Solved Errors sinusbot
rejzerPL
Since yesterday, I'm trying to correctly install a sinusbot on debiana, centos and even ubuntu so that the scripts work, but nothing helps or reinstall or nothing.
When I run the bot does not work for me a large part of the scripts or the bot does not pass even on the designated channel, I set loglevel on 10. Here are the logs. anyone can know how to fix it?
the main script I care about is: AutomaticServerGroupAssigner.
LOGS:
2018-08-01T17:02:30+02:00 Storing configuration.
2018-08-01T17:02:29+02:00 Could not add client to group: insufficient client permissions
2018-08-01T17:02:29+02:00 2568/insufficient client permissions/i_group_member_add_power
2018-08-01T17:02:29+02:00 TS/ERR 2564 e'access to default group is forbidden' x'' r'PR:{d0bf238b-f5b3-4d22-bf1d-da4125ccf14d}:228/GCLL'
2018-08-01T17:02:29+02:00 Awaiting Callback (1): PR:{d0bf238b-f5b3-4d22-bf1d-da4125ccf14d}:230/SGRA
2018-08-01T17:02:28+02:00 New connection status 4; Error 0
2018-08-01T17:02:28+02:00 TS |INFO |PermManager | |Loading permissions from cache
2018-08-01T17:02:28+02:00 TS |INFO |ClientUI |1 |Connect status: Connection established
2018-08-01T17:02:28+02:00 TS |INFO | | |Statistics report: Not yet, next report on Mon Aug 20 14:26:35 2018
2018-08-01T17:02:28+02:00 TS |INFO |ClientUI | |Last update check was: Tue Jan 1 00:00:01 2019
2018-08-01T17:02:28+02:00 TS |INFO |Bookmarks | |Collecting autoconnect bookmarks
2018-08-01T17:02:28+02:00 New connection status 3; Error 0
2018-08-01T17:02:28+02:00 TS |INFO |ClientUI |1 |Connect status: Establishing connection
2018-08-01T17:02:28+02:00 New connection status 2; Error 0
2018-08-01T17:02:28+02:00 TS |INFO |ClientUI |1 |Connect status: Connected
2018-08-01T17:02:27+02:00 TS |DEVELOP |PktHandler | |Puzzle solve time: 4
2018-08-01T17:02:27+02:00 New connection status 1; Error 0
2018-08-01T17:02:27+02:00 TS |INFO |ClientUI |1 |Connect status: Connecting
2018-08-01T17:02:27+02:00 TS |INFO |PreProSpeex |1 |Speex version: 1.2rc1
2018-08-01T17:02:27+02:00 TS |INFO |ClientUI |1 |Initiating connection: 51.38.142.101:9987
2018-08-01T17:02:27+02:00 TS |INFO |ClientUI |1 |Connect to server: 51.38.142.101
2018-08-01T17:02:27+02:00 TS |INFO |ClientUI | |ts3server: 51.38.142.101?port=9987&nickname=%5BMainBOT01%2F50%5D&password=&cid=88&channelpassword=
2018-08-01T17:02:27+02:00 TS |INFO |ClientUI | |Using configuration location: /home/mainbot/5550/data/ts3/c704c360-dbd8-42f2-924c-57a1952feb14/10b6a3b8-4148-4c04-9803-97d0a9c4490d/settings.db
2018-08-01T17:02:27+02:00 TS |INFO |ClientUI | |Qt version: 5.6.1
2018-08-01T17:02:27+02:00 TS |INFO |ClientUI | |Failed to init text to speech engine
2018-08-01T17:02:27+02:00 TS |DEVELOP |ClientUI | |Notifications init: Soundpack path: /home/mainbot/5550/teamspeak3-client/sound/nosounds
2018-08-01T17:02:27+02:00 TS |INFO | | |*** Time [INIT]: 160
2018-08-01T17:02:27+02:00 TS |INFO | | |*** Time [MAINWINDOW]: 150
2018-08-01T17:02:27+02:00 TS |INFO | | |successfully downloaded revocation list
2018-08-01T17:02:27+02:00 TS |INFO |Plugins | |Loading plugin: libsoundbot_plugin.so
2018-08-01T17:02:27+02:00 TS |INFO |Addons | |Checking for addon updates...
2018-08-01T17:02:27+02:00 TS |INFO |ClientUI | |Unable to create an Open GL context.
