Discord bot not working. Error from conn reader.
Ricardoo
Operating System: Windows / Linux
SinusBot Version: 0.9.21-217b2fe
TS3 Version: 3.x.x (don't use it)
Greetings my German and other friends!
Well, prior to this day the bot used to work very well. However today, I wanted to listen to some music, I started the SinusBot (using SinusBot.exe in C:\SinusBot) and I wanted to start up my Discord bot. However, I whenever I clicked the start button, it would turn green for a quick second then turn back red as if disabled. I retried it multiple times, still didn't work. I deleted that Discord bot, created a new one, put in the token and started it again. Still the same results. So it wasn't Discord itself with perhaps an invalid token or something. So, I tried starting SinusBot as an administrator, same results. Since I am absolutely by no means a technical genius like many of you, I just gave up there since I saw no other options. Thus, I came here. The logs below are the only ones that show up. The only difference with log level 10 was the Discord bot account validation, nothing else.
PC Specs:
Operating system: Windows 10, 64-bit
Hardware specs: Nvidia GeForce 960M 2GB (laptop lol), Intel core i7-6700HQ, 8GB RAM.
Browser & plugins: Google Chrome, as for the bot itself, I use no plugins beside YoutubeDL.
2017-12-06T23:11:06+01:00 reconnecting soon
2017-12-06T23:11:06+01:00 disconnected from discord
2017-12-06T23:11:06+01:00 error from conn reader: websocket: close 4012: Requested gateway version is no longer supported or invalid
2017-12-06T23:11:05+01:00 Discord bot account valid (id: 388088396725223424, name: grills pls dm ric he lonely)
2017-12-06T23:11:00+01:00 reconnecting soon
2017-12-06T23:11:00+01:00 disconnected from discord
2017-12-06T23:11:00+01:00 error from conn reader: websocket: close 4012: Requested gateway version is no longer supported or invalid
2017-12-06T23:11:00+01:00 Discord bot account valid (id: 388088396725223424, name: grills pls dm ric he lonely)
2017-12-06T23:10:54+01:00 Initialization complete
It just keeps repeating itself over and over. Nothing new ever being added.
This is my first post, if I did anything wrong, please correct me.
Thanks for reporting!
An upgrade is needed which is already in internal testing and will be released soon.
