Solved [EN][PROBLEM] TSClient quit.
twyK
When i start the bot it say "TSClient quit"
/opt/ts3soundboard$ xinit /opt/ts3soundboard/ts3bot -- /usr/bin/Xvfb :1 -screen 0 800x600x16 -ac
[dix] Could not init font path element /usr/share/fonts/X11/Type1, removing from list!
2015/08/29 20:19:38 fb8b152d INFO Initializing bot://fb8b152d-a00a-4012-b8e7-4dc9b37fd4b7
2015/08/29 20:19:39 fb8b152d bcf02f0f INFO Loaded
2015/08/29 20:19:39 Auto-Starting fb8b152d-a00a-4012-b8e7-4dc9b37fd4b7/bcf02f0f-41b7-42ca-9cc0-46588b8dcc48 in 2500 ms...
2015/08/29 20:19:39 FFmpeg/avcodec v3675236; license: LGPL version 2.1 or later; 494 codecs
2015/08/29 20:19:39 FFmpeg/avformat v3674980; license: LGPL version 2.1 or later; 139 formats
2015/08/29 20:19:39 RadioStation data loaded
2015/08/29 20:19:39 Imported radio stations
2015/08/29 20:19:41 fb8b152d bcf02f0f INFO Starting instance ts3server://xxx.xxx.xxx?port=9987&nickname=a&password=&channel=&channelpassword=
2015/08/29 20:20:01 fb8b152d bcf02f0f INFO KILL [admin] OK
2015/08/29 20:20:01 fb8b152d bcf02f0f INFO TSClient quit.
2015/08/29 20:20:02 fb8b152d bcf02f0f INFO Starting instance ts3server://xxx.xxx.xxx?port=9987&nickname=a&password=&channel=&channelpassword=
And when i start the ts Client
/opt/ts3soundboard$ xinit /opt/ts3soundboard/TeamSpeak3-Client-linux_amd64/ts3client_linux_amd64 -- /usr/bin/Xvfb :1 -screen 0 800x600x16 -ac
/opt/ts3soundboard/TeamSpeak3-Client-linux_amd64/ts3client_linux_amd64: error while loading shared libraries: libQt5Core.so.5: cannot open shared object file: No such file or directory
I installed this bot in another VPS succesfully, but here it dont work :(
on commandline:
export LD_LIBRARY_PATH="/opt/ts3soundboard/TeamSpeak3-Client-linux_amd64"
then try again to start the client via: xinit /opt/ts3soundboard/TeamSpeak3-Client-linux_amd64/ts3client_linux_amd64 -- /usr/bin/Xvfb :1 -screen 0 800x600x16 -ac
twyK
on commandline:
ty for reply,
but it doesnt work, i tried in normal command line and in xinit command line :(
this is what i see in Instance Log from the Web GUI
2015-08-29T21:06:14+02:00 Loaded
2015-08-29T21:06:16+02:00 Starting instance ts3server://xxx.xxx.xxx?port=9987&nickname=a&password=&channel=&channelpassword=
2015-08-29T21:06:56+02:00 KILL [admin] OK
2015-08-29T21:06:56+02:00 TSClient quit.
Sorry for my bad ENG but im Italian :)
You should start your Teamspeak Client via the command above, not the bot self.
Try the client alone and post the output.