2018-08-01T17:02:27+02:00 TS |ERROR |SoundBckndIntf| |libpulse.so.0: cannot open shared object file: No such file or directory
2018-08-01T17:02:27+02:00 TS |INFO | | |Using hardware aes
2018-08-01T17:02:27+02:00 TS |INFO | | |SystemInformation: Linux 2.6.32-48-pve #1 SMP Fri Dec 23 10:22:54 CET 2016 x86_64 Binary: 64bit
2018-08-01T17:02:27+02:00 TS |INFO | | |TeamSpeak 3 Client 3.1.9 (2018-05-04 13:54:44)
2018-08-01T17:02:27+02:00 TS>DUMP defined! Dumpdir is: /home/mainbot/5550/data/ts3/c704c360-dbd8-42f2-924c-57a1952feb14/10b6a3b8-4148-4c04-9803-97d0a9c4490d/crashdumps
2018-08-01T17:02:27+02:00 TS>Crashdump ENABLED, directory is: /home/mainbot/5550/data/ts3/c704c360-dbd8-42f2-924c-57a1952feb14/10b6a3b8-4148-4c04-9803-97d0a9c4490d/crashdumps
2018-08-01T17:02:27+02:00 Starting instance ts3server://51.38.142.101?port=9987&nickname=%5BMainBOT01%2F50%5D&password=&cid=88&channelpassword=
2018-08-01T17:02:27+02:00 Could not insert into FileTransfer-Tableno such table: FileTransfer
2018-08-01T17:02:27+02:00 Could not delete from FileTransferno such table: FileTransfer
2018-08-01T17:02:27+02:00 Could not create Notifications-Tabletable Notifications already exists
2018-08-01T17:02:27+02:00 Could not create WhisperReceive-Tabletable WhisperReceive already exists
2018-08-01T17:02:27+02:00 Could not create Chat-Tabletable Chat already exists
2018-08-01T17:02:27+02:00 About to run.
2018-08-01T17:02:27+02:00 Prespawn.
2018-08-01T17:02:26+02:00 TSClient quit.
2018-08-01T17:02:26+02:00 Closed.
2018-08-01T17:02:26+02:00 TS>libpng warning: iCCP: known incorrect sRGB profile
2018-08-01T17:02:26+02:00 TS>QXcbIntegration: Cannot create platform OpenGL context, neither GLX nor EGL are enabled
2018-08-01T17:02:26+02:00 TS>Use QT_XKB_CONFIG_ROOT environmental variable to provide an additional search path, add ':' as separator to provide several search paths and/or make sure that XKB configuration data directory contains recent enough contents, to update please see http://cgit.freedesktop.org/xkeyboard-config/ .
2018-08-01T17:02:26+02:00 TS>Qt: Failed to create XKB context!
2018-08-01T17:02:26+02:00 TS>xkbcommon: ERROR: failed to add default include path /usr/share/X11/xkb
2018-08-01T17:02:26+02:00 TS>QCoreApplication::applicationDirPath: Please instantiate the QApplication object first
2018-08-01T17:02:26+02:00 KILL [admin] OK
2018-08-01T17:02:25+02:00 New connection status 0; Error 0
2018-08-01T17:02:25+02:00 TS |INFO |ClientUI |1 |Disconnected or forced to leave, want autoreconnect = 0
2018-08-01T17:02:25+02:00 TS |INFO |ClientUI |1 |Connect status: Disconnected
2018-08-01T17:02:25+02:00 [MainBOT01/50] joined the channel
2018-08-01T17:01:50+02:00 Could not add client to group: insufficient client permissions
2018-08-01T17:01:50+02:00 2568/insufficient client permissions/i_group_member_add_power
2018-08-01T17:01:50+02:00 Awaiting Callback (1): PR:{3b4e7fa3-d47b-4eb0-8642-4663bd867a03}:396/SGRA
2018-08-01T17:01:00+02:00 Storing configuration.
2018-08-01T17:00:47+02:00 Could not add client to group: insufficient client permissions
2018-08-01T17:00:47+02:00 2568/insufficient client permissions/i_group_member_add_power
2018-08-01T17:00:47+02:00 Awaiting Callback (1): PR:{3b4e7fa3-d47b-4eb0-8642-4663bd867a03}:390/SGRA
2018-08-01T17:00:44+02:00 Could not add client to group: insufficient client permissions
2018-08-01T17:00:44+02:00 2568/insufficient client permissions/i_group_member_add_power
2018-08-01T17:00:44+02:00 Awaiting Callback (1): PR:{3b4e7fa3-d47b-4eb0-8642-4663bd867a03}:389/SGRA
2018-08-01T17:00:40+02:00 Loading script AutomaticServerGroupAssigner
2018-08-01T17:00:40+02:00 Loading script (autorun) OKlib
2018-08-01T17:00:30+02:00 Storing configuration.
2018-08-01T17:00:13+02:00 Loading script (autorun) OKlib
2018-08-01T17:00:00+02:00 Storing configuration.
