Andrew Lastak
Hi, Sinusbot cannot connect to a specific server. This same installation works correctly with other servers.
Update:
- Operating System: Debian GNU/Linux 8.10 (jessie) (OpenVZ)
- Kernel: Linux 2.6.32-042stab127.2 x86_64
- Load Average: 0.30 0.07 0.02
- Uptime: 0 days, 1 hours, 0 minutes, 57 seconds
- OS APT Last Update: 02.03.2018 15:42:45 EST -05:00:00
- RAM: B/256.00 MB in use (%)
- SWAP: B/ B in use (%)
- DISK: 855.83 MB/3.70 GB in use (22%)
+ libglib: 2.42.1-1+b1
- Status: running (PIDs: 3294 3293, User: bot)
- Webinterface: port locally reachable (Port: 7000)
- Binary: /home/bot/sinusbot
- Binary Info: MD5 Hash: febce0ebdd2d2e9d7f69701bc5a7c339, Perms: 755, User: bot
- Version: 0.10.8-71ba94b
- TS3Path = /home/bot/TeamSpeak3-Client-linux_amd64/ts3client_linux_amd64 (Version 3.0.19.4)
- YoutubeDLPath = /home/bot/youtube-dl (does exist, version: 2018.03.03)
- Time (local): 02.03.2018 16:42:59 EST -05:00:00
- Timezone: America/New_York
- youtube-dl Version: 2018.03.03
- DiagScript Version: 0.7.0
- used version (SinusBot, TS Client / Server)
- SinusBot: 0.10.8-71ba94b
- TS Client 3.0.19.4 And 3.0.18.2
- TS Server: 3.0.12.2 on Linux
- used operating system (e.g. Windows, 64bit)
- Debian 8 - OpenVZ (NAT IPv4)
- hardware specs (e.g. VPS, Core i7, 8 GB RAM)
- VPS
- 1Vcpu Xeon E5
- 256 MB Ram
- used browser (and maybe plugins)
- Chrome
- your config.ini
TS3Path = "/home/bot/TeamSpeak3-Client-linux_amd64/ts3client_linux_amd64"
DataDir = "/home/bot/data/"
ListenPort = 7000
YoutubeDLPath = "/home/bot/youtube-dl"
LicenseKey = "qAHVu8KGjGlKR7ko4EMkF3dlsr49Yl4QtNQvI1******"
UserAgent = "SinusBot (0.10.8-71ba94b)"
- Instance log:
2018/03/02 17:01:34 X [MAIN] Starting up fake x-server...
2018/03/02 17:01:35 [GENERAL/SCRIPTS] INFO Loading ScriptPlugin advertising.js
2018/03/02 17:01:35 [GENERAL/SCRIPTS] INFO Loading ScriptPlugin alonemode.js
2018/03/02 17:01:35 [GENERAL/SCRIPTS] INFO Loading ScriptPlugin bookmark.js
2018/03/02 17:01:35 [GENERAL/SCRIPTS] INFO Loading ScriptPlugin followme.js
2018/03/02 17:01:35 [GENERAL/SCRIPTS] INFO Loading ScriptPlugin norecording.js
2018/03/02 17:01:35 [GENERAL/SCRIPTS] INFO Loading ScriptPlugin rememberChannel.js
2018/03/02 17:01:35 [GENERAL/SCRIPTS] INFO Loading ScriptPlugin welcome.js
2018/03/02 17:01:36 3b9312ad INFO Loading instances
2018/03/02 17:01:36 3b9312ad INFO Loading instance://bf027890-82ce-4cb7-be97-fad72f72e135
2018/03/02 17:01:36 3b9312ad bf027890 INFO Initialization complete
2018/03/02 17:01:36 [GENERAL/FFMPEG ] INFO FFmpeg/avcodec v3741798; license: LGPL version 2.1 or later; 81 codecs
2018/03/02 17:01:36 [GENERAL/FFMPEG ] INFO FFmpeg/avformat v3742052; license: LGPL version 2.1 or later; 143 formats
2018/03/02 17:01:36 [GENERAL/YTDL ] INFO youtube-dl checking...
2018/03/02 17:01:38 [GENERAL/YTDL ] INFO youtube-dl version compatible, support enabled
2018/03/02 17:01:38 [GENERAL/!!!!!!!] NOTICE You may now configure and launch the bots from the webinterface. http://0.0.0.0:7000
2018/03/02 17:01:38 [GENERAL/RADIO ] INFO RadioStation data loaded
2018/03/02 17:01:39 [GENERAL/RADIO ] INFO Imported radio stations
2018/03/02 17:01:45 3b9312ad bf027890 DEBUG Prespawn.
