LetsBlade
Betriebssystem: Linux
SinusBot Version: - 0.9.20-a9b8dc6
TS3 Version: 3.0.18.2
Problembeschreibung
Erläutere bitte das Problem im Detail. Was hast du getan, was hast du erwartet und was ist stattdessen passiert?
Der Bot joint nur aufm Localhost.
//edit: Liegt nur an einem TS Server
IP + Port + Sicherheits-Stufe etc sind alles Mehrfach überprüft worden.
Problembeschreibung
2017-06-26T14:33:31+02:00 TSClient quit.
2017-06-26T14:33:31+02:00 Closed.
2017-06-26T14:33:31+02:00 TS>warning: The VAD has been replaced by a hack pending a complete rewrite
2017-06-26T14:33:31+02:00 TS>libpng warning: iCCP: known incorrect sRGB profile
2017-06-26T14:33:30+02:00 TS |INFO | | |Statistics report: User has not yet confirmed participation
2017-06-26T14:33:30+02:00 TS |INFO |ClientUI | |Last update check was: Tue Jan 1 00:00:01 2019
2017-06-26T14:33:30+02:00 New connection status 0; Error 0
2017-06-26T14:33:30+02:00 The bot could not connect. This might have several reasons: the server doesn't exist at that address, the server password is wrong, the default channel doesn't exist, the bot has been banned, the server is an illegal installation or the password is wrong , the security level of your identity is too low or the server does not allow the version of the client you are using. See our Wiki / Forums for more help.
2017-06-26T14:33:30+02:00 TS |INFO |ClientUI |1 |Disconnected or forced to leave, want autoreconnect = 0
2017-06-26T14:33:30+02:00 TS |INFO |ClientUI |1 |Connect status: Disconnected
2017-06-26T14:33:30+02:00 TS |DEVELOP |PktHandler | |Puzzle solve time: 3
2017-06-26T14:33:30+02:00 New connection status 1; Error 0
2017-06-26T14:33:30+02:00 TS |INFO |ClientUI |1 |Connect status: Connecting
2017-06-26T14:33:30+02:00 TS |INFO |PreProSpeex |1 |Speex version: 1.2rc1
2017-06-26T14:33:30+02:00 TS |INFO |ClientUI |1 |Initiating connection: 46.20.46.228:10192 46.20.46.228
2017-06-26T14:33:30+02:00 TS |INFO |ClientUI |1 |Blacklist check ok
2017-06-26T14:33:30+02:00 TS |INFO |ClientUI |1 |Connect to server: 46.20.46.228
2017-06-26T14:33:30+02:00 TS |INFO |ClientUI | |ts3server: 46.20.46.228?port=10192&nickname=Musikbot%20%C2%BB%20by%20Blade&password=&cid=65064&channelpassword=
2017-06-26T14:33:30+02:00 TS |INFO |ClientUI | |Using configuration location: /opt/bot/data/ts3/dd1b93d8-f4bb-4afd-b016-87d8769b1108/1d64f562-ab5e-4f05-bdd1-eb02a1975cec/settings.db
2017-06-26T14:33:30+02:00 TS |INFO |ClientUI | |Qt version: 5.5.0
2017-06-26T14:33:30+02:00 TS |INFO |ClientUI | |Failed to init text to speech engine
2017-06-26T14:33:30+02:00 TS |ERROR |Query | |bind failed on 127.0.0.1:25639
2017-06-26T14:33:30+02:00 TS |INFO | | |Loading plugin: libtest_plugin
2017-06-26T14:33:30+02:00 TS |INFO | | |Loading plugin: libsoundbot_plugin
2017-06-26T14:33:30+02:00 TS |INFO | | |Loading plugin: liblua_plugin
2017-06-26T14:33:30+02:00 TS |INFO | | |Loading plugin: libclientquery_plugin
2017-06-26T14:33:29+02:00 TS |ERROR |SoundBckndIntf| |/opt/bot/TeamSpeak3-Client-linux_amd64/soundbackends/libpulseaudio_linux_amd64.so error: INIT_PA_IMPL
2017-06-26T14:33:29+02:00 TS |ERROR |PulseAudio | |pa_context_connect failed
2017-06-26T14:33:29+02:00 TS |ERROR |PulseAudio | |failed to connect to pulse audio server
2017-06-26T14:33:29+02:00 TS |INFO | | |Using hardware aes
2017-06-26T14:33:29+02:00 TS |INFO | | |SystemInformation: Linux 3.16.0-4-amd64 #1 SMP Debian 3.16.39-1+deb8u2 (2017-03-07) x86_64 Binary: 64bit
2017-06-26T14:33:29+02:00 TS |INFO | | |TeamSpeak 3 Client 3.0.18.2 (2015-10-22 11:14:48)