twyK
My bad i tryed again and this is the output
bot@twyk1:/opt/ts3soundboard$ xinit /opt/ts3soundboard/TeamSpeak3-Client-linux_amd64/ts3client_linux_amd64 -- /usr/bin/Xvfb :1 -screen 0 800x600x16 -ac
2015-08-29 22:29:21.192467|INFO | | | TeamSpeak 3 Client 3.0.16 (2014-08-04 13:42:43)
2015-08-29 22:29:21.192548|INFO | | | SystemInformation: Linux 2.6.32-042stab108.5 #1 SMP Wed Jun 17 20:20:17 MSK 2015 x86_64 Binary: 64bit
2015-08-29 22:29:21.192572|INFO | | | Using hardware aes
2015-08-29 22:29:21.197335|ERROR |PulseAudio | | failed to connect to pulse audio server
2015-08-29 22:29:21.197560|ERROR |PulseAudio | | pa_context_connect failed
2015-08-29 22:29:21.197632|ERROR |SoundBckndIntf| | /opt/ts3soundboard/TeamSpeak3-Client-linux_amd64/soundbackends/libpulseaudio_linux_amd64.so error: INIT_PA_IMPL
2015-08-29 22:29:21.211276|INFO | | | Loading plugin: libappscanner_plugin
2015-08-29 22:29:21.211392|INFO | | | Loading plugin: libclientquery_plugin
2015-08-29 22:29:21.211425|INFO | | | Loading plugin: liblua_plugin
2015-08-29 22:29:21.211445|INFO | | | Loading plugin: libsoundbot_plugin
2015-08-29 22:29:21.211464|INFO | | | Loading plugin: libtest_plugin
2015-08-29 22:29:21.212884|INFO |Query | | listening on 127.0.0.1:25639
2015-08-29 22:29:23.607304|INFO | | | *** Time [MAINWINDOW]: 120
2015-08-29 22:29:23.607419|INFO | | | *** Time [INIT]: 120
2015-08-29 22:29:23.607447|INFO |ClientUI | | *** Time [SQLITE_CONVERTER]: 10
2015-08-29 22:29:23.609850|INFO |ClientUI | | Failed to init text to speech engine
2015-08-29 22:29:23.609911|INFO |ClientUI | | Qt version: 5.2.1
2015-08-29 22:29:23.609935|INFO |ClientUI | | Using configuration location: /home/bot/.ts3client/settings.db
2015-08-29 22:29:24.107858|INFO |ClientUI | | Last update check was: Never
2015-08-29 22:29:24.255306|INFO | | | Checking for updates...
2015-08-29 22:29:24.528414|INFO |TSDNS | | DNS resolve successful, "update.teamspeak.com"=46.105.112.65
2015-08-29 22:29:25.844295|INFO | | | Update check, my version: 1407159763, latest version: 1438673913
Okay, the client seems okay.
This is a known bug, some people had this already.
Which version you use? 0.9.8 or 0.9.9?
In your Webinterface ( Settings > Info > About).
twyK
I dont see version info
And under
The MIT License (MIT)
Copyright (C) by the owners (see above).
Permission is hereby granted, free of charge, to any person obtaining a copy
of this software and associated documentation files (the "Software"), to deal
in the Software without restriction, including without limitation the rights
to use, copy, modify, merge, publish, distribute, sublicense, and/or sell
copies of the Software, and to permit persons to whom the Software is
furnished to do so, subject to the following conditions:
The above copyright notice and this permission notice shall be included in
all copies or substantial portions of the Software.
THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS OR
IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF MERCHANTABILITY,
FITNESS FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT. IN NO EVENT SHALL THE
AUTHORS OR COPYRIGHT HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER
LIABILITY, WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING FROM,
OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER DEALINGS IN
THE SOFTWARE.
twyK
I installed a clean Sinusbot and a clean teamspeak in the sinusbot folder
but i have the same problem :(
bot@twyk1:/opt/ts3bot$ ./sinusbot
Version: 0.9.9-6fb4fe2
2015/08/29 23:22:04 [GENERAL/SCRIPTS] INFO Loading ScriptPlugin advertising.js
2015/08/29 23:22:04 [GENERAL/SCRIPTS] INFO Loading ScriptPlugin badchan.js
2015/08/29 23:22:04 [GENERAL/SCRIPTS] INFO Loading ScriptPlugin bookmark.js
2015/08/29 23:22:04 [GENERAL/SCRIPTS] INFO Loading ScriptPlugin followme.js
2015/08/29 23:22:04 [GENERAL/SCRIPTS] INFO Loading ScriptPlugin idle.js
2015/08/29 23:22:04 [GENERAL/SCRIPTS] INFO Loading ScriptPlugin metadata.js
2015/08/29 23:22:04 [GENERAL/SCRIPTS] INFO Loading ScriptPlugin norecording.js
2015/08/29 23:22:04 [GENERAL/SCRIPTS] INFO Loading ScriptPlugin showcase.js
2015/08/29 23:22:04 [GENERAL/SCRIPTS] INFO Loading ScriptPlugin welcometext.js
Generating new bot instance with account 'admin' and password 'foobar'
2015/08/29 23:22:04 X [MAIN] Starting up fake x-server...
