Alebia
root@vps1522215:/opt# bash <(wget --no-check-certificate -O - 'https://sinusbot-installer.de/download.php?s=3f0d9f5bad7c40a46d82af8b35d4527d&t=1516904318')
--2018-01-25 18:48:05-- https://sinusbot-installer.de/download.php?s=3f0d9f5bad7c40a46d82af8b35d4527d&t=1516904318
Length: 31398 (31K) [application/octet-stream]
Saving to: ‘STDOUT’
- 100%[====================================================================>] 30.66K --.-KB/s in 0.001s
2018-01-25 18:48:06 (43.2 MB/s) - written to stdout [31398/31398]
Your installer is up-to-date.
You're using Installer 1.4
What should the Installer do?
1) Install
2) Update
3) Remove
4) PW Reset
5) Quit
#? 1
Done!
Automatically chosen system.d for your startscript!
1) Automatic
2) Own path
3) Quit
#? 1
1) No
2) Yes
#? 2
1) Yes
2) No
#? 1
Check your time below:
DATE: 01/25/18
TIME: 18:50:16
1) Correct
2) Incorrect
#? 1
1) Yes
2) No
#? 1
Starting the installer now!
Detected latest TS3-Client version as 3.1.8
Packages installed!
Please enter the name of the sinusbot user. Typically "sinusbot". If it does not exists, the installer will create it.
Username [sinusbot]:
Your sinusbot user is: sinusbot
Downloading TS3 client files.
Installing the TS3 client.
Read the eula!
Do the following: Press "ENTER" then press "q" after that press "y" and accept it with another "ENTER".
Welcome to the TeamSpeak 3 Client for Linux on amd64 installer
In order to install this software you are required to accept the license
agreement, please press return to view the license.
You can scroll with the arrow keys and quit the viewer by pressing 'q'.
[RETURN]
Please type y to accept, n otherwise:
Please type y to accept, n otherwise: y
Uncompressing TeamSpeak 3 Client for Linux on amd64 100%
TS3 client install done.
Downloading latest SinusBot.
Extracting SinusBot files.
SinusBot installation done.
Starting systemd installation
Installed systemd file to start the SinusBot with "service sinusbot {start|stop|status|restart}"
config.ini created successfully.
Installing Cronjob for automatic SinusBot update...
Installing SinusBot update cronjob successful.
Installing YT-Downloader now!
Installing Cronjob for automatic YT-DL update...
Installing Cronjob successful.
Downloading YT-DL now...
Download successful!
youtube-dl is up-to-date (2018.01.21)
Deleted /tmp/.X11-unix/X40
Starting the SinusBot. For first time.
2018/01/25 18:51:46 X [MAIN] Starting up fake x-server...
2018/01/25 18:51:47 [GENERAL/SCRIPTS] INFO Loading ScriptPlugin advertising.js
2018/01/25 18:51:47 [GENERAL/SCRIPTS] INFO Loading ScriptPlugin alonemode.js
2018/01/25 18:51:47 [GENERAL/SCRIPTS] INFO Loading ScriptPlugin bookmark.js
2018/01/25 18:51:47 [GENERAL/SCRIPTS] INFO Loading ScriptPlugin followme.js
2018/01/25 18:51:47 [GENERAL/SCRIPTS] INFO Loading ScriptPlugin norecording.js
2018/01/25 18:51:47 [GENERAL/SCRIPTS] INFO Loading ScriptPlugin rememberChannel.js
2018/01/25 18:51:47 [GENERAL/SCRIPTS] INFO Loading ScriptPlugin welcome.js
Plötzlich starte sinusbot nicht mehr ich habe es mehrfach mit einer neuinstallation probiert aber es kommt immer der gleich fehler raus.
Alebia
  • Aktuellste Version des Installers
  • Debian 8 aktuellste version
  • 12gb RAM 6 Cores 3,2GHZ
  • Browser Crome unintressant da fehler in der Konsole und generell keine abgeschlossene installation
  • RAM frei 10GB Speichjer 200gb
  • config.ini unverändert da gerade installiert
Es gibt schon Debian 9
Du bist der erste der 77 000 Installer-Script Installationen, der dieses Problem hat. Upgrade mal auf debian 9.3
