Solved "ev.clientNick" problem in my script
omano
Operating System: Linux Ubuntu 14.04
SinusBot Version: 0.9.18-8499d2c
TS3 Version: 3.0.19.4
I have a script I made which is supposed to play a track or say a sentence when someone leaves the channel where the bot is. Problem is that it only works sometimes as intended (play or say the corresponding track or sentence depending on the user which is leaving the bot channel). Most of the time it says "userXXX has left the channel" where 'userXXX' is a random user of the teamspeak server user database, not even connected on the TS server, or not connected since one year for example, totally random. I joined the script to the message in order to let you test. In the script, it knows a few people and have custom tracks/sentences for each user the script knows, or else it says a generic sentence with the user nickname.
Problem may be directly in my script (I'm not a coder, so.. yeah maybe), but I really think it is the bot which has a bug and does not correctly say the good "ev.clientNick", or have the good "ev.clientUid" when a user moves from the bot channel. I added logging to try to understand what happens but it does not really help it only proves the bot thinks the user who left the bot channel is the wrong one.
Link to my script: https://pastebin.com/WAVJWcQv
- Operating System: Ubuntu 14.04.5 LTS
- Kernel: Linux 3.13.0-85-generic x86_64
- Load Average: 0.64 0.55 0.65
- Uptime: 72 days, 4 hours, 39 minutes, 18 seconds
- OS Updates: 7 (updates available!)
- OS APT Last Update: 24.02.2017 23:50:22 CET +01:00:00
  Architecture:  x86_64
  CPU(s):  8
  Thread(s) per core:  2
  Core(s) per socket:  4
  Socket(s):  1
  CPU MHz:  1600.000
  Virtualization:  VT-x
- RAM:  B/15.64 GB in use (%)
- SWAP:  B/ B in use (%)
- DISK: 216.23 GB/651.67 GB in use (33%)
  > libglib: 2.40.2-0ubuntu12.40.2-0ubuntu1
- Status: running (PIDs: 29063 29062, User: ogp_agent)
- Binary: /home/ogp_agent/OGP_User_Files/HS_SinusBot/sinusbot (MD5 Hash: aa67b784b83f5a7e66c60496f58d4a92)
- Version: 0.9.18-8499d2c
  - Bot Plugin: d53693319c8922b95257ad4c6eacff69
  - TS3 Client: d53693319c8922b95257ad4c6eacff69
  - TS3Path = /home/ogp_agent/OGP_User_Files/HS_SinusBot/TeamSpeak3-Client-linux_amd64/ts3client_linux_amd64 (Version 3.0.19.4)
  - YoutubeDLPath = /usr/bin/youtube-dl (does exist, version: 2017.02.24.1)
- Installed scripts: backtodefault.js; customcomands.js; playonjoin.js; playonleave.js
- Report date: 12.04.2017 00:34:45 CEST +02:00:00 (timezone: Europe/Paris)
- youtube-dl Version: 2017.02.24.1
- DiagScript version: 0.5.1
This problem is bugging me for a long time now I hoped for each new version the problem would be fixed but it is not. This thread may be a good starting point to let you investigate the problem. Thanks for replying in advance.
Tuetchen
Diesmon Dominator
1st you are using the old deprecated scripting api please switch to the new one https://www.sinusbot.com/docs/scripting/
2nd it should be ev.client.name() and ev.client.uid() (not quite sure if there are differences to the old one - but thats how its done in the new version) Edit: okay its for the new one only but you should switch anyway so you ill keep it in so you know how to do it)
omano
Thanks for the reply. I will try to update my script with the new stuff and see if it now works :)
I'll let you know.