2015/08/29 23:22:05 Updating database to v1... 0
2015/08/29 23:22:05 Updating database to v2... 1
2015/08/29 23:22:06 Updating database to v3... 2
2015/08/29 23:22:06 0c04996f INFO Loading instances
2015/08/29 23:22:06 0c04996f INFO Creating default instance
2015/08/29 23:22:06 0c04996f 93cb1aff INFO Starting instance ts3server://127.0.0.1?port=9987&nickname=TS3SB-Demobot&password=&channel=&channelpassword=
2015/08/29 23:22:06 0c04996f INFO Promoting instance to main instance
2015/08/29 23:22:06 X [MAIN] New connection
2015/08/29 23:22:07 0c04996f INFO Adding new useradmin
2015/08/29 23:22:07 [GENERAL/FFMPEG ] INFO FFmpeg/avcodec v3675236; license: LGPL version 2.1 or later; 494 codecs
2015/08/29 23:22:07 [GENERAL/FFMPEG ] INFO FFmpeg/avformat v3674980; license: LGPL version 2.1 or later; 139 formats
2015/08/29 23:22:07 [GENERAL/!!!!!!!] NOTICE You may now configure and launch the bots from the webinterface. http://0.0.0.0:8087
2015/08/29 23:22:07 [GENERAL/RADIO ] INFO Could not find RadioStation-Data, updating...
Crashdump ENABLED, directory is: /opt/ts3bot/data/ts3/0c04996f-53b4-4479-bf76-5333d99e60e0/93cb1aff-2973-4148-8fe5-90c7177f2e28/crashdumps
DUMP defined! Dumpdir is: /opt/ts3bot/data/ts3/0c04996f-53b4-4479-bf76-5333d99e60e0/93cb1aff-2973-4148-8fe5-90c7177f2e28/crashdumps
2015-08-29 20:22:09.258032|INFO | | |TeamSpeak 3 Client 3.0.17 (2015-08-04 07:38:33)
2015-08-29 20:22:09.258115|INFO | | |SystemInformation: Linux 2.6.32-042stab108.5 #1 SMP Wed Jun 17 20:20:17 MSK 2015 x86_64 Binary: 64bit
2015-08-29 20:22:09.258146|INFO | | |Using hardware aes
2015/08/29 23:22:09 X [MAIN] New connection
2015/08/29 23:22:09 X [MAIN] Disconnected: 1
2015-08-29 20:22:09.262228|ERROR |PulseAudio | |failed to connect to pulse audio server
2015-08-29 20:22:09.262453|ERROR |PulseAudio | |pa_context_connect failed
2015-08-29 20:22:09.262519|ERROR |SoundBckndIntf| |/opt/ts3bot/TeamSpeak3-Client-linux_amd64/soundbackends/libpulseaudio_linux_amd64.so error: INIT_PA_IMPL
2015-08-29 20:22:09.274352|INFO | | |Loading plugin: libclientquery_plugin
2015-08-29 20:22:09.274418|INFO | | |Loading plugin: liblua_plugin
2015-08-29 20:22:09.274446|INFO | | |Loading plugin: libsoundbot_plugin
2015-08-29 20:22:09.274471|INFO | | |Loading plugin: libtest_plugin
2015-08-29 20:22:09.275286|INFO |Query | |listening on 127.0.0.1:25639
tracks 10683
2015/08/29 23:22:09 [GENERAL/RADIO ] INFO RadioStation data loaded
2015/08/29 23:22:10 [GENERAL/RADIO ] INFO Imported radio stations
2015/08/29 23:22:11 X [MAIN] Disconnected: 0
2015/08/29 23:22:11 0c04996f 93cb1aff INFO TSClient quit.
