[Bugs/Error] Ubuntu 16.04 LTS/Debian 9 - a manual update is required
EdisonJwa
#stayinghome
How Can I Fix This ? Because of this I can't run the SinusBot
sinusbot@ubuntu:/opt/sinusbot$ ./sinusbot
Version: 0.10.8-71ba94b
2017/11/15 01:02:55 X [MAIN] Starting up fake x-server...
2017/11/15 01:02:55 [GENERAL/SCRIPTS] INFO Loading ScriptPlugin advertising.js
2017/11/15 01:02:55 [GENERAL/SCRIPTS] INFO Loading ScriptPlugin alonemode.js
2017/11/15 01:02:55 [GENERAL/SCRIPTS] INFO Loading ScriptPlugin bookmark.js
2017/11/15 01:02:55 [GENERAL/SCRIPTS] INFO Loading ScriptPlugin followme.js
2017/11/15 01:02:55 [GENERAL/SCRIPTS] INFO Loading ScriptPlugin norecording.js
2017/11/15 01:02:55 [GENERAL/SCRIPTS] INFO Loading ScriptPlugin rememberChannel.js
2017/11/15 01:02:55 [GENERAL/SCRIPTS] INFO Loading ScriptPlugin welcome.js
- Operating System: Ubuntu 16.04.3 LTS
- Kernel: Linux 4.4.0-98-generic x86_64
- Load Average: 0.07 0.02 0.00
- Uptime: 0 days, 0 hours, 21 minutes, 14 seconds
- OS APT Last Update: 14.11.2017 21:34:20 CST +08:00:00
- HTTPS check with IPv4 mode: FAILED  [Failed establishing connection to www.sinusbot.com, CODE #403]
    CPU(s):                1
    Thread(s) per core:    1
    Core(s) per socket:    1
    Socket(s):             1
    Model name:            Intel Core Processor (Broadwell)
    CPU MHz:               2095.146
    Hypervisor vendor:     Microsoft
    Virtualization type:   full
- RAM: 216.33 MB/992.31 MB in use (21%)
- SWAP: 0 B/3.99 GB in use (0%)
- DISK: 2.25 GB/31.23 GB in use (7%)
   + libglib: 2.48.2-0ubuntu1
- Binary Info: MD5 Hash: febce0ebdd2d2e9d7f69701bc5a7c339, Perms: 755, User: sinusbot
- Version: 0.10.8-71ba94b
   - TS3Path = /opt/sinusbot/teamspeak3-client/ts3client_linux_amd64 (Version 3.0.18.2)
   - YoutubeDLPath = not set
- Time (local): 15.11.2017 00:57:59 CST +08:00:00
- Time (remote): 01.01.1900 08:05:43 LMT +08:05:43
- Time (difference): -3719667479 secs (Time diff less than 10 secs. Aceptable.)
- Timezone: America/New_York
- youtube-dl Version: unknown
- DiagScript Version: 0.6.1
good_live
Maybe you need to update the bot... Just random guessing, because the error message isn't clear about that.
EdisonJwa
#stayinghome
root@VM-197-175-debian:/opt/sinusbot# bash diagSinusbot.sh
[2017-12-28 16:20:21] [WELCOME] =================================================
[2017-12-28 16:20:21] [WELCOME] = HELLO! Please invest some time to read this. =
[2017-12-28 16:20:21] [WELCOME] = =
[2017-12-28 16:20:21] [WELCOME] = Thanks for using this diagnostic script! =
[2017-12-28 16:20:21] [WELCOME] = The more information you provide, the =
[2017-12-28 16:20:21] [WELCOME] = better we can help to solve your problem. =
[2017-12-28 16:20:21] [WELCOME] = The execution may take some moments to =
[2017-12-28 16:20:21] [WELCOME] = collection the most important information =
[2017-12-28 16:20:21] [WELCOME] = of your system and your bot installation. =
[2017-12-28 16:20:21] [WELCOME] = After everything is done, you will get a =
[2017-12-28 16:20:21] [WELCOME] = diagnostic output, ready for copy & pasting =
[2017-12-28 16:20:21] [WELCOME] = it within a CODE-tag in the SinusBot forum. =
[2017-12-28 16:20:21] [WELCOME] = [Link: https://forum.sinusbot.com] =
[2017-12-28 16:20:21] [WELCOME] = No private information will be collected =
[2017-12-28 16:20:21] [WELCOME] = nor the data will be sent to anywhere. =
[2017-12-28 16:20:21] [WELCOME] = This just generates an example forum post. =
[2017-12-28 16:20:21] [WELCOME] = The script does perform a DNS resolution of =
[2017-12-28 16:20:21] [WELCOME] = domain 'www.sinusbot.com' to determine if =
[2017-12-28 16:20:21] [WELCOME] = your DNS settings are working as expected. =
[2017-12-28 16:20:21] [WELCOME] = I am thankful for any feedback. Please also =
[2017-12-28 16:20:21] [WELCOME] = report any issues you may find either on the =
[2017-12-28 16:20:21] [WELCOME] = SinusBot forum or via GitHub issues. Thanks! =
[2017-12-28 16:20:21] [WELCOME] = -- Patrik Kernstock aka. Patschi. =
[2017-12-28 16:20:21] [WAIT] Press [ENTER] to continue...
