Vizi
Hello
i followed the installation guide (stepps Installation and Usage) and after i used
./sinusbot
i got
i guess sth with "PulseAudio is wrong..
./sinusbot
i got
2019/01/07 17:39:23 Updating database to v1... 0
2019/01/07 17:39:23 Updating database to v2... 1
2019/01/07 17:39:23 Updating database to v3... 2
2019/01/07 17:39:23 Updating database to v4... 3
2019/01/07 17:39:23 Updating database to v5... 4
2019/01/07 17:39:23 Updating database to v6... 5
2019/01/07 17:39:24 Updating database to v7... 6
2019/01/07 17:39:24 Updating database to v8... 7
2019/01/07 17:39:24 74cf6212 INFO Loading instances
2019/01/07 17:39:24 74cf6212 INFO Creating default instance
2019/01/07 17:39:24 74cf6212 9364384e INFO Starting instance ts3server://127.0.0.1?port=9987&nickname=SinusBot&password=&channel=&channelpassword=
2019/01/07 17:39:24 74cf6212 INFO Promoting instance to main instance
2019/01/07 17:39:24 X [MAIN] New connection
2019/01/07 17:39:25 74cf6212 INFO Added new user admin
2019/01/07 17:39:25 [GENERAL/FFMPEG ] INFO FFmpeg/avcodec v3741798; license: LGPL version 2.1 or later; 81 codecs
2019/01/07 17:39:25 [GENERAL/FFMPEG ] INFO FFmpeg/avformat v3742052; license: LGPL version 2.1 or later; 143 formats
2019/01/07 17:39:25 [GENERAL/!!!!!!!] NOTICE You may now configure and launch the bots from the webinterface. http://0.0.0.0:8087
2019/01/07 17:39:25 [GENERAL/RADIO ] INFO Could not find RadioStation-Data (or outdated), updating...
2019/01/07 17:39:26 X [MAIN] New connection
2019/01/07 17:39:26 74cf6212 9364384e INFO TS |INFO | | |TeamSpeak 3 Client 3.2.3 (2018-10-02 07:57:10)
2019/01/07 17:39:26 74cf6212 9364384e INFO TS |INFO | | |SystemInformation: Linux 4.9.120-xxxx-std-ipv6-64 #327490 SMP Thu Aug 16 10:11:35 UTC 2018
2019/01/07 17:39:27 X [MAIN] New connection
2019/01/07 17:39:27 74cf6212 9364384e INFO TS |ERROR |PulseAudio | |failed to connect to pulse audio server -
2019/01/07 17:39:27 74cf6212 9364384e INFO TS |ERROR |PulseAudio | |pa_context_connect failed -
2019/01/07 17:39:27 74cf6212 9364384e INFO TS |ERROR |SoundBckndIntf| |/home/sinusbot/TeamSpeak3-Client-linux_amd64/soundbackends/libpulseaudio_linux_amd64.so err
2019/01/07 17:39:27 74cf6212 9364384e INFO TS |INFO | | |*** Time [SPAWN_EVENTCONVERTER]: 122
2019/01/07 17:39:27 74cf6212 9364384e INFO TS |INFO |ClientUI | |Unable to create an Open GL context.
2019/01/07 17:39:27 74cf6212 9364384e INFO TS |ERROR |RevocationListCache| |Failed to import revocation list from cache
2019/01/07 17:39:27 74cf6212 9364384e INFO TS |INFO | | |*** Time [ICONMANGER]: 313
2019/01/07 17:39:27 74cf6212 9364384e INFO TS |DEVELOP |Addons | |Installation request for Gamepad and Joystick Hotkey Support
2019/01/07 17:39:27 74cf6212 9364384e INFO TS |DEVELOP |Addons | |Installation request for ClientQuery
2019/01/07 17:39:27 74cf6212 9364384e INFO TS |INFO |Addons | |Checking for addon updates...
2019/01/07 17:39:27 74cf6212 9364384e INFO TS |INFO |Plugins | |Loading plugin: libsoundbot_plugin.so
2019/01/07 17:39:27 74cf6212 9364384e WARN Could not send config: HTTP returned an error: Error; Code: 500; Message: Error
2019/01/07 17:39:27 74cf6212 9364384e INFO TS |INFO | | |successfully downloaded revocation list for accounting
2019/01/07 17:39:27 74cf6212 9364384e INFO TS |INFO | | |successfully downloaded revocation list for myteamspeak id
2019/01/07 17:39:27 [GENERAL/RADIO ] INFO RadioStation data loaded
2019/01/07 17:39:27 74cf6212 9364384e INFO TS |INFO |Addon | |Not available for this platform.
2019/01/07 17:39:29 74cf6212 9364384e INFO TS |INFO |SyncImpl | |Creating default config in local storage
2019/01/07 17:39:29 74cf6212 9364384e INFO TS |INFO | | |*** Time [MAINWINDOW_ACTIONS]: 103
2019/01/07 17:39:29 74cf6212 9364384e WARN Could not request shutdown. Please make sure that the plugin is installed correctly; HTTP returned an error: Error; Code: 5
2019/01/07 17:39:29 74cf6212 9364384e INFO TS |INFO | | |*** Time [SERVERVIEW]: 164
2019/01/07 17:39:29 74cf6212 9364384e INFO TS |INFO | | |*** Time [SERVERVIEWMANAGER]: 204
2019/01/07 17:39:29 [GENERAL/RADIO ] INFO Imported radio stations
2019/01/07 17:39:30 74cf6212 9364384e INFO TSClient quit.
^C
2019/01/07 17:45:05 [GENERAL ] Shutting down... Hold on...
