does not work
  • Thread starter Deleted member 3323
  • Start date
D
Deleted member 3323
Guest
Good evening the bot created by me can not access my server Teamspeak 3, I leave you attached the log file of the bot.
2018/02/19 19:39:37 ed0c1d85 509770ee INFO   Starting instance ts3server://127.0.0.1?port=9987&nickname=bottoso%202&password=&channel=&channelpassword=
2018/02/19 19:39:37 X [MAIN] New connection
2018/02/19 19:39:37 ed0c1d85 509770ee DEBUG  TS>Crashdump ENABLED,  directory is: /opt/ts3soundboard/data/ts3/ed0c1d85-9c7c-4079-8e57-5c3f2d3313f8/509770ee-00f0-454b-bd92-f93880be713f/crashdumps
2018/02/19 19:39:37 ed0c1d85 509770ee DEBUG  TS>DUMP defined! Dumpdir is: /opt/ts3soundboard/data/ts3/ed0c1d85-9c7c-4079-8e57-5c3f2d3313f8/509770ee-00f0-454b-bd92-f93880be713f/crashdumps
2018/02/19 19:39:37 ed0c1d85 509770ee INFO   TS |INFO    |              |   |TeamSpeak 3 Client 3.0.18.2 (2015-10-22 11:14:48)
2018/02/19 19:39:37 ed0c1d85 509770ee INFO   TS |INFO    |              |   |SystemInformation: Linux 3.13.0-141-generic #190-Ubuntu SMP Fri Jan 19 12:52:38 UTC 2018 x86_64 Binary: 64bit
2018/02/19 19:39:37 ed0c1d85 509770ee INFO   TS |INFO    |              |   |Using hardware aes
2018/02/19 19:39:37 ed0c1d85 509770ee INFO   TS |ERROR   |PulseAudio    |   |failed to connect to pulse audio server
2018/02/19 19:39:37 ed0c1d85 509770ee INFO   TS |ERROR   |PulseAudio    |   |pa_context_connect failed
2018/02/19 19:39:37 ed0c1d85 509770ee INFO   TS |ERROR   |SoundBckndIntf|   |/opt/ts3soundboard/TeamSpeak3-Client-linux_amd64/soundbackends/libpulseaudio_linux_amd64.so error: INIT_PA_IMPL
2018/02/19 19:39:37 ed0c1d85 509770ee INFO   TS |INFO    |              |   |Loading plugin: libclientquery_plugin
2018/02/19 19:39:37 ed0c1d85 509770ee INFO   TS |INFO    |              |   |Loading plugin: liblua_plugin
2018/02/19 19:39:37 ed0c1d85 509770ee INFO   TS |INFO    |              |   |Loading plugin: libsoundbot_plugin
2018/02/19 19:39:37 ed0c1d85 509770ee INFO   TS |INFO    |              |   |Loading plugin: libtest_plugin
2018/02/19 19:39:37 ed0c1d85 509770ee INFO   TS |INFO    |Query         |   |listening on 127.0.0.1:25639
2018/02/19 19:39:37 ed0c1d85 509770ee DEBUG  TS>ClientQueryPlugin: currentServerConnectionChanged 1 (0)
2018/02/19 19:39:37 ed0c1d85 509770ee INFO   TS |INFO    |              |   |*** Time [MAINWINDOW]: 177
2018/02/19 19:39:37 ed0c1d85 509770ee INFO   TS |INFO    |              |   |*** Time [INIT]: 177
2018/02/19 19:39:37 ed0c1d85 509770ee INFO   TS |INFO    |ClientUI      |   |Failed to init text to speech engine
2018/02/19 19:39:37 ed0c1d85 509770ee INFO   TS |INFO    |ClientUI      |   |Qt version: 5.5.0
2018/02/19 19:39:37 ed0c1d85 509770ee INFO   TS |INFO    |ClientUI      |   |Using configuration location: /opt/ts3soundboard/data/ts3/ed0c1d85-9c7c-4079-8e57-5c3f2d3313f8/509770ee-00f0-454b-bd92-f93880be713f/settings.db
2018/02/19 19:39:38 ed0c1d85 509770ee INFO   TS |INFO    |ClientUI      |   |ts3server: 127.0.0.1?port=9987&nickname=bottoso%202&password=&channel=&channelpassword=
2018/02/19 19:39:38 ed0c1d85 509770ee INFO   TS |INFO    |ClientUI      |1  |Connect to server: 127.0.0.1
2018/02/19 19:39:38 ed0c1d85 509770ee INFO   TS |INFO    |ClientUI      |1  |Blacklist check ok