2015/08/29 23:22:28 0c04996f INFO LOGIN [admin] OK
2015/08/29 23:23:02 0c04996f 93cb1aff INFO BOT-CONFIG [admin] NICK NAME HOST CHAN CHANPW ANNOUNCE DESCRIPTION ANNOUNCESTR CC OK
2015/08/29 23:23:08 0c04996f 93cb1aff INFO Starting instance ts3server://xxx.xxx.xxx?port=9987&nickname=a&password=&channel=&channelpassword=
2015/08/29 23:23:08 X [MAIN] New connection
2015-08-29 20:23:09.114832|INFO | | |TeamSpeak 3 Client 3.0.17 (2015-08-04 07:38:33)
2015-08-29 20:23:09.114913|INFO | | |SystemInformation: Linux 2.6.32-042stab108.5 #1 SMP Wed Jun 17 20:20:17 MSK 2015 x86_64 Binary: 64bit
2015-08-29 20:23:09.114945|INFO | | |Using hardware aes
2015/08/29 23:23:09 X [MAIN] New connection
2015/08/29 23:23:09 X [MAIN] Disconnected: 3
2015-08-29 20:23:09.118931|ERROR |PulseAudio | |failed to connect to pulse audio server
2015-08-29 20:23:09.119117|ERROR |PulseAudio | |pa_context_connect failed
2015-08-29 20:23:09.119181|ERROR |SoundBckndIntf| |/opt/ts3bot/TeamSpeak3-Client-linux_amd64/soundbackends/libpulseaudio_linux_amd64.so error: INIT_PA_IMPL
2015-08-29 20:23:09.129497|INFO | | |Loading plugin: libclientquery_plugin
2015-08-29 20:23:09.129562|INFO | | |Loading plugin: liblua_plugin
2015-08-29 20:23:09.129590|INFO | | |Loading plugin: libsoundbot_plugin
2015-08-29 20:23:09.129615|INFO | | |Loading plugin: libtest_plugin
2015-08-29 20:23:09.130472|INFO |Query | |listening on 127.0.0.1:25639
2015/08/29 23:23:11 X [MAIN] New connection
2015-08-29 20:23:11.170451|INFO |ClientUI | |Failed to init text to speech engine
2015-08-29 20:23:11.170569|INFO |ClientUI | |Qt version: 5.4.1
2015-08-29 20:23:11.170602|INFO |ClientUI | |Using configuration location: /opt/ts3bot/data/ts3/0c04996f-53b4-4479-bf76-5333d99e60e0/93cb1aff-2973-4148-8fe5-90c7177f2e28/settings.db
2015-08-29 20:23:11.468292|INFO |ClientUI | |ts3server: xxx.xxx.xxx?port=9987&nickname=a&password=&channel=&channelpassword=
2015-08-29 20:23:11.468674|INFO |ClientUI |1 |Connect to server: xxx.xxx.xxx
2015-08-29 20:23:12.292139|INFO |ClientUI |1 |Trying to resolve xxx.xxx.xxx
2015-08-29 20:23:12.293599|INFO |ClientUI | |Last update check was: Sun Jan 1 00:00:01 2017
2015-08-29 20:23:12.293723|INFO |ClientUI | |Checking for update
2015-08-29 20:23:12.459455|INFO |Update | |Checking for updates...
