zInvalid
Version: 0.9.9-8f70ff3
OS: Ubuntu 15.10
Also, mein Hauptproblem ist eig. das mir gesagt wird das der Bot den TS beschuldigt wird den TS zu flooden und ich ihn der WhiteList hinzufügen solle. In der query_ip_whitelist.txt steht die local IP und auch selber die Server IP. Dann sind da noch ein paar Warns etc.
OS: Ubuntu 15.10
ListenHost = ""
ListenPort = 8081
YoutubeDLPath = "youtube-dl"
MTU = 1500
SampleInterval = 100
LicenseKey = "zj3AvgZ9lX8uYmnkyAsvuiOKnClZ9DdCtEShll7GKQk="
DisableLocalXServer = false
DebugLocalXServer = false
2015/12/09 22:21:29 2ee3faf0 b1d0c9ce WARN Could not send var command
2015/12/09 22:21:29 2ee3faf0 b1d0c9ce INFO New connection status 4; Error 0
2015/12/09 22:21:29 2ee3faf0 b1d0c9ce WARN Could not find request%!(EXTRA uint32=1)
2015/12/09 22:21:29 2ee3faf0 b1d0c9ce DEBUG TS/ERR 2564 e'access to default group is forbidden' x'' r'PR:{6231360c-05f3-4f8c-bfb4-4142e3080332}:8/GCLL'
2015/12/09 22:21:34 2ee3faf0 b1d0c9ce WARN Could not send var command
2015/12/09 22:21:34 2ee3faf0 b1d0c9ce WARN Could not send config. Please make sure that the loopback interface is not firewalled and the plugin is installed properly.
2015/12/09 22:21:35 2ee3faf0 b1d0c9ce INFO TS |INFO |Newsticker | |Newsticker next check: So. Jan. 1 00:00:01 2017
2015/12/09 22:21:39 2ee3faf0 b1d0c9ce WARN Could not send var command
2015/12/09 22:21:39 2ee3faf0 b1d0c9ce WARN Could not find request%!(EXTRA uint32=2)
2015/12/09 22:21:39 2ee3faf0 b1d0c9ce WARN Could not find request%!(EXTRA uint32=3)
2015/12/09 22:21:39 2ee3faf0 b1d0c9ce DEBUG TS/ERR 524 e'client is flooding' x'' r'PR:{6231360c-05f3-4f8c-bfb4-4142e3080332}:33/GCLL'
2015/12/09 22:21:39 2ee3faf0 b1d0c9ce DEBUG TS/ERR 524 e'client is flooding' x'' r'PR:{6231360c-05f3-4f8c-bfb4-4142e3080332}:34/GCLL'
2015/12/09 22:21:39 2ee3faf0 b1d0c9ce DEBUG TS/ERR 524 e'client is flooding' x'' r'PR:{6231360c-05f3-4f8c-bfb4-4142e3080332}:35/GCLL'
2015/12/09 22:21:39 2ee3faf0 b1d0c9ce DEBUG TS/ERR 524 e'client is flooding' x'' r'PR:{6231360c-05f3-4f8c-bfb4-4142e3080332}:36/GCLL'
2015/12/09 22:21:39 2ee3faf0 b1d0c9ce DEBUG TS/ERR 524 e'client is flooding' x'' r'PR:{6231360c-05f3-4f8c-bfb4-4142e3080332}:37/GCLL'
2015/12/09 22:21:39 2ee3faf0 b1d0c9ce DEBUG TS/ERR 524 e'client is flooding' x'' r'PR:{6231360c-05f3-4f8c-bfb4-4142e3080332}:38/GCLL'
2015/12/09 22:21:39 2ee3faf0 b1d0c9ce DEBUG TS/ERR 524 e'client is flooding' x'' r'PR:{6231360c-05f3-4f8c-bfb4-4142e3080332}:39/GCLL'
2015/12/09 22:21:39 2ee3faf0 b1d0c9ce DEBUG TS/ERR 524 e'client is flooding' x'' r'PR:{6231360c-05f3-4f8c-bfb4-4142e3080332}:40/GCLL'
2015/12/09 22:21:39 2ee3faf0 b1d0c9ce DEBUG TS/ERR 524 e'client is flooding' x'' r'PR:{6231360c-05f3-4f8c-bfb4-4142e3080332}:41/GCLL'
2015/12/09 22:21:39 2ee3faf0 b1d0c9ce DEBUG TS/ERR 524 e'client is flooding' x'' r'PR:{6231360c-05f3-4f8c-bfb4-4142e3080332}:42/GCLL'
2015/12/09 22:21:39 2ee3faf0 b1d0c9ce WARN Could not find request%!(EXTRA uint32=4)
2015/12/09 22:21:39 2ee3faf0 b1d0c9ce DEBUG TS/ERR 524 e'client is flooding' x'' r'PR:{6231360c-05f3-4f8c-bfb4-4142e3080332}:43/SET0'
2015/12/09 22:21:39 2ee3faf0 b1d0c9ce WARN Could not send config. Please make sure that the loopback interface is not firewalled and the plugin is installed properly.
2015/12/09 22:21:44 2ee3faf0 b1d0c9ce WARN Could not send var command
2015/12/09 22:21:44 2ee3faf0 b1d0c9ce WARN Could not find request%!(EXTRA uint32=6)
2015/12/09 22:21:44 2ee3faf0 b1d0c9ce WARN Could not find request%!(EXTRA uint32=7)
2015/12/09 22:21:44 2ee3faf0 b1d0c9ce DEBUG TS/ERR 524 e'client is flooding' x'' r'PR:{6231360c-05f3-4f8c-bfb4-4142e3080332}:46/SET0'
2015/12/09 22:21:44 2ee3faf0 b1d0c9ce WARN Could not send config. Please make sure that the loopback interface is not firewalled and the plugin is installed properly.
2015/12/09 22:21:45 2ee3faf0 b1d0c9ce INFO TS |INFO |Newsticker | |Newsticker next check: So. Jan. 1 00:00:01 2017
2015/12/09 22:21:52 2ee3faf0 b1d0c9ce DEBUG Storing configuration.