2018-08-01T16:59:32+02:00 TS/ERR 2564 e'access to default group is forbidden' x'' r'PR:{3b4e7fa3-d47b-4eb0-8642-4663bd867a03}:226/GCLL'
2018-08-01T16:59:31+02:00 New connection status 4; Error 0
2018-08-01T16:59:31+02:00 TS |INFO |PermManager | |Loading permissions from cache
2018-08-01T16:59:31+02:00 TS |INFO |ClientUI |1 |Connect status: Connection established
2018-08-01T16:59:31+02:00 TS |INFO | | |Statistics report: Not yet, next report on Mon Aug 20 14:26:35 2018
2018-08-01T16:59:31+02:00 TS |INFO |ClientUI | |Last update check was: Tue Jan 1 00:00:01 2019
2018-08-01T16:59:31+02:00 TS |INFO |Bookmarks | |Collecting autoconnect bookmarks
2018-08-01T16:59:31+02:00 New connection status 3; Error 0
2018-08-01T16:59:31+02:00 TS |INFO |ClientUI |1 |Connect status: Establishing connection
2018-08-01T16:59:31+02:00 New connection status 2; Error 0
2018-08-01T16:59:31+02:00 TS |INFO |ClientUI |1 |Connect status: Connected
2018-08-01T16:59:31+02:00 TS |DEVELOP |PktHandler | |Puzzle solve time: 3
2018-08-01T16:59:31+02:00 New connection status 1; Error 0
2018-08-01T16:59:31+02:00 TS |INFO |ClientUI |1 |Connect status: Connecting
2018-08-01T16:59:31+02:00 TS |INFO |PreProSpeex |1 |Speex version: 1.2rc1
It's TeamSpeak permissions, not file permissions - you can manage it with your own TeamSpeak Client when you are the admin of your server.
Kir-à
That's mean your admin rank don't have full access, so yeah.
Just setup your TeamSpeak permission.
If you use YatQa give him Admin Query it may work.
rejzerPL
2018-08-01T20:32:38+02:00 Could not add client to group: insufficient client permissions
2018-08-01T20:32:38+02:00 2568/insufficient client permissions/i_group_member_add_power
2018-08-01T20:32:38+02:00 TS/ERR 2564 e'access to default group is forbidden' x'' r'PR:{d1cc6aab-d3b4-4ef1-b02b-2b6f795370bd}:228/GCLL'
2018-08-01T20:32:38+02:00 Awaiting Callback (1): PR:{d1cc6aab-d3b4-4ef1-b02b-2b6f795370bd}:230/SGRA
2018-08-01T20:32:37+02:00 New connection status 4; Error 0
2018-08-01T20:32:37+02:00 TS |INFO |PermManager | |Loading permissions from cache
2018-08-01T20:32:37+02:00 TS |INFO |ClientUI |1 |Connect status: Connection established
2018-08-01T20:32:37+02:00 TS |INFO | | |Statistics report: Not yet, next report on Tue Aug 14 13:51:56 2018
2018-08-01T20:32:37+02:00 TS |INFO |ClientUI | |Last update check was: Tue Jan 1 00:00:01 2019
2018-08-01T20:32:37+02:00 TS |INFO |Bookmarks | |Collecting autoconnect bookmarks
2018-08-01T20:32:37+02:00 New connection status 3; Error 0
2018-08-01T20:32:37+02:00 TS |INFO |ClientUI |1 |Connect status: Establishing connection
2018-08-01T20:32:37+02:00 New connection status 2; Error 0
2018-08-01T20:32:37+02:00 TS |INFO |ClientUI |1 |Connect status: Connected
2018-08-01T20:32:37+02:00 TS |DEVELOP |PktHandler | |Puzzle solve time: 4
2018-08-01T20:32:37+02:00 New connection status 1; Error 0
2018-08-01T20:32:37+02:00 TS |INFO |ClientUI |1 |Connect status: Connecting
2018-08-01T20:32:37+02:00 TS |INFO |PreProSpeex |1 |Speex version: 1.2rc1
2018-08-01T20:32:37+02:00 TS |INFO |ClientUI |1 |Initiating connection: 51.38.142.101:9987
2018-08-01T20:32:37+02:00 TS |INFO |ClientUI |1 |Connect to server: 51.38.142.101
2018-08-01T20:32:37+02:00 TS |INFO |ClientUI | |ts3server: 51.38.142.101?port=9987&nickname=SinusBot&password=111&channel=&channelpassword=
2018-08-01T20:32:36+02:00 TS |INFO |ClientUI | |Using configuration location: /home/mainbot/5550/data/ts3/aa3a334d-e653-4e41-ad0f-0f677efb21da/6d18628d-4fb4-4a4d-b9e2-bbb23dbbc18d/settings.db
2018-08-01T20:32:36+02:00 TS |INFO |ClientUI | |Qt version: 5.6.1
2018-08-01T20:32:36+02:00 TS |INFO |ClientUI | |Failed to init text to speech engine
2018-08-01T20:32:36+02:00 TS |DEVELOP |ClientUI | |Notifications init: Soundpack path: /home/mainbot/5550/teamspeak3-client/sound/nosounds
2018-08-01T20:32:36+02:00 TS |INFO | | |*** Time [INIT]: 523
2018-08-01T20:32:36+02:00 TS |INFO | | |*** Time [MAINWINDOW]: 522
2018-08-01T20:32:36+02:00 TS>ClientQueryPlugin: currentServerConnectionChanged 1 (0)
2018-08-01T20:32:36+02:00 TS |INFO |Query | |listening on 127.0.0.1:25639
2018-08-01T20:32:36+02:00 TS |INFO |Plugins | |Loading plugin: libclientquery_plugin_linux_amd64.so
2018-08-01T20:32:36+02:00 TS |INFO |Plugins | |Loading plugin: libsoundbot_plugin.so
2018-08-01T20:32:36+02:00 TS |INFO | | |successfully downloaded revocation list
2018-08-01T20:32:36+02:00 TS |INFO |Addons | |Checking for addon updates...