2018/02/19 19:39:38 ed0c1d85 509770ee INFO   TS |INFO    |ClientUI      |1  |Initiating connection: 127.0.0.1:9987 127.0.0.1
2018/02/19 19:39:38 ed0c1d85 509770ee INFO   TS |INFO    |PreProSpeex   |1  |Speex version: 1.2rc1
2018/02/19 19:39:38 ed0c1d85 509770ee INFO   TS |INFO    |ClientUI      |1  |Connect status: Connecting
2018/02/19 19:39:38 ed0c1d85 509770ee INFO   New connection status 1; Error 0
2018/02/19 19:39:38 ed0c1d85 509770ee INFO   TS |DEVELOP |PktHandler    |   |Puzzle solve time: 3
2018/02/19 19:39:38 ed0c1d85 509770ee INFO   The bot could not connect. This might have several reasons: the server doesn't exist at that address, the server password is wrong, the default channel doesn't exist, the bot has been banned, the server is an illegal installation or the password is wrong , the security level of your identity is too low or the server does not allow the version of the client you are using. See our Wiki / Forums for more help.
2018/02/19 19:39:38 ed0c1d85 509770ee INFO   New connection status 0; Error 0
2018/02/19 19:39:38 ed0c1d85 509770ee INFO   TS |INFO    |ClientUI      |1  |Connect status: Disconnected
2018/02/19 19:39:38 ed0c1d85 509770ee INFO   TS |INFO    |ClientUI      |1  |Disconnected or forced to leave, want autoreconnect = 0
2018/02/19 19:39:38 ed0c1d85 509770ee INFO   TS |INFO    |ClientUI      |   |Last update check was: Tue Jan 1 00:00:01 2019
2018/02/19 19:39:38 ed0c1d85 509770ee INFO   TS |INFO    |              |   |Statistics report: Not yet, next report on Mon Mar 5 19:28:36 2018
2018/02/19 19:39:39 ed0c1d85 509770ee INFO   TSClient quit.
2018/02/19 19:39:39 ed0c1d85 509770ee DEBUG  Closed.
2018/02/19 19:39:45 ed0c1d85 509770ee DEBUG  Storing configuration.
You are using a outdated TeamSpeakClient and Sinusbot please update both to the latest stable Version available
3.0.18.x is not the latest TeamSpeak Client the newest Version of Sinusbot does not work with 3.0.x TeamSpeak Client
Best way is to use this Script to install your Bot with this Script https://sinusbot-installer.de/
D
Deleted member 3323
Guest
@Multivitamin same problem, but the problem comes with a precise teamspeak server with the other works, despite the two teamspeak in which I tried them I downloaded them from the same site
2018/02/19 21:20:09 5ead14f2 e4922266 INFO   Starting instance ts3server://127.0.0.1?port=9987&nickname=SinusBot&password=&channel=&channelpassword=
2018/02/19 21:20:09 X [MAIN] New connection
2018/02/19 21:20:09 5ead14f2 e4922266 INFO   TS |INFO    |              |   |TeamSpeak 3 Client 3.1.8 (2018-01-22 09:50:07)
2018/02/19 21:20:09 5ead14f2 e4922266 INFO   TS |INFO    |              |   |SystemInformation: Linux 3.13.0-141-generic #190-Ubuntu SMP Fri Jan 19 12:52:38 UTC 2018 x86_64 Binary: 64bit
2018/02/19 21:20:09 5ead14f2 e4922266 INFO   TS |INFO    |              |   |Using hardware aes
2018/02/19 21:20:09 5ead14f2 e4922266 INFO   TS |ERROR   |PulseAudio    |   |failed to connect to pulse audio server -
2018/02/19 21:20:09 5ead14f2 e4922266 INFO   TS |ERROR   |PulseAudio    |   |pa_context_connect failed -
2018/02/19 21:20:09 5ead14f2 e4922266 INFO   TS |ERROR   |SoundBckndIntf|   |/opt/sinusbot/teamspeak3-client/soundbackends/libpulseaudio_linux_amd64.so error: INIT_PA_IMPL
2018/02/19 21:20:09 5ead14f2 e4922266 INFO   TS |INFO    |ClientUI      |   |Unable to create an Open GL context.
