HELP What can i do? Another Bot is not running! and how can i stop a Bot?
_ _ _ _ _ _ _ _ _ ___ BETA
/ __|_ | \| | | | / _| _ )/ _ \_ _|
\__ \| || .` | || \_ \ _ \ (_) || |
|/||\|\/|//\/ |_|
Version: 0.14.3-0e747fd
2019/03/05 19:55:27 [GENERAL/SCRIPTS] INFO Loading ScriptPlugin advertising.js
2019/03/05 19:55:27 [GENERAL/SCRIPTS] INFO Loading ScriptPlugin alonemode.js
2019/03/05 19:55:27 [GENERAL/SCRIPTS] INFO Loading ScriptPlugin bookmark.js
2019/03/05 19:55:27 [GENERAL/SCRIPTS] INFO Loading ScriptPlugin followme.js
2019/03/05 19:55:27 [GENERAL/SCRIPTS] INFO Loading ScriptPlugin norecording.js
2019/03/05 19:55:27 [GENERAL/SCRIPTS] INFO Loading ScriptPlugin rememberChannel.js
2019/03/05 19:55:27 [GENERAL/SCRIPTS] INFO Loading ScriptPlugin welcome.js
2019/03/05 19:55:27 b9dd2d39 INFO Loading instances
2019/03/05 19:55:27 b9dd2d39 INFO Loading instance://17b94845-a01a-419a-b7c4-7da90bc4f7b0
2019/03/05 19:55:27 b9dd2d39 17b94845 INFO Initialization complete
2019/03/05 19:55:27 b9dd2d39 17b94845 INFO Auto-Starting b9dd2d39-1ec6-406c-a6c7-8137ceecdf3b/17b94845-a01a-419a-b7c4-7da90bc4f7b0 in 500 ms...
2019/03/05 19:55:27 [GENERAL/FFMPEG ] INFO FFmpeg/avcodec v3741798; license: LGPL version 2.1 or later; 81 codecs
2019/03/05 19:55:27 [GENERAL/FFMPEG ] INFO FFmpeg/avformat v3742052; license: LGPL version 2.1 or later; 143 formats
2019/03/05 19:55:27 [GENERAL/!!!!!!!] NOTICE You may now configure and launch the bots from the webinterface. http://0.0.0.0:8087
2019/03/05 19:55:27 [GENERAL/RADIO ] INFO Could not find RadioStation-Data (or outdated), updating...
error starting up: listen tcp 0.0.0.0:8087: bind: address already in usesinusbot@cythostnet:/opt/ts3soundboard$ su root
it seems like that either sinusbot or another process is using the port 8087 on your machine
you can check with the command ss -tulp
and how can i stop the process? this is the message with the port
users:(("rpc.statd",pid=458,fd=11))
tcp LISTEN 0 128 :::8087 :::* users:(("sinusbot",pid=16719,fd=14))
Night
Dear H3id3ltraut 05,
Can you tell me which "OS" are you using now?
Which version of sinusbot are you using now?
Did you check your error log?If you did paste a errors here.
Paste here your config file.
Did you try to delete your installation and make a new clean installation with "Sinusbot Installer"
Best regards,
Adrian
