EN get clientId from clientUid
jowieweb
I'm playing around with the scripting API, but I got stuck...
I need the clientid, but I only have the clientUid or the nickname. Is there a way to look it up? Or a way to list ALL connected users and then search the right id?
I guess i could log all users with the onMove method and than search by myself?
But thats a quite ugly way...
thx for the help,
jowieweb
    function getClientByUid(uid) {
        return getClientByParam('uid', uid);
    function getClientById(id) {
        return getClientByParam('id', id);
    function getClientByParam(search_key, search_value) {
        var channels = getChannels();
        for (var i = 0; i < channels.length; i++) {
            if (channels[i]['clients'].length > 0) {
                for (var key in channels[i]['clients']) {
                    if (channels[i]['clients'][key][search_key] == search_value) {
                        var client = channels[i]['clients'][key];
                        client.cid = channels[i].id;
                        return client;
        return false;
Here you are able to get the client as object with the function
var client = getClientByUid('someuidhere=');
