GLIBC_2.14' not found (required by ./sinusbot)
SpliinTaX_
Betriebssystem: Linux
SinusBot Version: Keine Ahnung => Datei heißt sinusbot-beta.tar
TS3 Version: 3.0.13.8
Problembeschreibung
Ich wollte die Musikbots starten über ./sinusbot und musste folgendes feststellen:
musicbot@project-infinity:~/sinusbot$ ./sinusbot
./sinusbot: /lib/x86_64-linux-gnu/libc.so.6: version `GLIBC_2.14' not found (required by ./sinusbot)
 - Operating System: Debian GNU/Linux 7.11 (wheezy)
 - Kernel: Linux 4.4.83-1-pve x86_64
 - Load Average: 24.04 22.78 22.23
 - Uptime: 0 days, 0 hours, 18 minutes, 25 seconds
 - OS APT Last Update: 09.12.2017 17:38:16 CET +01:00:00
 - SHELL LOCALE LANG:
  Architecture:  x86_64
  CPU(s):  16
  Thread(s) per core:  2
  Core(s) per socket:  8
  Socket(s):  1
  CPU MHz:  2599.968
  Virtualization:  VT-x
 - RAM: 780.72 MB/1.00 GB in use (76%)
 - DISK: 9.89 GB/36.68 GB in use (26%)
  + libglib: 2.33.12+really2.32.4-5
 - Binary: /home/musicbot/sinusbot/sinusbot
 - Binary Info: MD5 Hash: febce0ebdd2d2e9d7f69701bc5a7c339, Perms: 755, User: musicbot
 - Version:
  - TS3Path = /home/musicbot/TeamSpeak3-Client-linux_amd64/ts3client_linux_amd64 (Version 3.0.18.2)
  - YoutubeDLPath = not set
 - Installed scripts: MusicSoundText Message On Join.js; ServerQuery.js; ShowPlaylists.js; ZTSupport(1).js; advertising.js; advertisingOLD.js; aloneMode.js; alonemode.js; badchan.js; bookmark.js; channelassigner.js; covatar.js; dev.js; digitalclock.js; followme.js; idle.js; metadata.js; norecording.js; reconnect.js; rememberChannel.js; showcase.js; sound.js; support_0.2.js; welcome.js; welcomeSound.js; welcometext.js
 - Time (local): 09.12.2017 18:19:47 CET +01:00:00
 - Time (remote): 01.01.1900 01:00:00 CET +01:00:00
 - Time (difference): -3721828787 secs (Time diff less than 10 secs. Aceptable.)
 - Timezone: America/New_York
 - youtube-dl Version: unknown
 - DiagScript Version: 0.6.1
SpliinTaX_
Daran sollte es eigentlich nicht liegen oder? [...]
Ich konnte die ganze Zeit Sinusbot verwenden, seit eine Zeit leider nicht mehr.
