Hallo ich habe ein Problem,
ich versuch gerade den 6 Bot zu starten aber er geht dann wieder aus !
[HEADING=1]Instanz-Log[/HEADING]
2020-11-06T00:13:29+01:00 eof from data
2020-11-06T00:13:29+01:00 closing channels
2020-11-06T00:13:29+01:00 eof from voice
2020-11-06T00:13:28+01:00 TSClient quit. LogLevel has been increased, please try to connect again to see more details.
2020-11-06T00:13:28+01:00 Closed.
2020-11-06T00:13:28+01:00 TS>terminating with uncaught exception of type std::__1::system_error: thread constructor failed: Die Ressource ist zur Zeit nicht verfügbar
2020-11-06T00:13:28+01:00 TS |CRITICAL| | |Failure during pthread_create, error = EAGAIN
2020-11-06T00:13:28+01:00 TS>QXcbIntegration: Cannot create platform OpenGL context, neither GLX nor EGL are enabled
2020-11-06T00:13:28+01:00 TS>QStandardPaths: XDG_RUNTIME_DIR not set, defaulting to '/tmp/runtime-sinusbot'
2020-11-06T00:13:28+01:00 TS>qt.qpa.xkeyboard: no keyboard layouts with latin keys present
2020-11-06T00:13:28+01:00 TS>QCoreApplication::applicationDirPath: Please instantiate the QApplication object first
2020-11-06T00:13:28+01:00 TS>Crashdump written (unhandled) !
2020-11-06T00:13:28+01:00 TS |INFO | | |successfully downloaded revocation list for accounting
2020-11-06T00:13:28+01:00 TS |INFO |Plugins | |Loading plugin: libsoundbot_plugin.so
2020-11-06T00:13:28+01:00 TS |INFO |Addons | |Checking for addon updates...
2020-11-06T00:13:28+01:00 TS |ERROR |RevocationListCache| |Failed to import revocation list from cache
2020-11-06T00:13:28+01:00 TS |INFO |ClientUI | |Unable to create an Open GL context.
2020-11-06T00:13:28+01:00 TS |ERROR |SoundBckndIntf| |/opt/sinusbot/teamspeak3-client/soundbackends/libpulseaudio_linux_amd64.so error: INIT_PA_IMPL
2020-11-06T00:13:28+01:00 TS |ERROR |PulseAudio | |pa_context_connect failed -
2020-11-06T00:13:28+01:00 TS |ERROR |PulseAudio | |failed to connect to pulse audio server -
2020-11-06T00:13:27+01:00 TS |INFO | | |Using hardware aes
2020-11-06T00:13:27+01:00 TS |INFO | | |SystemInformation: Linux 4.9.0 #1 SMP Tue Jun 9 12:58:54 MSK 2020 x86_64 Binary: 64bit
2020-11-06T00:13:27+01:00 TS |INFO | | |TeamSpeak Client 3.5.3 (2020-05-06 09:07:50)
2020-11-06T00:13:27+01:00 TS>DUMP defined! Dumpdir is: /opt/sinusbot/data/ts3/0f5c4f3b-0d50-45dd-afa4-d1d3baebcfb0/67b3e290-ec6e-21a2-8d11-520e902ff127/crashdumps
2020-11-06T00:13:27+01:00 TS>Crashdump ENABLED, directory is: /opt/sinusbot/data/ts3/0f5c4f3b-0d50-45dd-afa4-d1d3baebcfb0/67b3e290-ec6e-21a2-8d11-520e902ff127/crashdumps
2020-11-06T00:13:27+01:00 Starting instance ts3server://127.0.0.1?port=9987&nickname=H%C3%B6re%3A%20%5BClubTime.FM%5D&password=&cid=105&channelpassword=
2020-11-06T00:13:27+01:00 Could not insert into FileTransfer-Tableno such table: FileTransfer
2020-11-06T00:13:27+01:00 Could not delete from FileTransferno such table: FileTransfer
2020-11-06T00:13:27+01:00 Could not create Notifications-Tabletable Notifications already exists
2020-11-06T00:13:27+01:00 Could not create WhisperReceive-Tabletable WhisperReceive already exists
2020-11-06T00:13:27+01:00 Could not create Chat-Tabletable Chat already exists
2020-11-06T00:13:27+01:00 About to run.
2020-11-06T00:13:27+01:00 Prespawn.
2020-11-06T00:12:39+01:00 imported module: command
2020-11-06T00:12:39+01:00 resolving module command
2020-11-06T00:12:39+01:00 script command loaded
2020-11-06T00:12:39+01:00 module registered as command
2020-11-06T00:12:39+01:00 registered callback for event chat
2020-11-06T00:12:39+01:00 Initialization complete
2020-11-06T00:12:39+01:00 script sinusbot-commands loaded
2020-11-06T00:12:39+01:00 registered callback for event load
2020-11-06T00:12:39+01:00 [sinusbot-commands:86:12] Loaded SinusBot Commands v1.0.0 by Jonas Bögle (@irgendwr).
2020-11-06T00:12:39+01:00 executing script command
2020-11-06T00:12:39+01:00 executing script sinusbot-commands