2018/03/02 17:01:45 3b9312ad bf027890 DEBUG About to run.
2018/03/02 17:01:45 3b9312ad bf027890 WARN Could not create Chat-Tabletable Chat already exists
2018/03/02 17:01:45 3b9312ad bf027890 WARN Could not create WhisperReceive-Tabletable WhisperReceive already exists
2018/03/02 17:01:45 3b9312ad bf027890 WARN Could not create Notifications-Tabletable Notifications already exists
2018/03/02 17:01:45 3b9312ad bf027890 DEBUG Could not delete from FileTransferno such table: FileTransfer
2018/03/02 17:01:45 3b9312ad bf027890 DEBUG Could not insert into FileTransfer-Tableno such table: FileTransfer
2018/03/02 17:01:46 3b9312ad bf027890 INFO Starting instance ts3server://*TS3SERVER*&nickname=SinusBot&password=&channel=&channelpassword=
2018/03/02 17:01:46 X [MAIN] New connection
2018/03/02 17:01:46 3b9312ad bf027890 DEBUG TS>Crashdump ENABLED, directory is: /home/bot/data/ts3/3b9312ad-467d-4e80-8a0e-8682dffbb083/bf027890-82ce-4cb7-be97-fad72f72e135/crashdumps
2018/03/02 17:01:46 3b9312ad bf027890 DEBUG TS>DUMP defined! Dumpdir is: /home/bot/data/ts3/3b9312ad-467d-4e80-8a0e-8682dffbb083/bf027890-82ce-4cb7-be97-fad72f72e135/crashdumps
2018/03/02 17:01:46 3b9312ad bf027890 INFO TS |INFO | | |TeamSpeak 3 Client 3.0.19.4 (2016-07-14 10:16:58)
2018/03/02 17:01:46 3b9312ad bf027890 INFO TS |INFO | | |SystemInformation: Linux 2.6.32-042stab127.2 #1 SMP Thu Jan 4 16:41:44 MSK 2018 x86_64 Binary: 64bit
2018/03/02 17:01:46 3b9312ad bf027890 INFO TS |INFO | | |Using hardware aes
2018/03/02 17:01:46 3b9312ad bf027890 INFO TS |ERROR |SoundBckndIntf| |libasound.so.2: cannot open shared object file: No such file or directory
2018/03/02 17:01:46 3b9312ad bf027890 INFO TS |ERROR |SoundBckndIntf| |libpulse.so.0: cannot open shared object file: No such file or directory
2018/03/02 17:01:46 3b9312ad bf027890 INFO TS |WARNING |SoundDevManager| |Did not load any sound backends. No (usable) dynamic libraries found.
2018/03/02 17:01:46 3b9312ad bf027890 INFO TS |INFO | | |Loading plugin: libclientquery_plugin
2018/03/02 17:01:46 3b9312ad bf027890 INFO TS |INFO | | |Loading plugin: liblua_plugin
2018/03/02 17:01:46 3b9312ad bf027890 INFO TS |INFO | | |Loading plugin: libsoundbot_plugin
2018/03/02 17:01:46 3b9312ad bf027890 INFO TS |INFO | | |Loading plugin: libtest_plugin
2018/03/02 17:01:46 3b9312ad bf027890 INFO TS |INFO |Query | |listening on 127.0.0.1:25639
2018/03/02 17:01:46 3b9312ad bf027890 DEBUG TS>ClientQueryPlugin: currentServerConnectionChanged 1 (0)
2018/03/02 17:01:46 3b9312ad bf027890 INFO TS |INFO |ClientUI | |Failed to init text to speech engine
2018/03/02 17:01:46 3b9312ad bf027890 INFO TS |INFO |ClientUI | |Qt version: 5.5.1
2018/03/02 17:01:46 3b9312ad bf027890 INFO TS |INFO |ClientUI | |Using configuration location: /home/bot/data/ts3/3b9312ad-467d-4e80-8a0e-8682dffbb083/bf027890-82ce-4cb7-be97-fad72f72e135/settings.db
2018/03/02 17:01:47 3b9312ad bf027890 INFO TS |INFO |ClientUI | |ts3server: *TS3SERVER*&nickname=SinusBot&password=&channel=&channelpassword=
2018/03/02 17:01:47 3b9312ad bf027890 INFO TS |INFO |ClientUI |1 |Connect to server: *TS3SERVER*
2018/03/02 17:01:47 3b9312ad bf027890 INFO TS |INFO |ClientUI |1 |Trying to resolve *TS3SERVER*
18/03/02 17:01:47 3b9312ad bf027890 INFO TS |INFO |TSDNS | |DNS resolve successful, "*TS3SERVER*"=***.***.***.***