2015-08-29 20:23:12.459965|INFO |Newsticker | |Newsticker language change detected
2015-08-29 20:23:12.460207|INFO |Newsticker | |Newsticker next check:
qt.network.ssl: QSslSocket: cannot resolve SSLv2_client_method
qt.network.ssl: QSslSocket: cannot resolve SSLv2_server_method
2015-08-29 20:23:12.723584|INFO |TSDNS | |DNS resolve successful, "xxx.xxx.xxx"=xxx.xxx.xxx
2015-08-29 20:23:13.210645|INFO |TSDNS | |SRV DNS resolve unsuccessful for "_ts3._udp.xxx.xxx.xxx"
2015-08-29 20:23:13.963478|INFO |Newsticker | |Newsticker received for language en, expires on Sat Aug 29 23:53:12 2015, next check in 1800 seconds
2015-08-29 20:23:14.113869|INFO |Update | |Check license version: 1
2015-08-29 20:23:14.114763|INFO |LicenseViewer | |License language: en
2015-08-29 20:23:14.114833|INFO |LicenseViewer | |Requesting remote license for version 1 and language en
2015-08-29 20:23:14.392727|INFO |LicenseViewer | |Downloaded license file for version 1 and language en
2015-08-29 20:23:16.325312|INFO |ClientUI |1 |Lookup finished: xxx.xxx.xxx 9987 xxx.xxx.xxx 0 0
2015-08-29 20:23:16.325394|INFO |ClientUI |1 |Resolve successful: xxx.xxx.xxx:9987
2015-08-29 20:23:16.325537|INFO |ClientUI |1 |Blacklist check ok
2015-08-29 20:23:16.325575|INFO |ClientUI |1 |Initiating connection: xxx.xxx.xxx:9987 xxx.xxx.xxx
2015-08-29 20:23:17.040204|INFO |PreProSpeex |1 |Speex version: 1.2rc1
2015-08-29 20:23:17.659479|INFO |ClientUI |1 |Connect status: Connecting
2015/08/29 23:23:17 0c04996f 93cb1aff INFO New connection status 1; Error 0
2015-08-29 20:23:22.751049|INFO |ClientUI |1 |Connect status: Disconnected
2015-08-29 20:23:22.751664|INFO |ClientUI |1 |Failed to connect to server, want autoreconnect = 0
2015/08/29 23:23:22 0c04996f 93cb1aff INFO The bot could not connect. This might have several reasons: the server doesn't exist at that address, the server password is wrong or the security level of your identity is too low.
2015/08/29 23:23:22 0c04996f 93cb1aff INFO New connection status 0; Error 1797
2015/08/29 23:23:22 X [MAIN] Disconnected: 4
2015/08/29 23:23:22 X [MAIN] Disconnected: 2
2015/08/29 23:23:22 0c04996f 93cb1aff INFO TSClient quit.
I see this line(The bot could not connect. This might have several reasons: the server doesn't exist at that address, the server password is wrong or the security level of your identity is too low.)
and i checked, the server is up, the server dont have password, and the minimun level is 8 and the bot has 8 :(
Some users had problems to connect local. Others but also on try connect externally . Have you tried to connect to the server at OVH?
twyK
i have a teamspeak server on a VPS hosted in OVH, and im hosting this bot on another server hosted on Gamehosting.it, i cant install the bot on the OVH server because if i do, the server crash (because it had 1GB of ram D: ) but now i will do a server in local in my GH.it (gamehosting.it) VPS and i try to connect it, if you mean connect the bot to the server hosted in OVH i was doing it
Haha okay, yes i meant connect to your normal Teamspeak.
Can you do as root "iptables -L" ? I want to Take a look to your firewall..
twyK
Im using UFW
twyk@twyk1:~/ts3$ sudo ufw status
Status: active
To Action From
53769 ALLOW Anywhere
27015 ALLOW Anywhere
27020/udp ALLOW Anywhere
80 ALLOW Anywhere
27005 ALLOW Anywhere
51840 ALLOW Anywhere
27015/tcp ALLOW Anywhere
27015/udp ALLOW Anywhere
9988/udp ALLOW Anywhere
9987/udp ALLOW Anywhere
30033/tcp ALLOW Anywhere
10011/tcp ALLOW Anywhere
41144/tcp ALLOW Anywhere
2011:2110/udp ALLOW Anywhere
