Bug Event serverGroupAdded not fired
fabm3n
Tier II
Tier I
Operating System: Linux Debian Jessie 64 bit
SinusBot Version: 0.9.18-8499d2c
TS3 Version: 3.19.4
In the following Script no Text in the Log appers if i give someone or the bot an server group.
registerPlugin({
    version: '1.0',
    description: 'Test',
    author: 'fabm3n',
    vars: []
    var event = require('event');
    engine.log('Script gestartet');
    event.on('serverGroupAdded', function() {
        engine.log('Server Group added!');
 - Operating System: Debian GNU/Linux 8.8 (jessie)
 - Load Average: 0.61 0.63 0.71
 - Uptime: 29 days, 17 hours, 2 minutes, 47 seconds
 - OS Updates: 15 (updates available!)
 - OS APT Last Update: 15.05.2017 12:41:02 CEST +02:00:00
    CPU(s):                8
    Thread(s) per core:    2
    Core(s) per socket:    4
    Socket(s):             1
    Model name:            Intel(R) Core(TM) i7-6700 CPU @ 3.40GHz
    CPU MHz:               800.000
    Virtualization:        VT-x
 - RAM: 6.32 GB/62.88 GB in use (10%)
 - SWAP: 183.53 MB/31.96 GB in use (0%)
 - DISK: 100.28 GB/87.12 GB in use (115%)
   > libglib: 2.42.1-1+b12.42.1-1+b1
 - Status: running (PIDs: 3367 3365, User: sinusbot
ns2server)
 - Binary: /home/sinusbot/sinusbot (MD5 Hash: aa67b784b83f5a7e66c60496f58d4a92)
 - Version: 0.9.18-8499d2c
   - Bot Plugin: d53693319c8922b95257ad4c6eacff69
   - TS3 Client: d53693319c8922b95257ad4c6eacff69
   - TS3Path = /home/sinusbot/TeamSpeak3-Client-linux_amd64/ts3client_linux_amd64 (Version 3.0.19.4)
   - YoutubeDLPath = /usr/local/bin/youtube-dl (does exist, version: 2017.04.11)
 - Installed scripts: aloneMode.js; away_mover.js; mod_counter.js; reconnect.js; Support++.js
 - Report date: 15.05.2017 16:52:29 CEST +02:00:00 (timezone: Europe/Berlin)
 - youtube-dl Version: 2017.04.11
 - DiagScript version: 0.5.1
