Hello there, I would like to suggest to set up statics portsfor Discord.
I'm hosting a sinusbot since a while now, and I was very glad to see the discord feature. But there is something causing issue. From time to time, the port used to send VOIP (I guess? , the sound/music) to Discord server change. I did open 51575 for example, when I first used the discord feature. Today I had to open another port because he was not using 51575 but 50447.
I don't want to change my firewall every few days, and I would like to see some improvement for this matter. IDK if this is even possible, it may be Discord working this way, but maybe if there is a length of ports that can be used, maybe we can force the use of one port someway.
Thanks for reading.
My log :
Thanks for reading.
My log :
2018-06-29T13:33:14+02:00 voice handler returned with: write udp 192.168.10.13:60852->5.200.14.166:50447: write: operation not permitted
2018-06-29T13:32:53+02:00 reconnecting soon
2018-06-29T13:32:53+02:00 disconnected from discord
2018-06-29T13:32:53+02:00 error from conn reader: read tcp 192.168.10.13:49164->104.16.59.37:443: read: connection reset by peer
2018-06-29T13:32:28+02:00 SEEK [admin] 4.531250 OK
2018-06-29T13:32:24+02:00 PLAY [admin] b4484f9b-26c5-4b79-bfe9-ac03e6cb83d5 OK
2018-06-29T13:32:22+02:00 voice handler returned with: write udp 192.168.10.13:39630->5.200.14.166:50447: write: operation not permitted
2018-06-29T13:32:00+02:00 disconnected from discord
2018-06-29T13:32:00+02:00 error from conn reader: read tcp 192.168.10.13:41552->104.16.60.37:443: use of closed network connection
2018-06-29T13:32:00+02:00 KILL [admin] OK
2018-06-29T13:31:15+02:00 voice handler returned with: write udp 192.168.10.13:40122->5.200.14.166:50447: write: operation not permitted
2018-06-28T23:58:54+02:00 voice handler returned with: write udp 192.168.10.13:35735->5.200.14.166:50479: write: operation not permitted
2018-06-28T23:58:29+02:00 reconnecting soon
2018-06-28T23:58:29+02:00 disconnected from discord
2018-06-28T23:58:29+02:00 error from conn reader: websocket: close 1001 (going away)
2018-06-28T22:40:17+02:00 voice handler returned with: write udp 192.168.10.13:46448->5.200.14.166:51002: write: operation not permitted
2018-06-28T22:39:50+02:00 reconnecting soon
2018-06-28T22:39:50+02:00 disconnected from discord
2018-06-28T22:39:50+02:00 error from conn reader: websocket: close 1001 (going away)
2018-06-28T20:01:32+02:00 voice handler returned with: write udp 192.168.10.13:52170->5.200.14.166:51250: write: operation not permitted
2018-06-28T14:42:53+02:00 voice handler returned with: write udp 192.168.10.13:36351->5.200.14.166:50343: write: operation not permitted
2018-06-28T14:42:27+02:00 reconnecting soon
2018-06-28T14:42:27+02:00 disconnected from discord
2018-06-28T14:42:27+02:00 error from conn reader: websocket: close 1006 (abnormal closure): unexpected EOF
2018-06-27T15:37:39+02:00 voice handler returned with: write udp 192.168.10.13:50196->5.200.14.166:51151: write: operation not permitted
2018-06-27T15:37:13+02:00 reconnecting soon
2018-06-27T15:37:13+02:00 disconnected from discord
2018-06-27T15:37:13+02:00 error from conn reader: websocket: close 1006 (abnormal closure): unexpected EOF
2018-06-27T15:12:17+02:00 voice handler returned with: write udp 192.168.10.13:39247->5.200.14.166:50768: write: operation not permitted
2018-06-27T15:11:51+02:00 reconnecting soon
2018-06-27T15:11:51+02:00 disconnected from discord
2018-06-27T15:11:51+02:00 error from conn reader: websocket: close 1006 (abnormal closure): unexpected EOF
2018-06-27T04:00:29+02:00 voice handler returned with: write udp 192.168.10.13:35948->5.200.14.166:51352: write: operation not permitted
2018-06-27T04:00:03+02:00 reconnecting soon
2018-06-27T04:00:03+02:00 disconnected from discord
2018-06-27T04:00:03+02:00 error from conn reader: read tcp 192.168.10.13:59826->104.16.60.37:443: read: connection reset by peer
2018-06-27T03:45:06+02:00 voice handler returned with: write udp 192.168.10.13:59518->5.200.14.166:50202: write: operation not permitted
2018-06-27T03:44:41+02:00 reconnecting soon
2018-06-27T03:44:41+02:00 disconnected from discord
2018-06-27T03:44:41+02:00 error from conn reader: read tcp 192.168.10.13:59816->104.16.60.37:443: read: connection reset by peer
2018-06-27T03:42:06+02:00 voice handler returned with: write udp 192.168.10.13:57466->5.200.14.166:51808: write: operation not permitted
2018-06-27T03:41:40+02:00 reconnecting soon
2018-06-27T03:41:40+02:00 disconnected from discord
2018-06-27T03:41:40+02:00 error from conn reader: read tcp 192.168.10.13:58284->104.16.60.37:443: read: connection reset by peer
2018-06-26T20:56:14+02:00 voice handler returned with: write udp 192.168.10.13:54939->5.200.14.166:51590: write: operation not permitted
2018-06-26T20:55:47+02:00 reconnecting soon
2018-06-26T20:55:47+02:00 disconnected from discord
2018-06-26T20:55:47+02:00 error from conn reader: websocket: close 1001 (going away)
2018-06-26T13:42:09+02:00 voice handler returned with: write udp 192.168.10.13:37681->5.200.14.166:50227: write: operation not permitted