2018-08-01T20:32:36+02:00 TS |INFO |ClientUI | |Unable to create an Open GL context.
2018-08-01T20:32:36+02:00 TS |ERROR |SoundBckndIntf| |libpulse.so.0: cannot open shared object file: No such file or directory
2018-08-01T20:32:36+02:00 TS |INFO | | |Using hardware aes
2018-08-01T20:32:36+02:00 TS |INFO | | |SystemInformation: Linux 2.6.32-48-pve #1 SMP Fri Dec 23 10:22:54 CET 2016 x86_64 Binary: 64bit
2018-08-01T20:32:36+02:00 TS |INFO | | |TeamSpeak 3 Client 3.1.9 (2018-05-04 13:54:44)
2018-08-01T20:32:36+02:00 TS>DUMP defined! Dumpdir is: /home/mainbot/5550/data/ts3/aa3a334d-e653-4e41-ad0f-0f677efb21da/6d18628d-4fb4-4a4d-b9e2-bbb23dbbc18d/crashdumps
2018-08-01T20:32:36+02:00 TS>Crashdump ENABLED, directory is: /home/mainbot/5550/data/ts3/aa3a334d-e653-4e41-ad0f-0f677efb21da/6d18628d-4fb4-4a4d-b9e2-bbb23dbbc18d/crashdumps
2018-08-01T20:32:35+02:00 Starting instance ts3server://51.38.142.101?port=9987&nickname=SinusBot&password=111&channel=&channelpassword=
2018-08-01T20:32:35+02:00 Could not insert into FileTransfer-Tableno such table: FileTransfer
2018-08-01T20:32:35+02:00 Could not delete from FileTransferno such table: FileTransfer
2018-08-01T20:32:35+02:00 Could not create Notifications-Tabletable Notifications already exists
2018-08-01T20:32:35+02:00 Could not create WhisperReceive-Tabletable WhisperReceive already exists
2018-08-01T20:32:35+02:00 Could not create Chat-Tabletable Chat already exists
2018-08-01T20:32:35+02:00 About to run.
2018-08-01T20:32:35+02:00 Prespawn.
2018-08-01T20:32:35+02:00 Auto-Starting aa3a334d-e653-4e41-ad0f-0f677efb21da/6d18628d-4fb4-4a4d-b9e2-bbb23dbbc18d in 500 ms...
2018-08-01T20:32:35+02:00 Initialization complete
2018-08-01T20:32:35+02:00 Loading script AutomaticServerGroupAssigner
2018-08-01T20:32:35+02:00 Loading script (autorun) OKlib
still don't working
Kir-à
now my bot have permissions admin server query and still don't working... :c View attachment 2453
what now? :(
« Those come from reading in all information from the server, nothing is being modified. You don't need to change permissions as everything should work fine without them.
The messages come from trying to access even non existent things and also server query clients. That behavior has already been optimized in the newer Linux betas so that those messages don't appear anymore. »
Lala Sabathil
Ill do a takeover now
i send you a private message for further help
Lala Sabathil
So:
The problem is now solved.
The server seemed to be behaving strangely with the permissions.
Therefore I copied the server group "AdminServerQuery" into the new group "Bot".
Ud then removed the rights for the global settings and virtual settings.
It works now:)
Can be closed as "Resolved" @flyth