2008/tcp ALLOW Anywhere
2010/udp ALLOW Anywhere
443/tcp ALLOW Anywhere
8080/tcp ALLOW Anywhere
8080/udp ALLOW Anywhere
8087/tcp ALLOW Anywhere
8087/udp ALLOW Anywhere
53769 ALLOW Anywhere (v6)
27015 ALLOW Anywhere (v6)
27020/udp ALLOW Anywhere (v6)
80 ALLOW Anywhere (v6)
27005 ALLOW Anywhere (v6)
51840 ALLOW Anywhere (v6)
27015/tcp ALLOW Anywhere (v6)
27015/udp ALLOW Anywhere (v6)
9988/udp ALLOW Anywhere (v6)
9987/udp ALLOW Anywhere (v6)
30033/tcp ALLOW Anywhere (v6)
10011/tcp ALLOW Anywhere (v6)
41144/tcp ALLOW Anywhere (v6)
2011:2110/udp ALLOW Anywhere (v6)
2008/tcp ALLOW Anywhere (v6)
2010/udp ALLOW Anywhere (v6)
443/tcp ALLOW Anywhere (v6)
8080/tcp ALLOW Anywhere (v6)
8080/udp ALLOW Anywhere (v6)
8087/tcp ALLOW Anywhere (v6)
8087/udp ALLOW Anywhere (v6)
and my bot can connect to 127.0.0.1 ts3 server, so the problem dont is the bot, i tried to disable firewall but it dont work, and user can connect to my OVH server :(
twyK
but the iptables -L is
twyk@twyk1:~/ts3$ sudo iptables -L
Chain INPUT (policy DROP)
target prot opt source destination
ufw-before-logging-input all -- anywhere anywhere
ufw-before-input all -- anywhere anywhere
ufw-after-input all -- anywhere anywhere
ufw-after-logging-input all -- anywhere anywhere
ufw-reject-input all -- anywhere anywhere
ufw-track-input all -- anywhere anywhere
Chain FORWARD (policy DROP)
ufw-before-logging-forward all -- anywhere anywhere
ufw-before-forward all -- anywhere anywhere
ufw-after-forward all -- anywhere anywhere
ufw-after-logging-forward all -- anywhere anywhere
ufw-reject-forward all -- anywhere anywhere
Chain OUTPUT (policy ACCEPT)
ufw-before-logging-output all -- anywhere anywhere
ufw-before-output all -- anywhere anywhere
ufw-after-output all -- anywhere anywhere
ufw-after-logging-output all -- anywhere anywhere
ufw-reject-output all -- anywhere anywhere
ufw-track-output all -- anywhere anywhere
Chain ufw-after-forward (1 references)
Chain ufw-after-input (1 references)
ufw-skip-to-policy-input udp -- anywhere anywhere udp dpt:netbios-ns
ufw-skip-to-policy-input udp -- anywhere anywhere udp dpt:netbios-dgm
ufw-skip-to-policy-input tcp -- anywhere anywhere tcp dpt:netbios-ssn
ufw-skip-to-policy-input tcp -- anywhere anywhere tcp dpt:microsoft-ds
ufw-skip-to-policy-input udp -- anywhere anywhere udp dpt:bootps
ufw-skip-to-policy-input udp -- anywhere anywhere udp dpt:bootpc
ufw-skip-to-policy-input all -- anywhere anywhere ADDRTYPE match dst-type BROADCAST
Chain ufw-after-logging-forward (1 references)
LOG all -- anywhere anywhere limit: avg 3/min burst 10 LOG level warning prefix "[UFW BLOCK] "
Chain ufw-after-logging-input (1 references)
Chain ufw-after-logging-output (1 references)
Chain ufw-after-output (1 references)
Chain ufw-before-forward (1 references)
ufw-user-forward all -- anywhere anywhere
Chain ufw-before-input (1 references)
ACCEPT all -- anywhere anywhere
ACCEPT all -- anywhere anywhere state RELATED,ESTABLISHED
ufw-logging-deny all -- anywhere anywhere state INVALID
DROP all -- anywhere anywhere state INVALID
ACCEPT icmp -- anywhere anywhere icmp destination-unreachable
ACCEPT icmp -- anywhere anywhere icmp source-quench
ACCEPT icmp -- anywhere anywhere icmp time-exceeded
ACCEPT icmp -- anywhere anywhere icmp parameter-problem
ACCEPT icmp -- anywhere anywhere icmp echo-request
ACCEPT udp -- anywhere anywhere udp spt:bootps dpt:bootpc
ufw-not-local all -- anywhere anywhere
ACCEPT udp -- anywhere 224.0.0.251 udp dpt:mdns
ACCEPT udp -- anywhere 239.255.255.250 udp dpt:1900