[2017-12-28 16:20:35] [INFO] Starting diagSinusbot v0.6.1 [2017-11-07 01:30]...
[2017-12-28 16:20:35] [INFO] Checking for new diagnostic script version...
[2017-12-28 16:20:37] [OKAY] You are using the latest version.
[2017-12-28 16:20:37] [INFO] Detected operating system: Debian GNU/Linux 9.3 (stretch)
[2017-12-28 16:20:37] [INFO] Searching bot binary...
[2017-12-28 16:20:37] [DEBUG] Searching in directory '/opt/sinusbot'...
[2017-12-28 16:20:37] [DEBUG] Binary 'sinusbot' found.
[2017-12-28 16:20:37] [INFO] Binary found.
[2017-12-28 16:20:37] [DEBUG] Collecting information...
[2017-12-28 16:20:37] [INFO] (Scan may take some moments...)
[2017-12-28 16:20:37] [INFO] Collecting system information...
[2017-12-28 16:20:37] [DEBUG] Getting operating system version...
[2017-12-28 16:20:37] [DEBUG] Checking DNS resolution...
[2017-12-28 16:20:37] [DEBUG] Checking web IPv4 access...
[2017-12-28 16:20:38] [ERROR] Contacting 'www.sinusbot.com' using IPv4-only mode failed: Please check for IPv4 connectivity, for any DNS resolution issues or possible firewall restrictions.
[2017-12-28 16:20:38] [WARNING] Error Code 403: This possibly means that Cloudflare has classified the connection as suspicious and therefor blocked it. So this could be probably a false-positive.
[2017-12-28 16:20:38] [DEBUG] Checking for locales...
[2017-12-28 16:20:38] [DEBUG] Getting processor information...
[2017-12-28 16:20:38] [DEBUG] Checking for available operating system updates...
[2017-12-28 16:20:38] [DEBUG] Getting RAM information...
[2017-12-28 16:20:38] [DEBUG] Getting SWAP information...
[2017-12-28 16:20:38] [DEBUG] Getting DISK information...
[2017-12-28 16:20:38] [DEBUG] Getting disk info by using command:
[2017-12-28 16:20:38] [DEBUG] $ df -Tl --total -t ext4 -t ext3 -t ext2 -t reiserfs -t jfs -t ntfs -t fat32 -t btrfs -t fuseblk
[2017-12-28 16:20:38] [INFO] Collecting bot information...
[2017-12-28 16:20:38] [DEBUG] Trying to get SinusBot version using version parameter...
[2017-12-28 16:20:38] [DEBUG] Loading bot config file...
[2017-12-28 16:20:38] [DEBUG] Determining bot status...
[2017-12-28 16:20:38] [DEBUG] Reading ListenPort from bot configuration...
[2017-12-28 16:20:38] [DEBUG] Getting installed bot scripts...
[2017-12-28 16:20:38] [DEBUG] Reading LogLevel from bot configuration...
[2017-12-28 16:20:38] [DEBUG] Reading TS3Path from bot configuration...
[2017-12-28 16:20:38] [DEBUG] Trying to get ts3client version...
[2017-12-28 16:20:38] [DEBUG] Checking installation of bot plugin in ts3client...
[2017-12-28 16:20:38] [DEBUG] Checking for 'youtube-dl'...
xxd: sorry cannot seek.
[2017-12-28 16:20:40] [DEBUG] Generating output...
 - Operating System: Debian GNU/Linux 9.3 (stretch)
 - Kernel: Linux 4.9.0-3-amd64 x86_64
 - Load Average: 0.00 0.01 0.00
 - Uptime: 0 days, 1 hours, 25 minutes, 47 seconds
 - OS APT Last Update: 28.12.2017 15:05:59 CST +08:00:00
 - SHELL LOCALE LANG: en_US.utf8
    CPU(s):                1
    Socket(s):             1
    Model name:            Intel(R) Xeon(R) CPU E5-26xx v4
    CPU MHz:               2399.996
    Hypervisor vendor:     KVM
 - RAM: 247.76 MB/868.58 MB in use (28%)
 - DISK: 2.11 GB/44.53 GB in use (4%)
   + libglib: 2.50.3-2
   - TS3Path = /opt/sinusbot/TeamSpeak3-Client-linux_amd64/ts3client_linux_amd64 (Version 3.1.7)
 - Time (local): 28.12.2017 16:20:38 CST +08:00:00
 - Time (difference): -3723438038 secs (Time diff less than 10 secs. Aceptable.)
 - Timezone: Asia/Shanghai
 - TeamSpeak 3 Version: 3.1.7
[2017-12-28 16:20:41] [DEBUG] Done.
