EN Get client's group
DrWarpMan
First, is this code right?
Second, If I have a group named "test", will this return true? Or how can I get "if a client has specified group"?
if(ev.client.getServerGroups().includes('test'))
DrWarpMan
But there I didn't ask how to get "if user has specified client's group".. or maybe I am blind..
DrWarpMan
But.. I want to get clients group.. what should I do? This?
var group = ev.client.getServerGroupByName("test")
if (!group) {
    // does not exist
} else {
    // does exist
Everlike
This Code won’t work.
I would do it like this.
var servergroupsOfUser = ev.client.getServerGroups();
function checkIfUserIsInGroup(servergroupsOfUser) {
var allserverIdsOfUser = new Array;
for (i = 0; i < servergroupsOfUser.length ; i++) {
allserverIdsOfUser.push(servergroupsOfUser.channel.id()
return allserverIdsOfUser;
if (checkIfUserIsInGroup(servergroupsOfUser).indexOf(insertAServergroupIdHere) >= 0) {
engine.log(„he is in the group“);
I can’t check if the code works, but I have working functions like this in some of my script, just check out my „servergroup switcher, and, or „admin % Moderator status“ script. There you should find good examples.
Everlike
Well, Iam on my phone, all this typing for nothing. Fukk me.
But afaik „.includes()“ does not work, I would recommend the .indexOf() <=0 thing.
It's not that hard and there are multiple ways to do it, basic js:
JavaScript:
if (hasServerGroupWithName(client, "foogroup")) {
    // do stuff
function hasServerGroupWithName(client, name)
    return client.getServerGroups().some(function (group) {
        return group.name() == name
(also not tested, may contain traces of typos™)
Edit: fixed typo™
DrWarpMan
Somehow it ain't working.
                if(hasServerGroupWithName(ev.client, "Magic") {
                    ev.client.chat('test');
    function hasServerGroupWithName(client, name){
DrWarpMan
The problem is.. where can I find the log.. and I do not think that it is Instance or Bot log..
Everlike
You can set the log path in your config.ini. f.e. /opt/sonusbot/logs.
But as @irgendwer teached me, the instamce/webinterface log should be such as good.
DrWarpMan
Now I wanted to change it, but suddenly, my config.ini just have this
ListenHost = "ip(hidden)"
inside, and I remember months ago, that I had more than 50 lines of text.