2018/03/02 17:01:47 3b9312ad bf027890 INFO TS |INFO |TSDNS | |TSDNS found at "*TS3SERVER*" and queried successfully. Result: ***.***.***.***:****
2018/03/02 17:01:47 3b9312ad bf027890 INFO TS |INFO |TSDNS | |SRV TSDNS found at "_tsdns._tcp.*TS3SERVER*"=>"*TS3SERVER*:41144" and queried successfully. Result: ***.***.***.***:****
2018/03/02 17:01:47 3b9312ad bf027890 INFO TS |INFO |TSDNS | |SRV DNS resolve unsuccessful for "_ts3._udp.*TS3SERVER*"
2018/03/02 17:01:47 3b9312ad bf027890 INFO TS |INFO |ClientUI |1 |Lookup finished: ***.***.***.*** **** *TS3SERVER* 1 0
2018/03/02 17:01:47 3b9312ad bf027890 INFO TS |INFO |ClientUI |1 |Resolve successful: ***.***.***.***:****
2018/03/02 17:01:47 3b9312ad bf027890 INFO TS |INFO |ClientUI |1 |Blacklist check ok
2018/03/02 17:01:47 3b9312ad bf027890 INFO TS |INFO |ClientUI |1 |Initiating connection: ****.****.****.****:**** *TS3SERVER*
2018/03/02 17:01:47 3b9312ad bf027890 INFO TS |INFO |PreProSpeex |1 |Speex version: 1.2rc1
2018/03/02 17:01:48 3b9312ad bf027890 INFO TS |INFO |ClientUI |1 |Connect status: Connecting
2018/03/02 17:01:48 3b9312ad bf027890 INFO TS |INFO |ClientUI | |Last update check was: Tue Jan 1 00:00:01 2019
2018/03/02 17:01:48 3b9312ad bf027890 INFO New connection status 1; Error 0
2018/03/02 17:01:48 3b9312ad bf027890 INFO TS |INFO | | |Statistics report: Not yet, next report on Fri Mar 9 15:53:21 2018
2018/03/02 17:01:53 3b9312ad bf027890 INFO TS |INFO |ClientUI |1 |Connect status: Disconnected
2018/03/02 17:01:53 3b9312ad bf027890 INFO TS |INFO |ClientUI |1 |Failed to connect to server, want autoreconnect = 0
2018/03/02 17:01:53 3b9312ad bf027890 INFO The bot could not connect. This might have several reasons: the server doesn't exist at that address, the server password is wrong, the default channel doesn't exist, the bot has been banned, the server is an illegal installation or the password is wrong , the security level of your identity is too low or the server does not allow the version of the client you are using. See our Wiki / Forums for more help.
2018/03/02 17:01:53 3b9312ad bf027890 INFO New connection status 0; Error 1797
2018/03/02 17:01:54 3b9312ad bf027890 DEBUG TS>libpng warning: iCCP: known incorrect sRGB profile
2018/03/02 17:01:54 3b9312ad bf027890 DEBUG TS>warning: The VAD has been replaced by a hack pending a complete rewrite
2018/03/02 17:01:54 3b9312ad bf027890 DEBUG Closed.
2018/03/02 17:01:54 3b9312ad bf027890 INFO TSClient quit.
2018/03/02 17:02:06 3b9312ad bf027890 DEBUG Storing configuration.
2018/03/02 17:02:30 [GENERAL ] Shutting down... Hold on...
Update:
- The server doesn't exist at that address
- Verified, the address is correct
- The server password is wrong
- The server does not require a password
- The default channel doesn't exist
- The default channel is defined and exists
- The bot has been banned
- There are no registered bans, and from the server side there are no connection attempts by the bot.
- The server is an illegal installation or the password is wrong
- The server is not blacklisted or a password is requested
- The security level of your identity is too low
- The bot meets the minimum required by default, increasing the security of the identity did not solve the problem (Tested).
- The server does not allow the version of the client you are using
- There are 2 instances in the server, Sinusbot connects perfectly to one, but it is impossible in the other.