ufw-user-input all -- anywhere anywhere
Chain ufw-before-logging-forward (1 references)
Chain ufw-before-logging-input (1 references)
Chain ufw-before-logging-output (1 references)
Chain ufw-before-output (1 references)
ufw-user-output all -- anywhere anywhere
Chain ufw-logging-allow (0 references)
LOG all -- anywhere anywhere limit: avg 3/min burst 10 LOG level warning prefix "[UFW ALLOW] "
Chain ufw-logging-deny (2 references)
RETURN all -- anywhere anywhere state INVALID limit: avg 3/min burst 10
Chain ufw-not-local (1 references)
RETURN all -- anywhere anywhere ADDRTYPE match dst-type LOCAL
RETURN all -- anywhere anywhere ADDRTYPE match dst-type MULTICAST
RETURN all -- anywhere anywhere ADDRTYPE match dst-type BROADCAST
ufw-logging-deny all -- anywhere anywhere limit: avg 3/min burst 10
Chain ufw-reject-forward (1 references)
Chain ufw-reject-input (1 references)
Chain ufw-reject-output (1 references)
Chain ufw-skip-to-policy-forward (0 references)
Chain ufw-skip-to-policy-input (7 references)
Chain ufw-skip-to-policy-output (0 references)
Chain ufw-track-input (1 references)
Chain ufw-track-output (1 references)
ACCEPT tcp -- anywhere anywhere state NEW
ACCEPT udp -- anywhere anywhere state NEW
Chain ufw-user-forward (1 references)
Chain ufw-user-input (1 references)
ACCEPT tcp -- anywhere anywhere tcp dpt:53769
ACCEPT udp -- anywhere anywhere udp dpt:53769
ACCEPT tcp -- anywhere anywhere tcp dpt:27015
ACCEPT udp -- anywhere anywhere udp dpt:27015
ACCEPT udp -- anywhere anywhere udp dpt:27020
ACCEPT tcp -- anywhere anywhere tcp dpt:http
ACCEPT udp -- anywhere anywhere udp dpt:http
ACCEPT tcp -- anywhere anywhere tcp dpt:27005
ACCEPT udp -- anywhere anywhere udp dpt:27005
ACCEPT tcp -- anywhere anywhere tcp dpt:51840
ACCEPT udp -- anywhere anywhere udp dpt:51840
ACCEPT udp -- anywhere anywhere udp dpt:9988
ACCEPT udp -- anywhere anywhere udp dpt:9987
ACCEPT tcp -- anywhere anywhere tcp dpt:30033
ACCEPT tcp -- anywhere anywhere tcp dpt:10011
ACCEPT tcp -- anywhere anywhere tcp dpt:41144
ACCEPT udp -- anywhere anywhere multiport dports 2011:2110
ACCEPT tcp -- anywhere anywhere tcp dpt:2008
ACCEPT udp -- anywhere anywhere udp dpt:2010
ACCEPT tcp -- anywhere anywhere tcp dpt:https
ACCEPT tcp -- anywhere anywhere tcp dpt:http-alt
ACCEPT udp -- anywhere anywhere udp dpt:http-alt
ACCEPT tcp -- anywhere anywhere tcp dpt:8087
ACCEPT udp -- anywhere anywhere udp dpt:8087
Chain ufw-user-limit (0 references)
LOG all -- anywhere anywhere limit: avg 3/min burst 5 LOG level warning prefix "[UFW LIMIT BLOCK] "
REJECT all -- anywhere anywhere reject-with icmp-port-unreachable
Chain ufw-user-limit-accept (0 references)
Chain ufw-user-logging-forward (0 references)
Chain ufw-user-logging-input (0 references)
Chain ufw-user-logging-output (0 references)
Chain ufw-user-output (1 references)
Ah, a firewall is active.
Try to disable the Firewall (as root):
iptables -P INPUT ACCEPT && iptables -P OUTPUT ACCEPT && iptables -P FORWARD ACCEPT && iptables -F
then try to connect again.
twyK
2015-08-29T23:28:38+02:00 TSClient quit.
2015-08-29T23:28:38+02:00 New connection status 0; Error 1797
2015-08-29T23:28:38+02:00 The bot could not connect. This might have several reasons: the server doesn't exist at that address, the server password is wrong or the security level of your identity is too low.
2015-08-29T23:28:33+02:00 New connection status 1; Error 0
2015-08-29T23:28:27+02:00 Starting instance ts3server://xxx.xxx.xxx?port=9987&nickname=L4g&password=&channel=&channelpassword=
It doesn't work :(
