=> The server is bad configured, it requires a newer client versions, though that I'm using the latest one.
(Advanced permission system failure, you need to remove the setting that the client version is required)
1. Download: http://yat.qa/
2. Install
3. Login via your server query login
3.1. If you doesn't have that anymore, please read: https://support.teamspeakusa.com/in...sword-of-the-serveradmin-server-query-account
4. Follow these steps (screenshot)
5. Check your entries: Desktop set to "3.1.7 (17-12-13 12:07:31)", Android set to "3.1.8 (18-01-25 08:30:56)" and iOS set to "3.1.8 (18-01-25 14:45:27)"