2018/02/19 21:20:09 5ead14f2 e4922266 INFO   TS |INFO    |Addons        |   |Checking for addon updates...
2018/02/19 21:20:09 5ead14f2 e4922266 INFO   TS |INFO    |Plugins       |   |Loading plugin: libsoundbot_plugin.so
2018/02/19 21:20:09 5ead14f2 e4922266 INFO   TS |INFO    |              |   |successfully downloaded revocation list
2018/02/19 21:20:09 5ead14f2 e4922266 INFO   TS |INFO    |              |   |*** Time [MAINWINDOW]: 212
2018/02/19 21:20:09 5ead14f2 e4922266 INFO   TS |INFO    |              |   |*** Time [INIT]: 212
2018/02/19 21:20:09 5ead14f2 e4922266 INFO   TS |DEVELOP |ClientUI      |   |Notifications init: Soundpack path: /opt/sinusbot/teamspeak3-client/sound/nosounds
2018/02/19 21:20:09 5ead14f2 e4922266 INFO   TS |INFO    |ClientUI      |   |Failed to init text to speech engine
2018/02/19 21:20:09 5ead14f2 e4922266 INFO   TS |INFO    |ClientUI      |   |Qt version: 5.6.1
2018/02/19 21:20:09 5ead14f2 e4922266 INFO   TS |INFO    |ClientUI      |   |Using configuration location: /opt/sinusbot/data/ts3/5ead14f2-11d1-44fb-a30b-9ee46a1ad8fb/e4922266-a07c-403f-83a1-d95c4d17bcd5/settings.db
2018/02/19 21:20:09 5ead14f2 e4922266 INFO   TS |INFO    |ClientUI      |   |ts3server: 127.0.0.1?port=9987&nickname=SinusBot&password=&channel=&channelpassword=
2018/02/19 21:20:09 5ead14f2 e4922266 INFO   TS |INFO    |ClientUI      |1  |Connect to server: 127.0.0.1
2018/02/19 21:20:09 5ead14f2 e4922266 INFO   TS |INFO    |ClientUI      |1  |Initiating connection: 127.0.0.1:9987
2018/02/19 21:20:09 5ead14f2 e4922266 INFO   TS |INFO    |PreProSpeex   |1  |Speex version: 1.2rc1
2018/02/19 21:20:09 5ead14f2 e4922266 INFO   TS |INFO    |ClientUI      |1  |Connect status: Connecting
2018/02/19 21:20:09 5ead14f2 e4922266 INFO   New connection status 1; Error 0
2018/02/19 21:20:09 5ead14f2 e4922266 INFO   TS |DEVELOP |PktHandler    |   |Puzzle solve time: 3
2018/02/19 21:20:09 5ead14f2 e4922266 INFO   TS |INFO    |ClientUI      |1  |Connect status: Disconnected
2018/02/19 21:20:09 5ead14f2 e4922266 INFO   TS |INFO    |ClientUI      |1  |Disconnected or forced to leave, want autoreconnect = 0
2018/02/19 21:20:09 5ead14f2 e4922266 INFO   The bot could not connect. This might have several reasons: the server doesn't exist at that address, the server password is wrong, the default channel doesn't exist, the bot has been banned, the server is an illegal installation or the password is wrong , the security level of your identity is too low or the server does not allow the version of the client you are using. See our Wiki / Forums for more help.
2018/02/19 21:20:09 5ead14f2 e4922266 INFO   New connection status 0; Error 0
2018/02/19 21:20:10 5ead14f2 e4922266 INFO   TS |INFO    |Bookmarks     |   |Collecting autoconnect bookmarks
2018/02/19 21:20:10 5ead14f2 e4922266 INFO   TS |INFO    |ClientUI      |   |Last update check was: Tue Jan 1 00:00:01 2019
2018/02/19 21:20:10 5ead14f2 e4922266 INFO   TS |INFO    |              |   |Statistics report: Not yet, next report on Thu Mar 15 21:19:23 2018
2018/02/19 21:20:10 5ead14f2 e4922266 INFO   TSClient quit. LogLevel has been increased, please try to connect again to see more details.
2018/02/19 21:20:22 5ead14f2 e4922266 DEBUG  Storing configuration.
Please provide the full log and the output of the diag script
And please check if you fulfill all requirements
