[GER][ENG] Scripts klappen nicht / Scripts dont work
xdmartinhi
Ich habe das Problem das die scripts nicht mehr funktionieren.
Die Scripts:
Support++
Ranks
AFK Mover
Diese funktionieren plötzlich nicht mehr.
woran kann es liegen?
ENGLISH Google translate:
I have the problem that the scripts no longer work.
The scripts:
Support ++
Ranks
AFK movers
These suddenly do not work anymore.
Diag Script Copy:
https://hastebin.com/hazujahiwu.cs / Bot version: SinusBot 0.14.3-0e747fd
what could be the problem?
Does nothing work anymore? Not even the !help command?
If so, then it is a known problem (see here) and will hopefully be fixed soon.
