: 3.1.8
MEMORY VPS: 3GB
plugin: none
Config.ini:
DataDir = "/home/sinusbot/data/"
LicenseKey = "Tkh4DYAUITYaDbjEtiWv4jE9lMaw6RG6aLZXHxTXEik="
ChunkSize = 5242880
AllowGIF = true
[Scripts.Privileges]
avatarbanner = ["graphics"]
2018-04-02T12:46:03+02:00 Could not send config: HTTP returned an error: Error; Code: 500; Message: Error
2018-04-02T12:46:03+02:00 Could not send var command: HTTP returned an error: Error; Code: 500; Message: Error
2018-04-02T12:46:02+02:00 Could not remove avatar: HTTP returned an error: Error; Code: 500; Message: Error
2018-04-02T12:46:02+02:00 banner creation already in progress for avatarbanner
2018-04-02T12:46:02+02:00 Could not send var command: HTTP returned an error: Error; Code: 500; Message: Error
2018-04-02T12:46:02+02:00 Could not send config: HTTP returned an error: Error; Code: 500; Message: Error
2018-04-02T12:46:02+02:00 Could not send description command: HTTP returned an error: Error; Code: 500; Message: Error
2018-04-02T12:46:02+02:00 Error on call #5
2018-04-02T12:46:02+02:00 New channel () ID cf17358a-88cf-4213-be1f-fa0c87952bef (cc 0)
2018-04-02T12:46:01+02:00 TS |INFO | | |successfully downloaded revocation list
2018-04-02T12:46:01+02:00 TS |INFO |Plugins | |Loading plugin: libsoundbot_plugin.so
2018-04-02T12:46:01+02:00 TS |INFO |Addons | |Checking for addon updates…
2018-04-02T12:46:01+02:00 TS |INFO |ClientUI | |Unable to create an Open GL context.
2018-04-02T12:46:01+02:00 TS |ERROR |SoundBckndIntf| |libpulse.so.0: the shared object file can not be opened: There is no such file or directory
2018-04-02T12:46:01+02:00 TS |INFO | | |Using hardware aes
2018-04-02T12:46:01+02:00 TS |INFO | | |SystemInformation: Linux 3.16.0-4-amd64 #1 SMP Debian 3.16.7-ckt9-3~deb8u1 (2015-04-24) x86_64 Binary: 64bit
2018-04-02T12:46:01+02:00 TS |INFO | | |TeamSpeak 3 Client 3.1.8 (2018-01-22 09:50:07)
2018-04-02T12:46:01+02:00 TS>DUMP defined! Dumpdir is: /home/sinusbot/data/ts3/5c575faa-a715-43d3-aed4-35acbbf9b5df/951611f3-cd1b-442e-9158-e24bb425c93a/crashdumps
2018-04-02T12:46:01+02:00 TS>Crashdump ENABLED, directory is: /home/sinusbot/data/ts3/5c575faa-a715-43d3-aed4-35acbbf9b5df/951611f3-cd1b-442e-9158-e24bb425c93a/crashdumps
2018-04-02T12:46:00+02:00 Starting instance ts3server://188.116.46.187?port=9987&nickname=BOT&password=&cid=28&channelpassword=
2018-04-02T12:46:00+02:00 Could not insert into FileTransfer-Tableno such table: FileTransfer
2018-04-02T12:46:00+02:00 Could not delete from FileTransferno such table: FileTransfer
2018-04-02T12:46:00+02:00 Could not create Notifications-Tabletable Notifications already exists
2018-04-02T12:46:00+02:00 Could not create WhisperReceive-Tabletable WhisperReceive already exists
2018-04-02T12:46:00+02:00 Could not create Chat-Tabletable Chat already exists
2018-04-02T12:46:00+02:00 About to run.
2018-04-02T12:46:00+02:00 Prespawn.
